Skip to content
View in the app
Armbian Community Forums
[Odroid C2] Big load average
Featured Replies
I just switch from hummingboard i4 to odroid c2 (same os, armbian, same app on it), all it's ok but I got an issue with load average, on i4 I have about 0.4 but on C2 I have 3 and I don't understand why. Here a vmstat from C2 :
procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
 0  0      0 891036  74724 277404    0    0     0     0  310  493  3  2 95  0  0
 1  0      0 891004  74724 277404    0    0     0     0 18272 1863  0  2 98  0  0
 0  0      0 891036  74724 277404    0    0     0     0 18205 1950  4  0 96  0  0
 1  0      0 891036  74724 277404    0    0     0     0 18412 1728  0  2 98  0  0
 0  0      0 891036  74732 277404    0    0     0     0 18090 1851  0  0 100  0  0
 1  0      0 891160  74732 277404    0    0     0     0 19303 2400  7  1 92  0  0
 0  0      0 891160  74732 277404    0    0     0     0 17993 1654  0  0 100  0  0
 2  0      0 891144  74732 277404    0    0     0     0 18178 1733  0  3 97  0  0
 1  0      0 891160  74732 277404    0    0     0     0 18027 1765  0  0 100  0  0
 2  0      0 891144  74732 277404    0    0     0     0 18147 1681  0  0 100  0  0
I find interrupt is very very high, did anyone also notice that ?
Thank in advance.
  • Author
It's with this patch :
vmstat 1 10
 0  0      0 248012 135536 767836    0    0     0     0  156  124  2  2 96  0  0
 2  0      0 247996 135536 767836    0    0     0     0 17899 1680  0  0 100  0  0
 1  0      0 247996 135536 767836    0    0     0     0 19032 2256  4  3 93  0  0
 2  0      0 247872 135536 767836    0    0     0     0 18447 1802  1  1 98  0  0
 0  0      0 247872 135536 767836    0    0     0     0 18285 1682  0  2 98  0  0
 2  0      0 247872 135536 767836    0    0     0     0 18222 1787  0  0 100  0  0
 1  0      0 247888 135536 767836    0    0     0     0 18424 1727  0  2 98  0  0
 0  0      0 247856 135536 767836    0    0     0     0 18214 1765  0  0 100  0  0
 1  0      0 247872 135536 767836    0    0     0     0 19268 2347  7  2 92  0  0
 4  0      0 247904 135536 767836    0    0     0     0 18458 2092  5  1 94  0  0
w :
08:43:18 up 16:58,  1 user,  load average: 2.57, 2.90, 2.88
USER     TTY      FROM             LOGIN@   IDLE   JCPU   PCPU WHAT
root     pts/0    192.168.0.90     08:38    0.00s  0.88s  0.03s w
cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
 25:          0          0          0          0       GIC  25  vgic
 27:          0          0          0          0       GIC  27  kvm guest timer
 29:          0          0          0          0       GIC  29  arch_timer
 30:    6112600    6112592    6112590    6112588       GIC  30  arch_timer
 35:    3667454          0          0          0       GIC  35  osd_vsync, vsync
 38:    6110623          0          0          0       GIC  38  timerC
 40:          0    2886805          0          0       GIC  40  eth0
 58:          0          0          0          0       GIC  58  meson_uart
 62:          0          0          0          0       GIC  62  dwc_otg, dwc_otg_hcd:usb2, dwc_otg_pcd
 63:      51309          0          0 1052167849       GIC  63  dwc_otg, dwc_otg_hcd:usb1
 78:          0          0          0          0       GIC  78  deinterlace
 89:          0          0          0          0       GIC  89  hdmitx
 99:          1          0          0          0       GIC  99  sd_emmc_mmc_in
101:          0          0          0          0       GIC 101  sd_emmc_mmc_out
121:    3667453          0          0          0       GIC 121  rdma, osd_rdma
182:          0          0          0          0       GIC 182  ge2d
225:          0          0          0          0       GIC 225  meson_uart
228:        711          0          0          0       GIC 228  ir-meson
231:          0          0          0          0       GIC 231  hdmi_aocec
241:      61204          0          0          0       GIC 241
242:     303053          0          0          0       GIC 242
249:          0          0          0          0       GIC 249  sd_emmc
250:       2084          0     386891          0       GIC 250  sd_emmc
IPI0:   4529837    4308917    5296590    3292367       Rescheduling interrupts
IPI1:         7         12         13         15       Function call interrupts
IPI2:         0          4          4          4       Single function call interrupts
IPI3:         0          0          0          0       CPU stop interrupts
IPI4:         0          0          0          0       Timer broadcast interrupts
IPI5:    204820     314482     235567     202304       IRQ work interrupts
Err:          0
Thx for the answer. Well with an uptime of 17 minutes that's over one million USB IRQs per second? You might check the output of 'sudo armbianmonitor -u' for possible reasons (can't say that much whether that's normal or not since I don't have a C2)
  • Author
I just make some more test, I install dietpi distribution with same software on it (but without data), load average :
- 0 at 0.01 on dietpi
- 0.24 on armbian
Here vmstat on dietpi :
 0  0      0 1496312  10760  90428    0    0    14     8 2151  169  1  1 98  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8513  491  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8487  473  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8489  475  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8488  473  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8491  479  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8515  479  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8491  475  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8503  474  0  0 100  0  0
 0  0      0 1496188  10760  90428    0    0     0     0 8493  480  0  0 100  0  0
And /proc/interrupts :
           CPU0       CPU1       CPU2       CPU3
 35:      20098          0          0          0       GIC  35  osd_vsync, vsync
 38:      40174          0          0          0       GIC  38  timerC
 40:        155        371          0          0       GIC  40  eth0
 63:     748497          0          0    2460326       GIC  63  dwc_otg, dwc_otg_hcd:usb1
 92:      79391          0          0          0       GIC  92  MESON TIMER-F
 93:          0      13733          0          0       GIC  93  MESON TIMER-G
 94:          0          0      14402          0       GIC  94  MESON TIMER-H
 95:          0          0          0       7794       GIC  95  MESON TIMER-I
121:      20097          0          0          0       GIC 121  rdma, osd_rdma
192:          0          0          0          0       GIC 192  Mali_GP
193:          0          0          0          0       GIC 193  Mali_GP_MMU
194:          0          0          0          0       GIC 194  Mali_PP_Broadcast
196:          0          0          0          0       GIC 196  Mali_PP0
197:          0          0          0          0       GIC 197  Mali_PP0_MMU
198:          0          0          0          0       GIC 198  Mali_PP1
199:          0          0          0          0       GIC 199  Mali_PP1_MMU
200:          0          0          0          0       GIC 200  Mali_PP2
201:          0          0          0          0       GIC 201  Mali_PP2_MMU
231:          3          0          0          0       GIC 231  hdmi_aocec
241:        407          0          0          0       GIC 241
242:          3          0          0          0       GIC 242
250:       3544          0        478          0       GIC 250  sd_emmc
IPI0:      2613       3400       8795       3609       Rescheduling interrupts
IPI1:         8          7         10         10       Function call interrupts
IPI2:         1          2          5          1       Single function call interrupts
IPI5:       180        102        253        175       IRQ work interrupts
I force on dietpi the same interrupt affinity like armbian (after boot).
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
