Skip to content
View in the app
Armbian Community Forums
Featured Replies
Hi everyone!
I have only recently started to get into Linux. I am not very knowledgeable about Linux on ARM.
I was able to run ARMBIANv0.7BETA MMC on H96 MAX V56 RK3566 8G/64G.
The link is to the files:
https://drive.google.com/file/d/1h5O4c8MHqw1bvxvJMdfFE1KJrq8vpXhT/view?usp=drive_link
ARMBIANv0.7BETA MMC was taken as a basis. I also needed an Armbian image from the Orange Pi 3B board.
What I did:
1. MiniLoaderAll.bin and U-boot are taken from Armbian image from Orange Pi 3B board.
2. The /boot directory was moved to a separate bootfs partition.
3. Rename  file /boot/extlinux/extlinux.conf.bak in extlinux.conf.bak
4. In /boot directory boot.cmd and boot.scr files were created with the following contents
setenv docker_optimizations "on"
setenv bootlogo "false"
echo "Boot script loaded from ${devtype} ${devnum}"
if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1"; fi
if test "${bootlogo}" = "true"; then
        setenv consoleargs "splash plymouth.ignore-serial-consoles ${consoleargs}"
else
        setenv consoleargs "splash=verbose ${consoleargs}"
fi
part uuid mmc 1:2 partuuid
setenv bootargs   androidboot.console=ttyFIQ0 root=PARTUUID=${partuuid} rootwait  rw rootfstype=ext4 ${consoleargs}   no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash p>
load mmc 1:1 0x42000000 Image
load mmc 1:1 0x44000000 dtb/rockchip/rk3566-firefly-roc-pc.dtb
load mmc 1:1 0x46000000 uInitrd
booti 0x42000000 0x46000000 0x44000000
# Recompile with:
# mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
How to install this Armbian:
On Windows OS:
1. Download and unzip the Armbian image
2. 1. Download, unzip and install the software: RKDevTool_Release_v3.15_and_DriverAssitant_v5.12
https://drive.google.com/file/d/14HWcHYHDrgUBFWholrDCKUWDPHw1r4F1/view?usp=drive_link
3. Run RKDevTool. Right-click in the partition list window (1). Select "Load Config". Open Armbin.cfg file from Armbian_xfce_v.0.7_MMC_8Gb.zip (2).
4. Shutting down H96 MAX. Press the Reset button. Turn on the H96 MAX. The message "Found One MASKROM Device" should appear. (1)
Mark all 4 sections with check marks (2)
Open 4 files for each section (3)
Check "Write by Address" (4).
Press the "Run" button (5). The download will start.
When the message "Download image OK" appears, the download is finished (6).
H96 MAX will automatically reboot.
Done.
On Linux OS
rkdeveloptool db MiniLoaderAll.bin
rkdeveloptool wl 0x0 start.img
rkdeveloptool wlx bootfs bootfs.img
rkdeveloptool wlx rootfs rootfs.img
Edited by hzdm
  • Author
@hzdm  You don't know how much we wait for someone like you.
I will update the main topic page with your build.
Thank you, arrived in good time
kernel 6 in this little box is an hot Kubernetes.
Please share with us the Armbian terminal screenshot  without ip address and
talk about your experience with this device.
did wifi works?
did USB2 port works?
Edited by hotnikq
Цитата
Arrived in good time kernel 6 in this little box is an hot Kubernetes.
I'm planning on learning how Kubernetes works on the H96 MAX as well. I even bought 4 H96 MAXs for this purpose. I will put them into a cluster. The processor is a bit weak, but for this price it is a great deal. The closest competitor is Orange Pi 3B, but it is a bit more expensive.
Цитата
did wifi works?
No, WiFi and USB 2 don't work.
I don't have any experience with it yet. As soon as I can run your image V0.7ARMBIAN23 - I already shared my results on this forum.
I plan to remove xfce completely, turning it from a desktop version to a server version.
I tried to run the system upgrade via "sudo apt full-upgrade", but after the upgrade the system stopped starting.
How do you update Armbian on your work device?
How do you update the Armbian image for this forum? Build a new image each time according to the instructions below https://docs.armbian.com/Developer-Guide_Build-Preparation/ ?
