February 14, 20233 yr Lastest current kernel Bullseye image for Renegade, first-boot, then reboot, ssh.service won't active. Problem is 'Missing privilege separation directory: /run/sshd', creat by manul then start the service will make it active. But after a reboot it will need to done again. Purge and install openssh-server will fix it. Reinstall won't work. Remember do this before install other package which depend on openssh-server. https://paste.armbian.com/qoxebajifu
February 14, 20233 yr Can you check if those images behaves better https://stpete-mirror.armbian.com/dl/renegade/rc/
February 14, 20233 yr Author Quote https://stpete-mirror.armbian.com/dl/renegade/rc/Armbian_23.02.1_Renegade_bullseye_current_5.15.93.img.xz has been tested, ssh.service inactive too.
February 14, 20233 yr Tried with another device (Opi 3 LTS with similar kernel, same user land) and can't reproduce. https://paste.armbian.com/facogodope I don't have Renegade - @TonyMac32 any clues if HW would played any role in this?
