chiefwigms
  1. you'd need to add a user patch at the moment.. finally had time to make a PR
  2. These two patches: https://lore.kernel.org/linux-arm-kernel/20240401023347.3114484-1-festevam@gmail.com/ https://lore.kernel.org/linux-arm-kernel/20240401023347.3114484-2-festevam@gmail.com/ Should get in the 6.9 kernel - as well as changing ONBOARD_USB_HUB to ONBOAD_USB_DEV in the kernel config https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/usb/misc/onboard_usb_hub.c?h=v6.9-rc3&id=65e62b8a955adebee8634804d8f72599213c2774 is already in mainline but was committed after 6.6/6.7. I'll make a PR sometime this weekend and try to test with edge, as well as an updated defconfig - don't really have much time these days to do anything 🥲
  3. Okay - finally got around to testing (with more back and forth between Fabio). There were some updates to what he patched getting it working with kernel 6.9 (ONBOARD_USB_HUB to ONBOAD_USB_DEV), however since armbian is on 6.6/6.7, this patch was needed as well: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/usb/misc/onboard_usb_hub.c?h=v6.9-rc3&id=65e62b8a955adebee8634804d8f72599213c2774. Attached is the patch I used to build & run successfully w/ wifi & usb enabled (for current - i haven't tested edge). Make sure you do a kernel config and set ONBOARD_USB_HUB to y - seems like config/kernel/linux-imx6-current.config is significantly different than cache/sources/linux-kernel-worktree/6.6__imx6__armhf/arch/arm/configs/imx_v6_v7_defconfig (attached patch only modifies the kernel work tree) udoo_usb_fix.patch
  4. I come back here every few years to rebuild my UDOO home brew controller.. Seems like USB was disabled around kernel 5.19 (https://github.com/torvalds/linux/commit/8f2ca252ee1f848d3eec9ebbbf3c3881cb423322). Got in touch with Fabio and he gave a super fast response and put two patches in to review. https://lore.kernel.org/linux-arm-kernel/20240401023347.3114484-1-festevam@gmail.com/ https://lore.kernel.org/linux-arm-kernel/20240401023347.3114484-2-festevam@gmail.com/ I'm building it now - might get around to testing tonight, but will probably be a week or so.
