acupofchicory
  1. it was this! after i booted from official OS i erased first 4mb of emmc to make it un-bootable. and i finally could load from armbian system
  2. OKAY SO I SPEND 5 HOURS FIGURING IT OUT AND I (oh i should cald down) figured out that issue was in images. none of images that were listed on page for orange pi 4 lts did not work. the second i inserted sd cart with official OS from orange pi it booted. btw there is log when any armbian image is used: In channel 0 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x83 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 353 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 251529 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3335db8 signature is wrong recovery gpt... GPT 0x3335db8 signature is wrong recovery gpt fail! Trust Addr:0x4000, 0x0 Trust Addr:0x4400, 0x0 Trust Addr:0x4800, 0x0 Trust Addr:0x4c00, 0x0 Trust Addr:0x5000, 0x0 Trust Addr:0x5400, 0x0 Trust Addr:0x5800, 0x0 Trust Addr:0x5c00, 0x0 Addr:0x4000 No find trust.img! LoadTrustBL error:-3 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT part: 0, name: security, start:0x2000, size:0x2000 GPT part: 1, name: uboot, start:0x4000, size:0x2000 GPT part: 2, name: trust, start:0x6000, size:0x2000 GPT part: 3, name: misc, start:0x8000, size:0x2000 GPT part: 4, name: dtbo, start:0xa000, size:0x2000 GPT part: 5, name: vbmeta, start:0xc000, size:0x800 GPT part: 6, name: boot, start:0xc800, size:0x14000 GPT part: 7, name: recovery, start:0x20800, size:0x36000 GPT part: 8, name: backup, start:0x56800, size:0xba000 GPT part: 9, name: cache, start:0x110800, size:0xc0000 GPT part: 10, name: metadata, start:0x1d0800, size:0x8000 GPT part: 11, name: baseparameter, start:0x1d8800, size:0x800 GPT part: 12, name: super, start:0x1d9000, size:0x614000 GPT part: 13, name: userdata, start:0x7ed000, size:0x1531fdf find part:uboot OK. first_lba:0x4000. find part:trust OK. first_lba:0x6000. Trust Addr:0x6000, 0x58334c42 No find bl30.bin Load uboot, ReadLba = 4000 Load OK, addr=0x200000, size=0x10aad0 RunBL31 0x40000 @ 315316 us NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a #zhangzj #9 Fri Sep 17 09:39:24 UTC 2021 aarch64) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09 #orangepi (Sep 14 2022 - 19:19:13 +0800) Model: Rockchip RK3399 Evaluation Board PreSerial: 2, raw, 0xff1a0000 DRAM: 3.8 GiB Sysmem: init Relocation Offset: f5a70000 Relocation fdt: f3c642c0 - f3c66cdb CR: M/C/I Using default environment DM: v1 dwmmc@fe320000: 1, sdhci@fe330000: 0 Bootdev(atags): mmc 0 MMC0: HS400, 150Mhz PartType: EFI boot mode: None Android 12.0, Build 2022.6, v2 Found DTB in boot part DTB: rk-kernel.dtb HASH(c): OK ANDROID: fdt overlay OK I2c0 speed: 400000Hz PMIC: RK808 vdd_center 900000 uV vdd_cpu_l 900000 uV vdd_log 1100000 uV warning: bad baseparameter Model: OrangePi 4 LTS Rockchip UBOOT DRM driver version: v1.0.1 I2c7 speed: 100000Hz Monitor has basic audio support hdmi info isn't saved in main block mode:1920x1080 hdmi@ff940000: detailed mode cloc 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 2025 CEA mode used vic=16 final pixclk = 148500000 tmdsclk = 148500000 xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY powered down in 0 iterations xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY PLL locked 1 iterations PHY powered down in 0 iterations xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY PLL locked 1 iterations sink has audio support hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500 CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A) aplll 816000 KHz apllb 816000 KHz dpll 856000 KHz cpll 24000 KHz gpll 800000 KHz npll 600000 KHz vpll 148000 KHz aclk_perihp 133333 KHz hclk_perihp 66666 KHz pclk_perihp 33333 KHz aclk_perilp0 266666 KHz hclk_perilp0 88888 KHz pclk_perilp0 44444 KHz hclk_perilp1 100000 KHz pclk_perilp1 50000 KHz Net: eth0: ethernet@fe300000 Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "(none)" optee api revision: 2.0 TEEC: Reset area[0] info... TEEC: Reset area[1] info... Vboot=0, AVB images, AVB verify read_is_device_unlocked() ops returned that device is UNLOCKED avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED get image from preloaded partition... Could not find "system" partition Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000... Fdt Ramdisk skip relocation ## Booting Android Image at 0x0027f800 ... Kernel: 0x00280000 - 0x01e5d010 (28533 KiB) ramdisk: 0x0a200000 - 0x0a34d708 (1334 KiB) ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 XIP Kernel Image from 0x00280000 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x01e5d010 'reserved-memory' ramoops@110000: addr=110000 size=f0000 Using Device Tree