Skip to content
View in the app
Armbian Community Forums
Scishion v88 4k doesn't start up after reboot
Featured Replies
Hi there, first of all big thanks to this community, what you're doing is awesome :-)
Here is my question:
I have Scishion v88 4k TV box, it had android 7
I've installed Armbian Buster legacy kernel 4.4.y on nand
Configured network, rn it has OctoPrint, Klipper, working webcam etc. No questions, its all working great.
But whenever I try to reboot it, it doesn't start up back, I gotta replug the power supply for a few sec, only then it starts up back.
While it was on Android, it did the reboot correctly.
Maybe it's something about exactly this model of tv box that does not let it to reboot on its own, it doesn't have an on\off buttons, so whenever I use it, I have to manually plug in the power supply and when I shut it down, manually unplug it.
I think in the future I would use wifi smart socket for it, but I was wondering, if I could do anything about it using armbian configs or something.
Should I upload logs or something? Which ones?)
As far as I'm concerned, this is the specification of this board:
Model: V88
Type: TV Box
GPU: Mali-400
System: Android 5.1
CPU: RK3229
Core: 1.5GHz,Quad Core
RAM: 1G
ROM: 8G
Max. Extended Capacity: 16G
Color: Black
Decoder Format: H.264,H.265
Video format: 4K,AVI,DAT,MKV,MOV,MPEG,MPG,RM,VC-1,WMV
Audio format: AAC,FLAC,MP3,OGG,RM,WMA
Photo Format: JPEG,JPG,PNG
Support XBMC: Yes
Power Supply: Charge Adapter
Interface: AV,DC Power Port,HDMI,RJ45,SD Card Slot,SPDIF,USB2.0
Language: Multi-language
System Bit: 32Bit
Firmware Version: Android 5.1
Power Type: External Power Adapter Mode
Power Input Vol: 5V
Power Adapter Output: 5V 2A
Here are few photos of this board:
https://disk.yandex.ru/a/ohSrg-TeCuj_dQ (couldn't insert it by standard "insert image from URL", sorry
Thanks a lot.
Edited by Vilok Lokhovskih
Hello.
Unfortunately NAND-based boards have this issue about rebooting. It is common among most of them and still could not sort it out.
Curiously using the mainline 5.10 kernel my NAND board reboots ok, but of course NAND is not accessible because the kernel driver is still missing.
  • Author
5 hours ago, jock said:
Hello.
Oh, okay then, thanks for the answer anyway
It's not a big deal, I was just thinking, maybe I did something wrong and could fix it software-wise.
No more questions then :-) Thanks
  • SteeMan locked this topic
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
