Julio Cesar Goldner Vendramini
  1. BPI-M4-Zero: Fast Ethernet (AC300 internal EPHY) working on current 6.18 Following up on the reports that EMAC1 never detects a PHY on this board — I got it working and submitted a PR: armbian/build#10328 WHAT WAS WRONG The board DTS describes an external RMII PHY at MDIO address 1. That PHY doesn't exist. The Fast Ethernet comes from the SoC-internal AC300 EPHY, routed through the 24-pin FPC connector, so the MAC was probing correctly and finding nothing on the bus. WHAT WAS NEEDED Three things had to line up. First, CONFIG_AC300_PHY=y and the h616-internal-phy stmmac patch. These landed in main around June/July 2026, so stable 26.2.1 doesn't have them. I lost a good while on that. Rolling/nightly or a self-built image is required. Second, compatible changed from allwinner,sun50i-h616-emac to allwinner,sun50i-h616-internal-emac. The first one maps to the H6 variant, which is external PHY only. Third, the AC300 description itself: mdio-mux plus mdio-internal, PWM5 as the 2MHz reference clock, and the SID calibration cell. I based it on arm64-dts-sun50i-h616-bigtreetech-cb1-emac1-ac300.patch RESULTS (BPI-M4-Zero v2, Noble, current 6.18.42) Link at 100Mb/s full duplex, DHCP on first boot iperf3: 94.7 Mbit/s over 20s, zero retransmissions I kept EMAC1 disabled in the base DTS since it needs the FPC expansion board, and enabling it would reserve PA0-PA9 plus PWM5 for everyone else. There's a separate overlay (bananapi-m4-zero-fpc24-eth) to turn it on. ONE ODDITY ethtool reports "Supported link modes: 10baseT/Half 10baseT/Full" even though the link negotiates 100/Full and reaches line rate. Looks like a capability-reporting issue in the AC300 PHY driver rather than anything in the DTS. Worth a look from someone more familiar with that driver. ALSO The analog codec just needs &codec enabled with "Line Out", "LINEOUT" routing, same as sun50i-h618-orangepi-zero2w.dts. Included in the same PR. A note for anyone who finds unofficial images in the Banana Pi wiki's Google Drive: those are built from the BPI fork of armbian-build, which doesn't carry the AC300 patches. The newer kernel version alone won't help.
  2. Yes, but now, I'm trying to make Bluetooth work and put Armbian to boot from eMMC. But I don't know exactly how to correctly submit these changes.
  3. Hi everyone! 👋 I managed to get Armbian running on a generic RK3518 TV box — mainline U-Boot, onboard Ethernet, and AIC8800D80 SDIO Wi-Fi all working. I couldn't find a single RK3518 thread here when I started, so I wrote everything up to help the community. Full step-by-step guide, device tree, and the loader binaries I built are in my GitHub repo: 👉https://github.com/juliovendramini/rk3518_armbian Happy to answer questions. Hope it helps someone! 🙂
