August 1, 20233 yr Looking for Linux for this X96 TVBox variant, model PROB3000 2GB DDRIII + 16 GB eMMC https://www.google.com/search?q=PROSB-3000%2F16 Tag on board: BA301 v1.3 XR819 NJ 2+16 CPU: Allwinner h313 (H616 datasheet covers H313, just higher clock and 4GB RAM support: https://linux-sunxi.org/images/3/30/H616_Datasheet_V1.0.pdf ) MCP> LPDDR3 SDRAM + eMMC chip: Samsung KMR8X000IM-B608 ( https://file2.dzsc.com/product/20/05/07/1115580_113217385.pdf ) WLAN chip: XR819 ( https://linux-sunxi.org/images/8/8f/XR819_Datasheet_V1.0-EN.pdf ) Edited August 1, 20233 yr by LinuxBoxer
August 23, 20233 yr my tv box uses the same chip,Ik316=h313, but when I use the h616 image it gives the following error U-Boot SPL 2021.04 (May 25 2023 - 13:06:08 +0200) DRAM:This DRAM setup is currently not supported. Attached I send the boot log and the images of my tvbox bootik316.txt
August 23, 20233 yr 31 minutes ago, javaxsousa said: when I use the h616 image What exact image are you using?
September 8, 20233 yr Author On 8/23/2023 at 4:54 PM, javaxsousa said: Attached I send the boot log Lots of fails, that firmware is improper for your hardware, and your hardware is older and not even similar to this one in this post. Better open a separate post and add more photos, I think there are missing chips in your photo. Your PMU is pictured as AXP305 and your log says "Unknown PMU AXP806" ? Very different circuit and chipset.
October 24, 20232 yr Hello! I also have such a console and can’t run the orange Pi zero2, Bigtreetech-cb1 images. Error: U-Boot SPL 2023.10-armbian (Oct 14 2023 - 01:14:07 +0000) DRAM:This DRAM setup is currently not supported. resetting...
November 4, 20232 yr Author Your board seems the same, your ram/emmc chip is a Micron model instead of the Samsung eMMC+LPDDR3, not sure about full compatibility between both.
November 29, 20232 yr Hi. First of all, I would like to congratulate you on this forum and the enormous work you do to keep it up to date. I just got an X96Q, it has a CPU: Allwinner H313, I would like to know how to install Armbian on it, thanks in advance.
March 24, 20242 yr @Juliano Schmitt https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
May 21, 20242 yr Quote Hi, sorry my english Did you got a working system? I can boot MiniArch-20231112-6.7.4-board-h313.x96_q_lpddr3-SD-Image but ethernet won't work and MiniArch-20231112-6.7.4-board-h616.tanix_tx6s_axp313-SD-Image won't boot.. I'm in hope to get Klipper work on this tvbox
June 5, 20242 yr How to connect with usb tethering please. And ethernet work after install or only wifi
June 6, 20242 yr Quote Connect usb cable into an Android smartphone and select "USB Thetering" in smartphone... But in new release(v20240522) Ethernet was showing working(not tested), and wifi too(tested). I've give up because can't add CAN network module(don't know how), this is necessary to run my project (3d printer with klipper and can toolhead).
June 6, 20242 yr Thank you friend Usb thetering done Install done After installing endeavouros How to boot to os
June 6, 20242 yr You need install lightdm manually, welcome to Arch world, everything need medium/advanced knowledge in linux... 😅
June 6, 20242 yr I have a question ❓️ If I found driver ethernet I can Install on miniarch I don't need to install endeavouros
