Skip to content
View in the app
Armbian Community Forums
Converting file to ISO
Featured Replies
I'm trying to figure out how to convert the img.xz file into a usable ISO file to boot onto a USB drive. I have no idea, tried using a few converter tools and they don't seem to be doing the job. Anyone know of a way to accomplish this? Thank you.
Solved by usual user
  • Author
@Werner I don't have a micro sd slot on any of my devices to directly download a distro to. In the case of the Orange Pi 4, dzo you know if I could download it to the Android OS on the device and then write it to the micro sd card on there?
What do you think the one marked with the red circle is?
Show me the how the CD ROM is attached to run an ISO.
  • Author
@usual user My question was regarding the possibility of downloading armbian via the Orange Pi to the SD Card. I have spent hours trying to configure anything on the Orange Pi 4 via the Android OS downloaded on the EMMC, but I can't get any of it to work. The only device I have that has a SD or Micro SD Card is the Orange Pi 4. So either I use USB to flash the EMMC or Micro SD card through the Orange Pi, or it's stuck with Android until I can acquire a completely separate device that has Micro SD/SD card reader.
  • Solution
I don't know Android and can't therefor help here, but I'm sure an experienced Android user can also use it to transfer an image to an sd card. However, if you are able to write an image to a USB flash drive, use a micro SD to USB adapter with a device whose system you are familiar with to write to an SD card. It is then the same procedure that you already know.
Edited by usual user
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
