Two Questions: How do I force Armbian/build to rebuild the kernel ? And where does the kernel get cached ?
Two Questions: How do I force Armbian/build to rebuild the kernel ? - Is there a `./compiler.sh` flag ? And where does the kernel get cached ? - Is it cached online ? - is it cached on kernel, kernel version, and kernel config hash ? I am trying to get a proper handle on Armbian/build. BTW: There really needs to be a `kernel` tag on Armbian Forum's - `Create New Topic`.
Radxa Rock 5B+ - Fan not working
@Igor - Can you have a look at this please. I have retrieved the devicetree's for the radxa Debian release on which the fan works and my Armbian Ubuntu build using dtc -I fs /sys/firmware/devicetree/base uname -a lsb_release -a https://github.com/AaronNGray/radxa-rock-5b-plus The 'pwm-fan' nodes are the same.
- Radxa Rock 5B+ - Fan not working
I have the default radxa image rock-5b-plus_bookworm_kde_b2 image with the fan working :- https://github.com/radxa-build/rock-5b-plus/releases/download/rsdk-b2/rock-5b-plus_bookworm_kde_b2.output.img.xz I/We need to try and find how this was built and the Linux DTD file the `uname -a` kernel reports as "Linux rock-5b-plus 6.1.84-1-rk2410" kernel. rsetup :- https://docs.radxa.com/en/rock5/rock5b/getting-started/interface-usage/fan https://github.com/radxa-pkg/rsetup
I am using :- [ Ubuntu 24.04 (Noble)](https://dl.armbian.com/rock-5b-plus/Noble_vendor_server) from :- [Radxa Rock 5B Plus - Armbian](https://www.armbian.com/rock-5b-plus/) Trying to turn fan on on Radxa Rock 5B+ selecting the device using armbian-config actually makes it disappear I am getting `line 3: echo: write error:Device or resource busy`
- /dev/mmcblk1 not there
- Gnome Power off and `sudo shutdown now` both reboot rather than powering down.
[Ubuntu 25.05 Plucky - Armbian-unofficial 25.05.0-trunk] BPi-M7 blank display, gnome version issue
>PLEASE STOP! This is both a time and money nightmare for me. I am giving as much information as I can in order to give feedback in order to get support. What I am posting is not all nonsense ! Okay the Gnome downgrade was incorrect and was based on what ifnformation I could get at the time. Why the issue system put up the postgres tag I really don't know I removed it. It is now repeatedly demostratably kernel dependant. On 6.12.32-current-rockchip64 and 6.12.39-current-rockchip64 the display is failing, 6.12.22-current-rockchip64, and 6.12.17-current-rockchip64 the display is working fine. 6.15.1-edge-rockchip64 is also working fine. No sure about 6.15.7 6.16.0-rc3-edge and 6.16.1-edge are not even booting, with BananaPi-M7. I am going to get kernel output using USB UART for all these boots.
Armbian has become a total nightmare. Things keep breaking and theres no way to get a proper build of a past state anymore, so if I loose a copy of the original image I used for a machine then I am stuck again. Stuck with hardware that will not work again. And this hardware costs a lot of money, and its a lot of time too. Why Armbian was not written with this in mind I really don't know ??? The tree kernel lines supported seem to change randomly and are not in alignment with the linux kernel versions or seem to change randomly just at the wrong times.
- [Ubuntu 25.05 Plucky - Armbian-unofficial 25.05.0-trunk] BPi-M7 blank display, gnome version issue
