Skip to content
View in the app
Armbian Community Forums
No Sound on NanoPI M1
Featured Replies
I've recently acquired some nanoPi M1, and just about now installed ARMBIAN. However I can't seem to get any sound working via 3.5 analog jack.
Volume is set right on alsamixer
Speaker are working and volume is set at max
Soundcard is listed
but yet I have absolutely no sound ... any ideas ?
root@user:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: audiocodec [audiocodec], device 0: SUNXI-CODEC sndcodec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
  Subdevices: 1/1
root@user:~# cat /proc/asound/cards
 0 [audiocodec     ]: audiocodec - audiocodec
                      audiocodec
 1 [sndhdmi        ]: sndhdmi - sndhdmi
                      sndhdmi
root@user:~# aplay  /usr/share/sounds/alsa/Noise.wav
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
I assume you are using legacy kernel, I have the same issue.
asoc: sndcodec <-> sunxi-codec mapping ok
[    1.622219] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.622593] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.622624] [DAUDIO0] driver not init,just return.
[    1.628874] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.679706] ALSA device list:
[    1.679722]   #0: audiocodec
[    1.679736]   #1: sndhdmi
let's see if sound work with hdmi
It looks as an interesting alternative to the orange PI one
http://www.friendlyarm.com/index.php?route=product/product&product_id=109
Regarding available connectors it's more like OPi PC, size of DRAM is your choice and you should keep in mind that NanoPi M1 uses the more primitive voltage regulator known from One/Lite and unfortunately shows also strange overheating behaviour compared to the various Oranges (almost as bad as the worst H3 device in this area: BPi M2+). But fortunately FriendlyARM just recently reduced shipping costs from $10 to $5 :)
http://forum.armbian.com/index.php/topic/1015-nanopi-m1/ (info that's missing there is that you can power the board also through the 4 pin header next to the 40 pin GPIO header)
Thanks for the link I missed it .
Yes that is mainly the connectors that I like.
Having most of them ,RJ45,HDMI,USB  on the same side of the board simplifies the design
of a decent box.
Cooling of the CPU is another drawback of most of those boards.
IMHO it would be much easier if the CPU was on the other side of the board.
Good night, I have the sound problem but with hdmi audio, de default is the 3.5 mm audio jack, then I looked for the asound.conf in /etc, then I found that this file doesn't exist and after that I've created it with the following content:
pcm.!default {
    type hw
    card 1
    device 0
ctl.!default {
    type hw
    card 1
the problem is that even created this way the sound output still being the 3.5 mm jack and I don't know if I need to change some setting to mpv player to output the sound through hdmi.
What else can I do to change the sound from audio jack to hdmi?
Edited by vr@m
forgot to write something
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
