TonyMac32
Moderators
  1. Let's say the world has been extra certain to bring me IRL problems 😄, as far as a bootloader being present, the Libre Computer Tritium boards are as barebones as can be possible, so any issues should be shared across any/all other H5 boards and really not board specific.
  2. LMAO at marking tagging me "Solution" In any case, I completely forgot about This complete catastrophe. I'll make an entry for Sweet Potato, but probably more like it is to simple check for family = meson-gxl, OR *gasp* put it in the individual board configs to avoid bloating the build systems common entities. Family configs are the stuff nightmares are made of. - https://github.com/armbian/build/pull/7668
  3. You don't have any "dumb" power supplies? Any USB-type -C style charger will limit to 450 or 900 mA without a "smart" device attached to it, irrespective of it's rating. (it requires a matched supply/cable/endpoint configuration to get 5V 1.5 or 3 A) *Most* QC- compatible (USB A output) will also limit the current unless they detect the correct QC-style resistances on the endpoint. You wouldn't happen to have a USB power meter on hand to see if these supplies are throttling the USB-A based on the fact the device has no "smart" charging built into it? I just measured mine and with keyboard, HDMI and network attached I broke 600 mA peak. If the supply had throttled to 450 mA it would have crashed right after loading the kernel. Otherwise I think you need to talk to LC and see if they can debug the issue you're having.
  4. I flashed my image to USB stick using balena Etcher, so I skipped half the steps (extracting/etc). Since I'm an EE and I'm running out of ideas, can you humor me with the exact specs of your power supply.
  5. hmm. Mine is a 1.0A, although I don't think there's any real difference (I don't have a switch for selecting boot mode). Do you have an eMMC installed?
  6. ok, so next step, you say you wrote to an SD card, since there's no SD slot on this board, are you attaching it through an SD --> USB adapter?
  7. 🫣 Let me take a look. [EDIT] So far I don't see an issue, I booted an image with no errors on my La Frite (1 GB). My guess is, you have old firmware on the board itself. The Armbian download page fir la frite includes instructions on how to update the spiflash with Libre Computers most recent binary.
  8. Eh, it's a logic that can't be properly managed. The XU4 and Tinkerboard (both armhf) have GPU's that run circles around RK3328, S905(X), H5, etc. I'd say leave it alone, after all the experience should be up to the user anyway. Because then you also need to start talking about RAM, and it just gets out of control.
  9. And it's running the wrong race if you're trying to get fancy with desktop environments. The current 6.6 also works just fine, no HDMI issues with Cinnamon.
  10. Sorry I didn't notice this post earlier, notifications get buried fast 👀. I haven't tested cinnamon on anything with a Mali450, TBH that GPU just isn't up to doing anything useful since it's target audience was 720p devices. That's not to say it *can't*, I just didn't expect anyone *would*. All of my tests have been with xfce and have been fine. Let me do a quick Cinnamon build (is this a download option now?) Rich, or @criageek, needed to provide an armbianmonitor -u or at least a dmesg. [UPDATE]: Built/tested a new 6.12 edge image with cinnamon, worked out of the box with no issues.
  11. sorry I didn't see this, and you had to buy some berry trash instead 😐
  12. unfortunately, in my experience, Samsung *in particular* does not play nice with SBC's
  13. TonyMac32 posted a topic in Off-topic
    Didn't know this thing was ever going to see the light of day: https://www.aliexpress.com/item/Lichee-Pi-Zero-1GHz-Cortex-A7-512Mbit-DDR-Development-Board-Module-Mini-PC/32931418720.html I see the original board outline is still there, but it grew a bit of a waistline A valid question is why, and I'm not sure, nor will I buy it, just thought it interesting that it popped up. With complete kernel support for VDEC/VENC/ camera this is actually somewhat interesting, so maybe some people would like to play with it. I'm sure @Icenowy knows more than is humanly possible about the capabilities and whether it's worth talking about.