Edited by hzdm
  • Author
if you want this extra features, it can be solved by editing the DTB file
mipi DSi, display 7seg and infrared controller, all can be translated from android DTB to Linux DTB.
in my case it can be found on /boot/dtb/rockchip/rk3566-firefly-roc-pc.dtb
and the setup are made by the /boot/extlinux/extlinux.conf
an example how to manipulate this files
it can be done by the armbian config!
 sudo armbian-config
i think to update this you will need to rebuild the entire system so:
No end-user support: built from trunk
I Reuploaded the Build File to google drive you can use it as an second and alternative link to download
https://drive.google.com/file/d/1Hodbwqb0AzXvPMd0lm2w4bdeQ7uMjV7u/view?usp=sharing
Edited by hotnikq
  • Author
What I did:
else
fi
# Recompile with:
U-Boot's scripting language is different from conventional programming languages such as C++, Python or Java.
how did you learn it?
did you came from other linux distribuition?
i think you was creating an universe before making the kubernetes cluster.
keep pushing!
Edited by hotnikq
If USB, WiFi and display 7seg works that would be great. Thanks for the tip. I'll try to figure out the DTB.
I was able to build and run Armbian_23.11.0_server on my H96MAX by building it for a station-m2 device and replacing the dtb file. It turned out to be easier than I thought. I just need to figure out how to set up an automatic Armbian build with the right dtb file, the right partitions and boot.cmd.
I just took the boot.cmd from the Orange Pi 3B Armbian Image, and trimmed it down to the bare minimum.
The U-boot language is very similar to bash, and intuitive.
I have some familiarity with Linux administration. This is my first experience with Linux maintenance.
keep pushing!
Carl Sagan is a very wise man.
  • Author
to Compile armbian you will need a x86 desktop
you will need to select a CUSTOM KERNEL option when asked by the armbian comple system
./compile.sh build BOARD=station-m2 KERNEL_CONFIGURE=yes
and when asked to EDIT KERNEL SETTINGS
go to the compile KERNEL FOLDER and put the DTB files inside kernel
after that :
On 6/15/2023 at 6:43 AM, hotnikq said:
any resemblance to this topic is mere adaptation
Mount that image virtual device like /media/armbian_boot
fdisk -l your-armbian-image-for-sd-card.img
mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot
if you can't "like WSL2"
sudo apt-get install kpartx
sudo kpartx -av your-armbian-image-for-sd-card.img
sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot
Second Step:  prepare an sd card or usb flash dummy , can be anithing with 6gb
fdisk /dev/mmcblk1
N
default
default (lower this value to match the size of your root image)
T
1
W
third step: format that flash drive for ext4
mkfs.ext4 /dev/mmcblk1p1
fourth step: mount that clear partition and copy the entire virtual drive to the flash device
mount /dev/mmcblk1p1 /mnt
rsync -avx /media/armbian_boot /mnt
fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1"
blkid
nano -w /mnt/boot/extlinux/extlinux.conf
sixth step: make an hardware RAW.img from hardware flash drive with these parameters
sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress
PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1
now you have an ROOT IMAGE MADE BY YOURSELF!
./mkupdate.sh
Uboot Legacy, Parameter.txt to create the Rockchip image
@hzdm
Wow, congratulations, it's a shame I found someone willing to pay good money for my box, so I sold it, then I bought a T95 plus rk3566 and since then I've been using it, but now I'm willing to buy the h95 max v56 and test its image
I was able to get USB 2.0 up and running.
Here's the DTB file you need.
https://drive.google.com/file/d/1_Ajk-TxBgp3hvuU5PTWW08wGRVNR0y6f/view?usp=drive_link
To make USB 2.0 work, you need to:
1. Rename the file rk3566-h96-max-v56_v1.dtb to rk3566-firefly-roc-pc.dtb
2.  Replace the file /boot/dtb/rockchip/rk3566-firefly-roc-pc.dtb with it.
I may be able to get WiFi up and running in the future. But it may take more time.
Edited by hzdm
Good firmware, USB works with the dtb I replaced! Thanks for your effort.
Thought the wifi and hdmi out did not work, but the kernel 6 is more important.
