HDMI0 fails to link at low pixel clocks (hdptx phy lane can't ready) — workaround via patched EDID
@Boardcon_yang thanks for confirming this on the EM3588 — the ~75MHz threshold you're seeing lines up exactly with what I found: 50.25MHz never locks, 74.25MHz (the 720p60 clock) locks every time on the same port and cable. Good to know it's not specific to the Orange Pi 5 Pro or to this particular panel. Also, apologies: the "[link a deploy/edid/README.md ...]" line at the end of my first post was a leftover placeholder (the repo is private), and I can no longer edit the post. Here are the full steps instead, so this is self-contained: 1) Validate the timing live first (stop getty@tty1 so modetest can take DRM master): sudo systemctl stop getty@tty1 sudo modetest -M rockchip -s <connector_id>:1024,1210,1278,1650,600,625,650,750-60 -> dmesg should show "hdptx phy lane locked!" and the panel should show an image. Timing used (same 1024x600 active area, more blanking, 74.25MHz = the 720p60 clock): H: active 1024, front porch 186, sync 68, back porch 372 -> htotal 1650 V: active 600, front porch 25, sync 25, back porch 100 -> vtotal 750 74,250,000 / (1650 x 750) = 60.0 Hz 2) Patch the EDID: dump the panel's real EDID (modetest -M rockchip -c, EDID blob property of the connector), rewrite only the first Detailed Timing Descriptor (bytes 54-71) with the timing above, keep the physical size bytes (66-71) untouched, and recompute the checksum (byte 127). 3) The initramfs gotcha (as you said, the connector asks for the EDID before the rootfs is up): update-initramfs does NOT pick up loose files in /lib/firmware/edid/ — it only packs firmware referenced by kernel modules. Without this you get "Direct firmware load for edid/<file>.bin failed with error -2". /etc/initramfs-tools/hooks/edid-firmware (chmod +x): #!/bin/sh PREREQ="" prereqs() { echo "$PREREQ"; } case "$1" in prereqs) prereqs; exit 0 ;; esac . /usr/share/initramfs-tools/hook-functions copy_file firmware /lib/firmware/edid/monitor7_1024x600_ib.bin sudo update-initramfs -u lsinitramfs /boot/initrd.img-$(uname -r) | grep edid # must list the file 4) /boot/armbianEnv.txt, extraargs: video=HDMI-A-1:1024x600@60 drm.edid_firmware=HDMI-A-1:edid/monitor7_1024x600_ib.bin Note: use drm.edid_firmware= — the old drm_kms_helper.edid_firmware= is deprecated on this kernel and silently loads nothing (only a warning).
Board: Orange Pi 5 Pro (RK3588S) OS: Armbian, kernel 6.1.115-vendor-rk35xx Display: Generic 7" HDMI panel, 1024x600 native (SKU MPI7002, "7inch HDMI Display-C") Symptom HDMI0 (the HDMI 2.1 port, using the new hdptx combo PHY via dwhdmi-rockchip) reliably fails to link-train at this panel's native timing (1024x600@59.82Hz, pixel clock 50.25MHz): dwhdmi-rockchip fde80000.hdmi: use tmds mode rockchip-vop2: Update mode to 1024x600p60 ... dclk: 50250000 rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane can't ready! phy phy-fed60000.hdmiphy.7: phy poweron failed --> -22 dwhdmi-rockchip fde80000.hdmi: dw_hdmi_qp_setup hdmi set operation mode failed 100% reproducible across 6+ reboots. Ruled out with real hardware tests (not the actual cause): Bad cable (same HDMI 2.1 8K UHD cable works fine on the board's other HDMI port) Monitor power sequencing (fails identically whether the monitor is powered from the Pi's own USB or an independent wall adapter) Shared PHY contention (fails identically with only one monitor connected, nothing else) What actually works The same physical port locks fine at a higher pixel clock — confirmed with the standard 720p60 timing (1280x720@60, dclk 74.25MHz): rockchip-vop2: Update mode to 1280x720p60 ... dclk: 74250000 dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 74250000 rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked! So this looks specific to low pixel clocks on this PHY, not a broken port. This matches ongoing upstream work on phy-rockchip-samsung-hdptx (patch series through v6, August 2026) fixing PLL/clock-ratio edge cases — this vendor kernel predates those fixes. (Side note: the board's second HDMI port, which shows up as DP-1/DP0 in dmesg since it's actually the SoC's native DP output through an on-board Lontium LT8711UXD DP-to-HDMI bridge chip, is not a working alternative for this panel either — Armbian's kernel has no driver/devicetree node for that bridge chip at all, so DP link training "succeeds" at the protocol level but no usable HDMI signal ever reaches the display.) Workaround: EDID override with increased blanking Instead of switching resolutions (with visible upscaling artifacts), I kept the monitor's native 1024x600 active area but patched its EDID to advertise a higher pixel clock via more blanking (1024x600, htotal 1650, vtotal 750, dclk 74.25MHz — reusing the same clock that's confirmed to work at 720p60), then loaded it via drm.edid_firmware=. Confirmed working end-to-end from cold boot: [drm] Got external EDID base block and 1 extension from "edid/monitor7_1024x600_ib.bin" for connector "HDMI-A-1" Update mode to 1024x600p60 ... dclk: 74250000 hdptx phy lane locked! Full write-up (EDID byte-level patching script, initramfs hook gotcha, etc.) here: [link a deploy/edid/README.md en tu repo, si quieres que sea público] Posting in case anyone else hits the same low-clock failure on this PHY, and in case it's a useful data point for whoever's working on the phy-rockchip-samsung-hdptx patches.
TrueLine Timing
