does rockpro64 armbian cli come with non free software?
Armbian_community_26.8.0-trunk.359_Rockpro64_trixie_current_6.18.38_minimal.img.xz If the image installs non free software on the computer can you tell which packages they are and how to remove them from the computer, such that no piece of non free software stays on the computer? In this post free software should be understood as coined by the fsf.org. Thank you.
can libre computer Renegade Elite ROC-RK3399-PC run entirely on free software?
https://libre.computer/products/roc-rk3399-pc/ Can the computer run entirely on free software which is software you can use, share, modify and redistribute? The question includes firmware, microcode, etc, any piece of software that is running on the computer. If some devices on the computer requires non free software in order to work then what devices are they? And will the computer still work if you choose to not install the pieces of non free software in question? Thank you.
does the olimex a20-olinuxino-lime2 armbian image contain and install non free software?
https://www.armbian.com/olimex-lime-2/ Does the image come with and install non free software on the computer? If so is there documentation showing how to do a fully free software installation of the Armbian_community_25.11.0-trunk.546_Lime2_trixie_current_6.12.58_minimal.img image? Free software is software you can use, share, modify and redistribute. Thank you.
- what can you tell about the non free software bl30 blob?
can le potato run entirely on free software?
https://www.loverpi.com/collections/le-potato It says open-source support. Free software is software you may use, share, modify and redistribute. Can le potato run entirely on free software, such that there is no piece of non free software on the computer? If so are the armbian le potato images free software images? https://www.armbian.com/lepotato/ Thank you.
renky
