cemzafer
  1. Thanks @Werner for the clarification. Regards.
  2. I have tried ./compile.sh script and find the Turing RK1 model, but in this configuration it does not contain NPU driver. Do you have any idea how to enable NPU option to compile the newer image? Regards.
  3. Thanks @laibsch, that is wonderful. Appreciate your help. Regards.
  4. Hi, I'm looking a newer armbian iso image which contains those futures. Is there any link? I'm going to test on Turing RK1 (RK3588) machine. Regards.
  5. Thanks, I will try that. Regards.
  6. Thanks for the reply. My Armbian version is as follows, PRETTY_NAME="Armbian 25.8.0-trunk.463 bookworm" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.8.0-trunk.463 bookworm" armbian@turing-rk1:~$ uname -a Linux turing-rk1 6.1.115-vendor-rk35xx #1 SMP Tue Jul 29 08:14:49 UTC 2025 aarch64 GNU/Linux So in this kernel, everything works as expected except vm problem. And one of a forum stated that this problem occurs because of kernel, so I upgraded the kernel with using armbian-config. My kernel changed to 6.12.41, now qemu vm works as normal without a hitch. But when I upgrade the kernel now I lost the NPU device, the new kernel does not recognize the NPU processor. Briefly with old kernel everything works not qemu vm, with new kernel qemu vm works but not NPU support. Any idea how to compile RK3588 NPU driver? Or alternative idea? Regards.
  7. Thanks for the reply @eselarm, I did not catch up the posted link, that means you upgraded your kernel. As in the posted email you have mentioned following message. So in my case on a NanoPi-R6C, that I just did upgrade, so got kernels: -rw-r--r-- 1 root root 33792512 Dec 5 18:28 vmlinuz-6.12.2-current-rockchip-rk3588 -rw-r--r-- 1 root root 39705088 Dec 1 18:38 vmlinuz-6.1.84-vendor-rk35xx Where can I find those kernel deb packages? Can you share the link/links? Regards.
  8. Hi, I'm using RK1 compute module and I get this error message "qemu-system-aarch64: Failed to put registers after init: Invalid argument" while creating a vm on incus. Can I upgrade a newer kernel 6.10 or later on this compute module? Regards.
