Skip to content
View in the app
Armbian Community Forums
[SOLVED] Amlogic S905 boxes
Featured Replies
I got couple of Amlogic S905 and S905x boxes.  And i think i've used at least a 7-8 hours to see if i can get these to work again.
I tried to use the lastest images with S905 boxes, and it is has been a real hassle to get it working. Some times i had to hook up an USB disk in addition to get it to boot the rootfs.  And when i finally get into the OS, the network won't work. Both the built in Ethernet port and an USB Ethernet adapter. Both can detect a link, but unable to to receive IP from DHCP nor is it possible when manually assigned to get it to ping the GW.
Is support for such devices by @balbes150still something that he still does?
balbes150 not supporting Amlogic boxes going forward, but the current builds available should still work.  What dtb's have you tried?  What build are you using? And could you post the contents of your extlinux.conf file?  Also since there dozens of different s905/s905x boxes, each being different a little more information would be helpful.  You really have provided no information for anyone to be able to help you.
  • Author
Thank a lot for your reply. And i apologize for not providing enough details.
I figured out by now that the issue was completely on my side. One of the switch port wasn't working hence not forwarding Ethernet packets to the gateway :(
Now i have one of the boxes, an MX Plus with S905, working with 1Gbit network.
@SteeMan thanks again!
  • fossxplorer changed the title to [SOLVED] Amlogic S905 boxes
Ok, GREAT!.... Exactly what I was saying on the thread I started... There's no info. it's incomplete, stuff is not mentioned...
If you don't say this I would never find he is not enabling Amlogic even though he speaks about them on his latest instructions. (or what I can find and seems latest)
Dear friends! I have an android TV box on Amlogic S905 4x ARM Cortex-A53. On the site I cannot find a suitable firmware for my device, can someone help me?
  • SteeMan locked this topic
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
