Celona
  1. I have Mango MQ Pro, Nezha and VisionFive2 boards and the solution for this RISC-V board was really simple, I installed Ubuntu Server and I'm happy with it, I just had to remove some unnecessary features, like DietPi does with Armbian. It is not mandatory to find excuses. https://ubuntu.com/download/risc-v
  2. I've now resigned myself to the fact that using Raxda's SBCs requires external adapters, they are not able to provide even a minimal working system, as their latest Debian image demonstrates: https://github.com/radxa-build/rock-3c/releases/tag/b43. So yours don't work either, or am I doing something wrong? ____ _ _____ ____ | _ \ ___ ___| | __ |___ / / ___| | |_) / _ \ / __| |/ / |_ \| | | _ < (_) | (__| < ___) | |___ |_| \_\___/ \___|_|\_\ |____/ \____| Welcome to Armbian_community 24.11.0-trunk.4 Bookworm with Linux 6.6.47-current-rockchip64 No end-user support: untested automated build System load: 21% Up time: 0 min Memory usage: 5% of 1.93G IP: 192.168.1.163 CPU temp: 63°C Usage of /: 6% of 29G uname -a Linux rock2g 6.6.47-current-rockchip64 #1 SMP PREEMPT Mon Aug 19 04:04:32 UTC 2024 aarch64 GNU/Linux sudo dmesg -l 0,1,2,3 [ 11.942338] of_dma_request_slave_channel: dma-names property of node '/serial@fe650000' missing or empty [ 14.090200] Bluetooth: hci0: command 0x0c03 tx timeout [ 14.090306] Bluetooth: hci0: BCM: Reset failed (-110) ip a | grep "inet " inet 127.0.0.1/8 scope host lo inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether a6:a2:b0:36:4d:8f brd ff:ff:ff:ff:ff:ff inet6 2a01:e11:1400:5d0:6bf9:d83d:a987:dc3f/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 85098sec inet6 2a01:e11:1400:5d0:a4a2:b0ff:fe36:4d8f/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::a4a2:b0ff:fe36:4d8f/64 scope link valid_lft forever preferred_lft forever 3: enxb88d1254cda3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether b8:8d:12:54:cd:a3 brd ff:ff:ff:ff:ff:ff inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 valid_lft 41689sec preferred_lft 41689sec inet6 fd8c:df22:1b60:a94b:8d64:46a6:bfb8:62b8/64 scope global temporary deprecated dynamic valid_lft 475sec preferred_lft 0sec inet6 fd8c:df22:1b60:a94b:ba8d:12ff:fe54:cda3/64 scope global deprecated dynamic mngtmpaddr noprefixroute valid_lft 475sec preferred_lft 0sec inet6 2a01:e11:1400:5d0:f759:2829:fa0b:ad4e/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 84745sec inet6 2a01:e11:1400:5d0:ba8d:12ff:fe54:cda3/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::ba8d:12ff:fe54:cda3/64 scope link valid_lft forever preferred_lft forever sudo dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 4.039090] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 4.042387] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 4.042420] rk_gmac-dwmac fe010000.ethernet: TX delay(0x47). [ 4.042435] rk_gmac-dwmac fe010000.ethernet: RX delay(0x27). [ 4.042461] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 4.042527] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 4.050680] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 4.055059] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.055098] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 4.055113] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 4.055123] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 4.055133] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 4.055142] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 4.055276] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 4.055291] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.055305] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 4.055319] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 4.055331] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.302372] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.656403] asix 6-1:1.0 eth0: register 'asix' at usb-fd880000.usb-1, ASIX AX88772 USB 2.0 Ethernet, b8:8d:12:54:cd:a3 [ 4.664025] asix 6-1:1.0 enxb88d1254cda3: renamed from eth0 [ 11.660738] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.758203] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 11.768291] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found [ 11.768322] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported [ 11.768670] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock [ 11.769109] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode [ 673.250279] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx Module Size Used by lz4hc 12288 0 lz4 12288 0 zram 32768 3 binfmt_misc 20480 1 nls_iso8859_1 12288 1 hci_uart 135168 0 hantro_vpu 249856 0 v4l2_vp9 20480 1 hantro_vpu rockchip_rga 20480 0 btqca 20480 1 hci_uart videobuf2_dma_contig 20480 1 hantro_vpu btrtl 28672 1 hci_uart snd_soc_simple_card 20480 0 snd_soc_rk817 40960 1 snd_soc_hdmi_codec 20480 1 v4l2_h264 16384 1 hantro_vpu snd_soc_rockchip_i2s_tdm 20480 4 v4l2_mem2mem 24576 2 hantro_vpu,rockchip_rga videobuf2_dma_sg 16384 1 rockchip_rga btintel 40960 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card snd_soc_core 208896 5 snd_soc_rockchip_i2s_tdm,snd_soc_hdmi_codec,snd_soc_rk817,snd_soc_simple_card_utils,snd_soc_simple_card videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_dma_sg btbcm 20480 1 hci_uart videobuf2_v4l2 20480 3 hantro_vpu,rockchip_rga,v4l2_mem2mem pwm_fan 20480 0 snd_compress 24576 1 snd_soc_core bluetooth 663552 6 btrtl,btqca,btintel,hci_uart,btbcm videodev 229376 4 videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem panfrost 69632 0 snd_pcm_dmaengine 12288 1 snd_soc_core display_connector 16384 0 rk_crypto2 36864 0 snd_pcm 106496 5 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine videobuf2_common 49152 7 videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops gpu_sched 36864 1 panfrost snd_timer 36864 1 snd_pcm dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 mc 53248 5 videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem drm_shmem_helper 16384 1 panfrost sm3_generic 12288 1 rk_crypto2 snd 77824 5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm sm3 20480 1 sm3_generic at24 20480 0 rk817_charger 20480 0 soundcore 12288 1 snd apple_mfi_fastcharge 16384 0 cpufreq_dt 16384 0 cfg80211 802816 0 rfkill 24576 3 bluetooth,cfg80211 dm_mod 126976 0 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 40960 2 ax88796b 12288 1 realtek 32768 1 spi_rockchip_sfc 16384 0 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 233472 3 stmmac_platform,dwmac_rk pcs_xpcs 20480 1 stmmac asix 49152 0 usbnet 40960 1 asix
  3. At this moment fails on ARM Cortex-A53 and Cortex-A55, works on RISC-V 64. wget https://downloads.xiph.org/releases/opus/opus-1.5.1.tar.gz tar -xf opus-1.5.1.tar.gz cd opus-1.5.1 sudo apt install autoconf automake libtool gcc make ./configure sudo make install This version brings non-marginal improvements for spoken content at low bitrate.
  4. IngwiePhoenix, you are welcome!