I almost threw this box into the trash can...  thank you @hzdm
I found the dtb.img from update.img, is it genarated by your DTS_DTB_rk3566H96MAX   @hotnikq
I remember the debian 10 linaro firmware(kernel 4.19.193) can use wifi, usb and hdmi output , but I don't know how to extract the dtb file from it
dtbo.img from update.img as below
dtbo.img
On my firmware "ARMBIANv0.7BETA MMC on H96 MAX V56 RK3566 8G/64G" - HDMI works. Only I found one peculiarity. If there is no monitor connected during power on - HDMI will not work. Accordingly - if the monitor is connected during startup - HDMI works properly.
Is it the same with H96 MAX V56 4Gb?
Regarding the work of WiFi. Unfortunately, WiFI operation is not only DTB file: it is also drivers and possibly kernel settings.
I managed to find an image too - which has WiFi working (but no HDMI). This is an Armbian image for Panther-X2 board, a build from OpenHub project) https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_jammy_save_2023.10/Armbian_23.11.0_rockchip_panther-x2_jammy_6.1.57_server_2023.10.13.img.gz.
Using dtb from Panther-X2 - no results - WiFi did not work.
For WiFI to work - driver for BCM4335 must be loaded
hz@armbian:~$ ethtool -i wlan0
driver: brcmfmac
version: 6.30.171.24
firmware-version: Station/P2P)
expansion-rom-version:
bus-info: mmc2:0001:1
supports-statistics: no
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
hz@armbian:~$ sudo dmesg | grep brcmfmac
[    5.930622] brcmfmac: F1 signature read @0x18000000=0x16014335
[    5.962902] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[    5.965362] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.panther,x2.bin failed with error -2
[    5.980008] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.clm_blob failed with error -2
[    6.204159] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    6.205664] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: Mar 24 2013 20:36:01 version 6.30.171.24.20 (B0 Station/P2P)
[    6.278966] usbcore: registered new interface driver brcmfmac
hz@armbian:~$
Sorry, hdmi works, but low performace, may be GPU acceleration not enabled
  • Author
This is something about the EDID
The process that initialize display on ARM devices isn't Plug and Play
it need the EDID code to start with system. like it was part of the GPU driver.
17 minutes ago, hotnikq said:
Mali GPU from rockchip RK3566 is not Open source!
Ok, I get it. Only operating systems without a desktop environment are suitable to this box
15 minutes ago, hotnikq said:
it's kernel 4
it uses the DTB from android.
android is an kernel 4 fork from google.
we are here glue things on kernel 6.
I'm sorry for my poor knowledge. I thought the kernel version had nothing to do with the DTB file
Now I use this box with kernel6 as a NAS, replace the old orangepi3 box,  the faster cifs transfer speed is great. Giving up for using the box as all-in-one device, THX
Edited by mvpwar
  • Author
you can do it!
I have a tip for you to do what you are imagining!!!
Linux distros with ARC Manjaro architecture have GPU acceleration working perfectly on MALI GPU's.
you can make a Manjaro ROOT compilation
Based on Armbian,
If you manage to compile it please come back here and share
I start talking about it  here
and the conclusion is here
my Rock 3a works fine as a media player device with Manjaro since 2022
Edited by hotnikq
  • Author
in only in a 4gb device rk3566
i was using 2x 1TB SATA SSD on USB3.0
Docker with CasaOS:
Web tunnel over cloudflare to enable access to nextcloud with HTTPs.
Web Nextcloud application dockered to share things with windows over samba to local network.
on MacOS and Linux devices i used to share files from Local Lan over Cifis agaist baremetal.
this device as a NAS work at gigabit speeds, all over the place with wifi6
Quote
Quote
Edited by hotnikq
nice, Maybe you need the 10gb network adapter more.  I was using 2x 3TB SATA HDD with Raid1 on orico USB3 external hard drive enclosure, HDD max speed is 120m/s,  the same as a gigabit network cable
Old orangpi3 box only running the 50m/s cifs transfer speed, since the poor CPU performance
that's great, My initial idea was to use this h96-max to run NAS and somtimes play web online videos or video on usb local storage
Unexpectedly, to start WiFi, you just need to copy the drivers for it to the right directory.
