July 20, 20233 yr A guide to installing Armbian on the H96 Max V11 (RK3318_V1.4 blue PCB) What you will need Your H96 Max V11 TV box with the power supply and the HDMI cable that came with it; A TV or a monitor with an HDMI port; A wired USB keyboard (or a wireless one with a USB dongle); An Ethernet cable to connect to a router on your home network that has Internet access; A Micro SD card (minimum 1GB, more if you're going to back up Android on your box before overwriting it with Armbian); A USB card reader for Micro SD cards; A Windows PC connected to your home network; Installation steps Download the experimental Armbian image (kernel 5.19.15 and libreelec patches — alas, that's the latest version that works correctly with our box) and a copy of the Multitool; Burn the Multitool on the SD card using Rufus (no need to change any settings, just click "SELECT" and locate multitool.img.xz or drag and drop the file on Rufus and then click "START"); Connect your TV box to the TV or monitor, connect the keyboard, plug in the Multitool SD card and then plug in the power cord; Wait a minute (while SD card partitions are being resized) for the Multitool main menu to appear, then select "Shutdown"; Unplug the power cord and the SD card, then plug the SD card into your PC. Two new drives should appear, labeled BOOTSTRAP and MULTITOOL. If you see both, skip the next step. If you only see the BOOTSTRAP, proceed to the next step; Start Disk Management (press Win+X, K). Scroll down the list of disks (use the scrollbar, because mouse wheel doesn't work there) to locate your SD card, and on the MULTITOOL partition right-click, then press C, and click "Add", "OK"; Open the MULTITOOL drive in Windows Explorer (or your favorite file manager) and copy the downloaded Armbian image to the images folder; Safely remove (eject) the SD card, plug it into the TV box and plug in the power cord. The Multitool main menu will appear in a few seconds; If you don't care about stock Android firmware on your TV box, skip the next step. If you want to back up the Android firmware, proceed to the next step; In the Multitool main menu select "Backup flash" and click through (there will be only one option). Name your backup file. Wait for the backup to finish. The backup file will be saved to the backups folder on the SD card's MULTITOOL partition; Now it's time to replace Android with Armbian. In the Multitool main menu select "Burn image to flash" and click through (there will be only one option). Wait for the process to complete, then in the main menu select "Shutdown"; Unplug the power cord and the SD card, then replug the power cord. Wait a few minutes for Armbian to get everything ready for its first launch, and then follow the initial setup prompts; You will be taken to the login prompt. Log in with the name/password for the regular user you've created; Connect your TV box to your home network router with an Ethernet cable; In Armbian, enter the command sudo cat /run/motd.dynamic and note the IP address assigned by the router to the TV box; Now you will need to connect to your TV box on the home network via the SSH protocol. If you're running Windows 10 or later, press Win+X, I, Enter. A PowerShell/Terminal window will open. Enter the following command, substituting the words in angle brackets with actual values: ssh <IP address from the previous step> -l <name for the regular user>. Type yes at the prompt asking if you really want to connect to this unknown host. At the next prompt that appears, enter the password for the regular user you've created. Skip the next step; If you're running an older version of Windows, you will need to download PuTTY, an SSH and Telnet client, set up an SSH connection to your TV box with the IP address above and log in with the name/password for the regular user; Now it's time to fix the settings for the Wi-Fi chip that doesn't work out of the box on the H96 Max V11. To delete the old settings, copy the command sudo rm -f /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt and paste it by right-clicking in the SSH window, then press Enter; To create the new settings file, enter (copy-paste) the command sudo nano /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt The nano text editor will open with a new empty file; Now open this small text file (a copy of nvram_2734c.txt from this forum topic), press Ctrl-A to select all text in it, then Ctrl-C to copy it to the clipboard; Switch to the SSH window, right-click to paste the copied text to nano then press Ctrl-S to save and Ctrl-X to exit; Enter (or copy-paste) the command sudo reboot -f to reboot Armbian. After that you can either close the SSH window and proceed with the physical console or start a new SSH session once Armbian has restarted; Enter (or copy-paste) the command sudo apt update && sudo apt install armbian-config After the update and installation is completed, run armbian-config to configure various software and hardware settings (including Wi-Fi). It is recommended to select "Freeze" in System settings to disable Armbian kernel upgrades because our kernel is compiled with custom patches enabling HDMI output on H96 Max V11 to work properly that are unavailable in other kernel versions. Edited July 21, 20233 yr by Maxxim SSH instructions updated for Windows 10 and later
July 20, 20233 yr vor 6 Stunden schrieb Maxxim: Download PuTTY, an SSH and Telnet client, to your Windows PC and use it to connect via SSH to your TV box (IP address in the previous step); On win 10+, putty isn´t needed, just open a Powershell or CMD and use in build ssh with "ssh <IP>"
July 21, 20233 yr Author 16 hours ago, robby said: "ssh <IP>" Thanks for the tip! I've been using PuTTY for so long (it's actually KiTTY these days) I wasn't even aware Windows 10 had a native ssh client. Instructions updated. (And it's not simply "ssh <IP>", unless you use the same name everywhere. :) You need to specify the username otherwise ssh will try to log you in with your Windows username by default.)
August 26, 20233 yr followed your guide and managed to install it on the EMMC. few things to note: -if the box is in the "red led on" state, it is either shutdown or awaiting user input or even reset button to be press to start -it is possible to update to a more recent kernel
November 17, 20232 yr Maxxim, thank you for detailed instruction. I have H96 V12 and bluetooth not working. hciconfig not see HCI0. I think in V12 installed another bluetooth chip. Maybe you know, how resolve this problem. (to correct some config file etc...)
