davide68
  1. I've followed your suggestion and used the configure sw. I've solved. Thank you.
  2. Hi all, I managed to install Armbian on a X96 Linux TVBox with 4Gb RAM and 32Gb ROM. I've build the image following the Armbian Build Framework. - v25.08 rolling for aml-s9xx-box running Armbian Linux 6.12.37-current-meson64 I reused the DTB that originally comes with the BOX and almost everything seems to work. I tested the system using glmark2 with a score of 197. I suppose GPU is working. Anyway I've some problems with Electron. I have installed the "hello world" app. The application starts but I receive this error: [4150:0714/130924.545719:ERROR:ui/gfx/linux/gbm_wrapper.cc:79] Failed to get fd for plane.: No such file or directory (2) [4150:0714/130924.547711:ERROR:ui/gfx/linux/gbm_wrapper.cc:261] Failed to export buffer to dma_buf: No such file or directory (2) Any suggestion? Davide
  3. I've installed the image Armbian_community_25.8.0-trunk.309_Rk3318-box_noble_current_6.12.35_gnome_desktop.img on a H96 Max V11. I've followed this guide: It works but I've some troubles with Wifi. I've tried to use this instructions to fix, but it doesn't work. I'm quite new with armbian and arm platform in general even if I've a strong knowledge on Linux. If I've understood well there is some tricks to do with DTS file concerning the WIFI chipset. Any suggestion how to investigate and fix the problem?
