April 3, 20233 yr Hi everyone! I tried to boot both Lunar and Sid and got similar UART-console output: Armbian_23.05.0-trunk-e33842ef2_Mangopi-mq_lunar_edge_6.1.0-rc3.boot.log I noticed that "/boot/dtb/allwinner/sun20i-d1-nezha.dtb" is wrong choise, found it in extlinux.conf and changed it like this(hope commenting out strings works here): label Armbian kernel /boot/Image initrd /boot/uInitrd # fdt /boot/dtb/allwinner/sun20i-d1-nezha.dtb fdt /boot/dtb/allwinner/sun20i-d1-mangopi-mq-pro.dtb append root=UUID=5e7413f7-b308-4843-b9a9-063d99cb1700 console=ttyS0,115200n8 console=tty0 earlycon=sbi cma=96M rootflags=data=writeback stmmaceth=chain_mode:1 rw rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles the result was like this(this is just a tail of log): lunar_edge_tail.log Am I on the right path?
April 4, 20233 yr >>Retrieving file: /boot/extlinux/pxelinux.cf_eth_start: Timeout MangoPi-MQ-Pro board does not have ethernet controller, but it seems OS try to initialize this (unexisting) device. Probably you need to change your image build configuration, to exclude ethernet device? Regards, Vladimir
April 4, 20233 yr 15 часов назад, n0153 сказал: everyone! I tried to boot both Lunar and Sid and got similar UART-console output: Where are these images taken from ?
April 4, 20233 yr Author Quote MangoPi-MQ-Pro board does not have ethernet controller, but it seems OS try to initialize this (unexisting) device. Probably you need to change your image build configuration, to exclude ethernet device? Failover like this is typical for many platforms, it tries PXE after more usual options failed, which also visible in this log. For example it tries USB above, some other lines are also look like unsuccessful attempts to boot from different medias. I didn't build image myself, I took it from the location below. Do you think that building is preferable? Quote Where are these images taken from ? from this location: https://www.armbian.com/mangopi-mq-pro/
May 13, 20233 yr The images on the download page are broken and do not boot past U-Boot phase, last functioning one comes from February. There is a new maintainer for the board, hopefully we will get a functioning version soon. I can help with testing and debugging if there is such need. By the way, /usr/lib and /lib are EMPTY in the images, I've tested 3, so something is seriously broken? Edited May 13, 20233 yr by riscvboy
May 28, 20233 yr just tested the latest available build for mangopi-mq-pro, 26 May 2023 (from there: https://github.com/armbian-beta/os/releases/download/23.5.0-trunk.275/Armbian_23.5.0-trunk.275_Mangopi-mq_lunar_edge_6.1.0-rc3.img.xz), boot process still stop at the same stage: Retrieving file: /boot/extlinux/pxelinux.cfg/default sun8i_emac_eth_start: Timeout Config file not found sun8i_emac_eth_start: Timeout sun8i_emac_eth_start: Timeout => Edited May 28, 20233 yr by Vladimir Dudnik
June 9, 20233 yr I also have a Mango Pi MQ Pro. I spent several hours attempting to figure out if I had a bad SD card or what. Just found this post and have the same problem. What image can I download that still works. Attempting to find a pre-built one from February seems to be a problem, can someone give me a link to the *.img file I need? Thanks, Mark
September 15, 20233 yr I have the same issue. .. all images on 6.0 kernel are broken only the ones on 5.19 are working. Even the oficial ubuntu server riscv doesnt boots on me ...
