Skip to content
View in the app
Armbian Community Forums
The ole power-off button using gpio question - AML-S905X-CC
Featured Replies
Hello.  I've searched here, the Libre computer forums, even tried "cheating" with asking chatgpt.  Using a "Le Potato" AML-S905X-CC with Armbian Jammy 22.04.2 LTS.
I've gotten far enough to be able to read the switch on the GPIO with pulled to 0 reading as 1.
button untouched:
~$ sudo gpioget --active-low gpiochip1 97
0
button pressed:
:~$ sudo gpioget --active-low gpiochip1 97
1
From here though, I can't seem to figure out what to do next.  I've seen suggestions to use a python script with a sleep to using device overlays.  The device overlay examples I see using armbian are typically for orange Pis and I can't seem to extrapolate to the le potato gpio, or are Libre's support saying how to do it with their custom kernels and device tree overlay tools, which I (in my foolishness? long term wisdom?) chose not to use over Armbian.
If anyone has some input on what to throw at this next I'd love it.  I am using this le potato as a klipper server with Fluidd and would love to be able to hit my pretty led backed power button to power down the server board and a second led lit power switch to power down the printer.  In the end it's no big deal if I can't get this working, I can just shutdown the pi via Klipperscreen and then use the modified power switch on the 3d printer.  But that's not as much fun as changing everything.
Thank you!
Solved by usual user
  • Author
Good input.  I did have to add  option " -B pull-down" or it gave me syntax errors.
sudo gpiomon --num-events=1 -B pull-down -f gpiochip0 9 && halt
I also couldn't get it to register the button press immediately.  I'd need to do more testing but it seemed I needed to hold it down for seconds before it'd register.  I also wasn't sure how to get a wall message and 5 second wait in there, so in the end I went with a script that loads on startup.
That said, what you said was a perfectly solid answer so you get the solution.
Thank you for the response!
The necessity of the "-B" parameter with the observed gpio behavior is probably due to how the gpio is wired up in the DT and how its pin control is set up there.
Since I didn't know the exact use case, I only presented the basic command and left it to the user's imagination how it would ultimately be used. It's general shell usage, and if I understand the use case correctly, I'd have e.g. used something like this in a script that loads on startup:
gpiomon --num-events=1 -B pull-down -f gpiochip0 9 && wall power off initiated && sleep 5 && halt
You're welcome.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