in place at 0000000008300000, end 000000000831d220 failed to reserve drm-cubic-lut memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000) Total: 840.79 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.232 (orangepi@ubuntu) (Android (7284624, based on r416183b) clang version 12.0.5 (https://android.googlesource.com/toolchain/llvm-project c935d99d7cf2016289302412d708641d52d2f7ee), LLD 12.0.5 (/buildbot/src/android/llvm-toolchain/out/llvm-project/lld c935d99d7cf2016289302412d708641d52d2f7ee)) #14 SMP PREEMPT Thu Sep 1 11:19:51 CST 2022 [ 0.000000] Machine model: OrangePi 4 LTS [ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '') [ 0.000000] bootconsole [uart8250] enabled console:/ $ INF USER-TA:read_data_from_uboot_ta:661: (read_data_from_uboot_ta) filename(security_partition) ! ERR [0x1] TEE-CORE:ree_fs_open:1492: tee file not exists ERR USER-TA:read_data_from_uboot_ta:689: TEE_InvokeTACommand returned 0xffff0000 INF USER-TA:TA_OpenSessionEntryPoint:341: Hello Rockchip Keymaster! rpmb :1 INF USER-TA:read_data_from_uboot_ta:661: (read_data_from_uboot_ta) filename(security_partition) ! ERR [0x0] TEE-CORE:ree_fs_open:1492: tee file not exists ERR USER-TA:read_data_from_uboot_ta:689: TEE_InvokeTACommand returned 0xffff0000 INF USER-TA:TA_OpenSessionEntryPoint:341: Hello Rockchip Keymaster! rpmb :1 INF USER-TA:TA_InvokeCommandEntryPoint:2132: -------1111-----TA_InvokeCommandEntryPoint------105 INF USER-TA:TA_OpenSessionEntryPoint:96: Hello Rockchip Weaver! rpmb :1 INF USER-TA:TA_OpenSessionEntryPoint:114: Hello Rockchip gatekeeper! rpmb :1 and this is how it looks when official image is used: In channel 0 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x3 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 352 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=14928MB FwPartOffset=2000 , 0 StorageInit ok = 108458 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3335db8 signature is wrong recovery gpt... GPT part: 0, name: EFI System Partition, start:0x28, size:0x64000 GPT part: 1, name: , start:0x64800, size:0x1cc3000 recovery gpt success! no find partition:uboot. Trust Addr:0x4000, 0x58334c42 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xb5130 RunBL31 0x40000 @ 288354 us NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-orangepi (Aug 01 2022 - 13:34:32 +0800) Model: OrangePi 4 AI board DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: OrangePi 4 AI board Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3341 bytes read in 9 ms (362.3 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 159 bytes read in 7 ms (21.5 KiB/s) 21540756 bytes read in 1823 ms (11.3 MiB/s) 10807969 bytes read in 920 ms (11.2 MiB/s) 102595 bytes read in 22 ms (4.4 MiB/s) 2698 bytes read in 16 ms (164.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Uncompressing Kernel Image Moving Image from 0x2080000 to 0x2200000, end=40e0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 21540692 Bytes = 20.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4a99000, end f5f23f54 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0) Loading Device Tree to 00000000f4a17000, end 00000000f4a98fff ... OK Starting kernel ... Orange Pi 3.0.6 Focal ttyS2 orangepi4-lts login: orangepi Password: Login incorrect orangepi4-lts login: admin Password: Login incorrect orangepi4-lts login: Login timed out after 60 seconds. Orange Pi 3.0.6 Focal ttyS2 orangepi4-lts login: orangepi Password: Login incorrect orangepi4-lts login: orangepi Password: ___ ____ ___ _ _ _ _____ ____ / _ \| _ \_ _| | || | | | |_ _/ ___| | | | | |_) | | | || |_ | | | | \___ \ | |_| | __/| | |__ _| | |___| |ocal with Linux 5.10.43 System load: 35% Up time: 4 min Memory usage: 17% of 3.77G IP: CPU temp: 78°C Usage of /: 19% of 14G [ 0 security updates available, 2 updates total: apt upgrade ] Last check: 2022-08-01 06:00 [ General system configuration (beta): orangepi-config ] orangepi@orangepi4-lts:~$ so question appears, why none of releases did not work? why only official image? then the point of those images existing? or my OPi4LTS is broken?
  3. i have 2 sd cards, 32 and 16gb. on every of them i burned ubuntu xfce and debian cli using dd and armbian imager (8 total tries). none worked. board every time booted into Android which locates on 16gb internal eMMC. what should i do? i looked into manual but no luck. i dont have DC to power board while doing maskrom. maybe i can wipe emmc from itself ( boot into android 12 and destroy it)? or i noticed that when i connect board via usb type c to my mac, it still powers on, so maybe i dont even need dc power to get maskrom device? im geniue lost now, i was searching in web for solution past 3 hours
