jernej
  1. Following fix should solve your boot issue: https://github.com/LibreELEC/LibreELEC.tv/blob/master/projects/Allwinner/patches/u-boot/0010-sunxi-dram-only-probe-DRAM-inside-the-addressable-range.patch I also recently make a lot of mmc driver improvements, which may or may not help with your issue. They primarily target A523, but a lot patches affect common code. Maybe worth testing: https://github.com/LibreELEC/LibreELEC.tv/commit/5d00d15d4883f8647ee988451f413b9e3b555d02
  2. Yes, H616 Cedrus is capable of decoding VP9, but I'm not aware that anyone actually implemented support for it.
  3. Even if this is now more than 10 years old, this is still mandatory read: https://www.cnx-software.com/2013/12/10/most-embedded-gpus-do-not-support-hardware-video-decoding-acceleration-the-vpu-does/ All of these players use Android API, so they don't need to care how HW video decoding is really done. Android is modified in a way to use Cedar core for that. libVA backend isn't maintained and LE doesn't use it. Latest kernel are not supported in that v4l2_request libVA port. For VLC and other players it would be easier to use it, but that's life... There is more than enough information to figure out how this works, but granted, there is also a lot of obsolete information, so you have to figure how things work. Hint, VLC currently won't work with Cedrus.
  4. @Troy H If you want mediacenter distro, you can try LibreELEC with Kodi. It has proper OPi3 LTS support (except wifi), but it might not be to your liking because it's single minded distro - no package manager to install extra software. If you decide to try it, I suggest latest nightly image (mind the date!) until 12.0.2 is out, as it has one important video rendering fix.
  5. LE doesn't use VAAPI as it would be just extra complication where something could go wrong. At the time LE started supporting v4l2_request based drivers, v4l2 wasn't flexible enough to support VAAPI way of memory management, at least not in all cases. Instead, LE uses modified ffmpeg with native v4l2_request support, among some other modifications. Patches are available here. In some cases Kodi also need patches (for example, for HW deinterlacing.) They are right, because Mali GPU has nothing to do with HW video decoding. It can be used for video rendering, but even that is done with DRM planes on LE, which is more performant in most (all?) cases. Allwinner SoCs use Cedrus core for video decoding. LE uses GPU only for GUI rendering.
  6. It has, all H family has 2 mixers. Addresses are hidden in DE BSP source code, but not as absolute address, only as relative. In any case, you don't need second mixer if you won't use any other display output. Note that there is no documentation for DE3.3. There is documentation for DE3 on linux-sunxi.org, which is older, but nevertheless similar core. Still, BSP source code will give you best info, even if it's sometimes hard to understand. In any case, you seem to be on right track to get it working. I strongly suggest that you dump register values of all components involved in pipeline from working BSP solution (most likely Android image) and compare to them to register values dump from your mainline based system. This includes TVE, TCON top and also very importantly, clocks and resets. One extremely useful trick for diagnostics is to use TCON test patterns. Those patterns are directly generated in TCON and then piped to encoder, TVE in this case. It allows you to test TVE without worrying about mixer and if it's properly routed through TCON top. Those test patterns can be enabled by setting TCON register 0x40 to, for example, 1, which will get you well know color check pattern. Note that your solution with TV TOP included in same driver as TVE will work here, but it's not appropriate solution for upstream. TV TOP should be standalone driver like TCON TOP...
  7. If you want Kodi and smooth video playback, you can always check LibreELEC. OPi3-LTS has some bugs, so best build is here, but you can wait for next point release which will be done in about a week. Video playback needs some work in progress software if you want smooth experience, which afaik is not present (yet) in Armbian.
  8. I don't have neither of these boards, but I can help answering any question regarding state of the art drivers in mainline kernel.