Copy the brcmfmac4335-sdio.txt and brcmfmac4335-sdio.firefly,rk3566-roc-pc.bin files to the /lib/firmware/brcm directory and restart the device. After that we can connect to WiFi (at least via command line, I haven't checked it via GUI).
If GUI doesn't work - you can connect to WiFi via console with the command
nmcli device wifi connect My-WiFi-Point password 12345678
https://drive.google.com/file/d/1TeoPe_pO5es247c-5TGLfc4cXiKcPr56/view?usp=share_link
  • Author
Attached, DTB and DTS Files that work with all USB ports
Today I start the Recompile Session.
Command:
./compile.sh build BOARD=station-m2 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools internet office programming remote_desktop' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=yes RELEASE=jammy
Whats news?
Detect USB 2.0 port ✔️
Works Wifi Broadcom ✔️
Updated Armbian 23.11 ✔️
runs kernel 6.2 DESKTOP ✔️
Boot on Linux Cinnamon Ambian✔️
display video HDMi ✔️
detect internal MMC ✔️
Detect SD-CARD ✔️
Detect USB 3.0 port ✔️
Please test this image and report it here.
Use this tutorial to test this image
use the same update.img
and apply this new 23.11 rootfs insted of 23.08
also use the new 23.11 update image
NEW ROOT FILE ARMBIAN 23.11 CINNAMON
The changes are:
Line 299 and Line 304
Amazing job @hzdm
Quote
OLD:
	usb@fcc00000 {
		compatible = "rockchip,rk3568-dwc3\0snps,dwc3";
		reg = <0x00 0xfcc00000 0x00 0x400000>;
		interrupts = <0x00 0xa9 0x04>;
		clocks = <0x0e 0xa6 0x0e 0xa7 0x0e 0xa5>;
		clock-names = "ref_clk\0suspend_clk\0bus_clk";
		dr_mode = "host";
		phy_type = "utmi_wide";
		power-domains = <0x10 0x0f>;
		resets = <0x0e 0x94>;
		snps,dis_u2_susphy_quirk;
		status = "disabled";
		phys = <0x12>;
		phy-names = "usb2-phy";
		extcon = <0x13>;
		maximum-speed = "high-speed";
		phandle = <0xcf>;
Quote
NEW:
	usb@fcc00000 {
		dr_mode = "host";
		status = "okay";
		phys = <0x12>;
		extcon = <0x13>;
		phandle = <0xc9>;
rk3566-firefly-roc-pc.dtb rk3566-firefly-roc-pc.dts
Edited by hotnikq
@hotnikq
I soldered in SD Card holder. Are you sure about "Detect SD-CARD" success you reported? I don't see it.
Can you confirm the sd card is wired to mmc@fe2b0000?
Here's relevant dts snippet:
mmc@fe2b0000 {
		compatible = "rockchip,rk3568-dw-mshc\0rockchip,rk3288-dw-mshc";
		reg = <0x00 0xfe2b0000 0x00 0x4000>;
		interrupts = <0x00 0x62 0x04>;
		clocks = <0x0e 0xb0 0x0e 0xb1 0x0e 0x18a 0x0e 0x18b>;
		clock-names = "biu\0ciu\0ciu-drive\0ciu-sample";
		fifo-depth = <0x100>;
		max-frequency = <0x8f0d180>;
		resets = <0x0e 0xd4>;
		reset-names = "reset";
		status = "okay";
		supports-sd;
		bus-width = <0x04>;
		cap-mmc-highspeed;
		cap-sd-highspeed;
		cd-gpios = <0x21 0x04 0x01>;
		disable-wp;
		pinctrl-names = "default";
		pinctrl-0 = <0x60 0x61 0x62 0x63>;
		vmmc-supply = <0x1b>;
		phandle = <0xf6>;
Thanks;
Bill
23.10.2023 в 12:20, Sunil sankar сказал:
@hzdm super wifi works . Can you also share the armbian server version you had build.
I built an Armbian 23.11.0 server.
WiFi and USB 2.0 are working.
The installation is similar to the previous image.
I think this is a temporary image. I want to improve its build in the future.
https://drive.google.com/file/d/1MjFe_Z_gBY7d_-K8kxJ6JUg8Wkzqk-JZ/view?usp=drive_link
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
