Skip to content
View in the app
Armbian Community Forums
RK3399 image through usb c
Featured Replies
Hello, I have an Orange Pi RK3399 and I'm very interested to install an armbian linux using the usb c instead of the usual method with the sd card. I have looked around but I was able to do it. Do you have any suggestions?
Thank you very much for your help
  • Author
16 minutes ago, martinayotte said:
Why ? The SDCard method still the simpliest ...
I understand that in normal cases it is the best, but if I need to flash multiple devices it becomes bothersome and personally I find difficult to bridge the pads to boot from the SD. I know that I may not make sense but I would really like to make the other solution work (or an alternative one)
This is true for the first installation, but once you have a Armbian U-Boot installed, simply stop u-boot before it boot the eMMC, and use "setenv devnum <x>", where "<x>" is the SDCard index, and then "run mmc_boot"
For USB-C, I don't think there is an easy way ...
  • Author
If theres a way that is hard the first time (for example that making the files is not that easy) but after that it's easy then i'm happy with it. I take it also as a personal challenge and a way to learn.
Thank you for your explanation.
  • Author
Would it be possible to do something similar to this post of the firefly with the orange pi and with armbian instead of ubuntu? Like for example change the uboot, kernel and rootfs images for armbian ones and get from somewhere the dtb file for the orange pi?
This is exactly what our build script does. For many years. But we don't deal with/support proprietary Rockchip tools http://wiki.t-firefly.com/en/ROC-RK3399-PC/upgrade_firmware_emmc.html for flashing ... which actually might even work. I successfully flashed Armbian image directly (via USB) to emmc to some older Rockchip hardware like https://www.armbian.com/z28-pro/ or https://www.armbian.com/miqi/
I assume it with this board it should go the same / similar but it is on you to try that.
We already provide proper (ofc not fully finished/polished) DTB for Orangepi RK3399 by default.
  • Author
Hi thank you very much for your answer. I'm not very experienced but I'll see what I can manage with what you just told me.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