December 16, 20232 yr I had a V11 and was able to get Bluetooth to work by performing the following steps: 1) run sudo rk3318-config and accept all defaults. 2) Create the following symbolic link: sudo ln -s /lib/firmware/brcm/BCM43342.hcd /lib/firmware/brcm/BCM.hcd 3) Reboot sudo reboot
January 9, 20251 yr On 7/20/2023 at 3:41 PM, Maxxim said: Safely remove (eject) the SD card, plug it into the TV box and plug in the power cord. The Multitool main menu will appear in a few seconds; Hi im on this step of the guide but the tv box wont open unless i unplug the sd card . what should i do ?
July 11, 20251 yr I've installed the image Armbian_community_25.8.0-trunk.309_Rk3318-box_noble_current_6.12.35_gnome_desktop.img on a H96 Max V11. I've followed this guide: It works but I've some troubles with Wifi. I've tried to use this instructions to fix, but it doesn't work. I'm quite new with armbian and arm platform in general even if I've a strong knowledge on Linux. If I've understood well there is some tricks to do with DTS file concerning the WIFI chipset. Any suggestion how to investigate and fix the problem? Edited July 11, 20251 yr by davide68
July 11, 20251 yr 4 hours ago, davide68 said: It works but I've some troubles with Wifi. I've tried to use this instructions to fix, but it doesn't work. I'm quite new with armbian and arm platform in general even if I've a strong knowledge on Linux. If I've understood well there is some tricks to do with DTS file concerning the WIFI chipset. Any suggestion how to investigate and fix the problem? What wifi do you have? Did you run rk3318-config to configure the device tree overlays for your board properly? The intent of rk3318-config script is to avoid the users tinkering with the DTS, but requires to know the board name printed on the silkscreen of the board itself. The commercial box name, instead, is often useless or misleading.
May 10May 10 ok my findings root@rk3318-box:/boot# cat *Env.txt verbosity=1 bootlogo=true console=both overlay_prefix=rockchip fdtfile=rockchip/rk3318-box.dtb rootdev=UUID=a3e848f3-8d54-412d-9184-5bc40ab76686 rootfstype=ext4 overlays=hdmi-audio rk3318-box-cpu-hs rk3318-box-led-conf1 rk3318-box-wlan-ap6334 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@rk3318-box:/boot# sudo ln -s /usr/lib/firmware/brcm/brcmfmac4334-sdio.bin /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin ### it was missing according the log sudo rm /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt ### this one did not do the job , you could ofcourse backup ... sudo wget -O /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt https://pastebin.com/raw/00gLSkKS ### the nvram hosted in this topic after the reboot the wifi worked fine for me
June 10Jun 10 i am running a H96(model RK3318) android tv box, its old, i have lost itss remote as well. basically noow i am tryinh to install ambrain os on it, but the conditon now is , even the android id now visible on the tv/monitor, basically when i insert the power cable on the display "boot" is showing with blue light. after few sec, some number like "07:01" is showing, but when i connect my htmi cable, the tv is detecting the htmi. but its showing no signal. basically there is no output on the display. i have tried many methods, there is no problem in htmi, or tv or cable. the andoird itself not booting. and the sd card method for ambrain also not working . tried the toothpick method and everything. but still its nott working!. i dont know why there is no output on the display. i dont know whhat issue. usb, htmi, everything is working. even charger also working.
September 21Sep 21 I have this very revision of the board -"RK3318_V1.4 202303.200629". Was able to install recent armbian (https://armbian.com/boards/rk3318-box) and it even booted once, right after installation - but that was the last time I've seen this board booting The only thing I've managed to do is to attempt to connect to my WiFi - but that was it. All my further attempts to boot it were failed. Current state is - upon power up the board is lighting up it's RED LED and without any HDMI output. What I've tried, and what didn't work: - powering the board up with the SD card plugged in - the one that has a multitool and the very same one, that was used to format the EMMC and copy armbian image on it - power the board up while pressing or hodling "boot" button (it's behind the 3.5 mm audio jack) I guess the internal EMMC got corrupted or bootloader got damaged and I need to bypass it. And given the EMMC chip is BGA that might be troublesome. I'll try to find UART port on the board, but appreciate if someone who already found it will share his knowledge. Right now I have few suspects: Edited September 21Sep 21 by alx84
September 22Sep 22 UART on this board is three pads marked with a light blue on my above shots. Middle pad is ground, left is TX right is RX. Bought a cheap USB RTL dongle and was able to read boot messages - it seems that the board doesn't like the RAM blob that came with that most recent armbian: user@x1:~/Downloads$ picocom -b 1500000 /dev/ttyUSB0 picocom v3.1 port is : /dev/ttyUSB0 flowcontrol : none baudrate is : 1500000 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no hangup is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, logfile is : none initstring : none exit_after is : not set exit is : no Type [C-a] [C-h] to see available commands Terminal ready DDR version 1.16 20190713 ID:0xFFF In col error ERR Next task is to find the CLK for eMMC
October 5Oct 5 So I bought a soldering air gun and removed the SSD chip. So I have MaskROM all the time I booted up with SD card (with Multitool on it) but symptoms are quite the same - in UART I can see the system is still complaining on memory: user@x1:~$ picocom -b 115200 /dev/ttyUSB0 picocom v3.1 port is : /dev/ttyUSB0 flowcontrol : none baudrate is : 115200 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no hangup is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, logfile is : none initstring : none exit_after is : not set exit is : no Type [C-a] [C-h] to see available commands Terminal ready DDR version 1.15 20190428 ID:0xFFF In col error ERR My current guesses are: - either there's something wrong with the memory initialization blobs, that are coming with Multitool. I need to find a way to replace them or configure them to use different clock speed / timings / whatever - or my memory chips (or their power supply) are busted
