Geoffrey F4FXL
  1. Same here, but on Orange Pi Zero (Allwinner)
  2. @Issou thanks for the feedback, I eventually got my hands on the Orange Pi zro I had in a remote location, I will make a fresh install and see how it behaves.
  3. Maybe are you experiencing the same issue ? https://forum.armbian.com/topic/56946-h3-reboot-issue/
  4. Today I needed to reboot one of the Orange Pi which is at a remote location.... It did not come back to life.... Maybe some update removed the extraargs=reboot=warm parameter ....
  5. Update, this is also working .... extraargs=reboot=watchdog UPDATE: It stopped working after 3 successful reboots...
  6. The thing is that I need it on different boards .... Tried Armbian Trixie and Ubuntu based, same issue thus it might be uoot and/or kernel related. Thanks for your help though.
  7. Here is the output: U-Boot SPL 2024.01_armbian-2024.01-S866c-P6b16-Ha5c2-V7d7d-Bbf55-R448a (Dec 22 2025 - 03:39:51 +0000) Note that prior to this I tried to update uboot through armbian-install, it did not change anything to my reboot issue.
  8. Ooops, you are right I meant /boot/armbianEnv.txt, I edited the topic to correct. The output of armbianmonitor -u can be found here: https://paste.armbian.com/foyunagisu What should I look for?
  9. Hi All, I have a couple of H3 based boards (Orange Pi Zero and FriendlyArm NanoPi Duo 2). With all of them I have the same issue: command like "reboot" turn the board off instead of rebooting. The workaround is to add following line in /boot/armbianEnv.txt extraargs=reboot=warm Running latest image on all of the boards.
  10. Ok, fair enough, but all the mirros all seem empty, regardless of board type....
  11. Hi All, It seems like all boards are missing current images, at least on the mirrors I checked.... @Werner even in the links you are mentioning, only the archive folder has older images.
  12. Submitted the PR: https://github.com/armbian/build/pull/8882
  13. Hi, I am quite familiar with github, I'll submit a PR asap.
  14. Hi all, I got my hands on an Odroid XU4 and wanted to use it as a replacement for my RPi 3 for all my amateur radio related stuff. Unfortunately all of the AX25 kernelmodules have been left out of official builds. I have a commit ready to add them back, yet I am not sure what the actual process is to submit a PR. As I understood I need to open an issue first yet I cannot figure out which category this fits in. I attached a patch file for current kernel. Thank You, Geoffrey ax25.patch
