Skip to content
View in the app
Armbian Community Forums
Featured Replies
Transpeed 8k618-t & Vontar H618
Wifi: HK6334Q
Clock: 37.4 MHz
Tanix Tx6s & Tx6
Wifi: SP6330-X0
Clock: 26.0 MHz
Tanix TX68
Wifi: AW869A
Clock: No Osc
Edited by firepower
Looking at the patch again... I don't think adding cooling will solve the issue. Also the H616 dtsi already has "#cooling-cells = <2>;".
https://lore.kernel.org/linux-arm-kernel/20230821-ths-h616-v2-0-cda60d556798@somainline.org/T/
Right now I'm using the 6.10.10 kernel. I'll update to 6.10.14 and make a new kernel config.
Your board is using an external crystal for it's clock. Can I see your dmesg log? Maybe you just need bluetooth firmware.
Edited by Nick A
firepower@tanix-tx6s-axp313:~$ dmesg | grep -i bluetooth
[   11.946450] Bluetooth: Core ver 2.22
[   11.946611] NET: Registered PF_BLUETOOTH protocol family
[   11.946621] Bluetooth: HCI device and connection manager initialized
[   11.946642] Bluetooth: HCI socket layer initialized
[   11.946650] Bluetooth: L2CAP socket layer initialized
[   11.946681] Bluetooth: SCO socket layer initialized
[   12.099653] Bluetooth: HCI UART driver ver 2.3
[   12.099681] Bluetooth: HCI UART protocol H4 registered
[   12.099686] Bluetooth: HCI UART protocol BCSP registered
[   12.099793] Bluetooth: HCI UART protocol LL registered
[   12.099802] Bluetooth: HCI UART protocol ATH3K registered
[   12.099840] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.100025] Bluetooth: HCI UART protocol Intel registered
[   12.100275] Bluetooth: HCI UART protocol Broadcom registered
[   12.100338] Bluetooth: HCI UART protocol QCA registered
[   12.100344] Bluetooth: HCI UART protocol AG6XX registered
[   12.100373] Bluetooth: HCI UART protocol Marvell registered
[   41.324215] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   41.324250] Bluetooth: BNEP filters: protocol multicast
[   41.324272] Bluetooth: BNEP socket layer initialized
Quote
root@transpeed-8k618-t:~# dmesg | grep -i bluetooth
[    5.478537] Bluetooth: Core ver 2.22
[    5.478627] NET: Registered PF_BLUETOOTH protocol family
[    5.478632] Bluetooth: HCI device and connection manager initialized
[    5.478650] Bluetooth: HCI socket layer initialized
[    5.478658] Bluetooth: L2CAP socket layer initialized
[    5.478672] Bluetooth: SCO socket layer initialized
[    5.531438] Bluetooth: HCI UART driver ver 2.3
[    5.531464] Bluetooth: HCI UART protocol H4 registered
[    5.531469] Bluetooth: HCI UART protocol BCSP registered
[    5.531553] Bluetooth: HCI UART protocol LL registered
[    5.531558] Bluetooth: HCI UART protocol ATH3K registered
[    5.531591] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.531762] Bluetooth: HCI UART protocol Intel registered
[    5.531870] Bluetooth: HCI UART protocol Broadcom registered
[    5.531906] Bluetooth: HCI UART protocol QCA registered
[    5.531911] Bluetooth: HCI UART protocol AG6XX registered
[    5.531941] Bluetooth: HCI UART protocol Marvell registered
[    5.893268] Bluetooth: hci0: BCM: chip id 68
[    5.895711] Bluetooth: hci0: BCM: features 0x0f
[    5.919060] Bluetooth: hci0: BCM4334B0
[    5.919078] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[    5.920257] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   10.433680] Bluetooth: hci0: BCM: features 0x0f
[   10.457165] Bluetooth: hci0: BCM4334B1 37.4 MHz ExtLNA Murata VM
[   10.457192] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1852
[   12.003621] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   12.003657] Bluetooth: BNEP filters: protocol multicast
[   12.003677] Bluetooth: BNEP socket layer initialized
[   12.010332] Bluetooth: MGMT ver 1.22
[   14.116580] Bluetooth: hci0: Opcode 0x0c56 failed: -110
[   14.116666] Bluetooth: hci0: command 0x0c56 tx timeout
[   16.132606] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   16.132693] Bluetooth: hci0: command 0x0c56 tx timeout
[   18.148604] Bluetooth: hci0: command 0x0c56 tx timeout
[   18.152608] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   20.168709] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   20.168799] Bluetooth: hci0: command 0x0c56 tx timeout
[   22.180702] Bluetooth: hci0: command 0x0c56 tx timeout
[   22.180757] Bluetooth: hci0: Opcode 0x0c13 failed: -110
[   24.196740] Bluetooth: hci0: command 0x0c56 tx timeout
[   24.196920] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   26.298259] Bluetooth: hci0: command 0x0c56 tx timeout
[   26.298257] Bluetooth: hci0: Opcode 0x0c13 failed: -110
root@transpeed-8k618-t:~# bluetoothctl
Agent registered
[CHG] Controller 43:34:B0:00:1F:AC Powered: yes
[CHG] Controller 43:34:B0:00:1F:AC Pairable: yes
[bluetooth]# scan on
Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]# show
Controller 43:34:B0:00:1F:AC (public)
    Alias: transpeed-8k618-t
    Class: 0x00000000
    Powered: yes
    Discoverable: no
    DiscoverableTimeout: 0x000000b4
    Pairable: yes
    UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
    UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
    UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
    UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
    UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
    UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
    Modalias: usb:v1D6Bp0246d0542
    Discovering: no
    Roles: central
    Roles: peripheral
Advertising Features:
    ActiveInstances: 0x00 (0)
    SupportedInstances: 0x05 (5)
    SupportedIncludes: tx-power
    SupportedIncludes: appearance
    SupportedIncludes: local-name
firepower.. I don't even see a HCI interface detected at all. Maybe your dts needs some work.
MMorales your dmesg looks like a firmware issue.. extract the firmware from your original android.
Edited by Nick A
I forget exactly where the firmware is... I think it's in /vendor/etc/firmware. Search your android partitions for a file called BCM4334B0.hcd. You can also try your original android wifi firmware too.
You can use the X-plorer app. My box comes with it.
Edited by Nick A
I have the same output as MMorales on 6.7.12 but ..( probably this is valid and for 6.10.x)
 kernel asks for an additional firmware blob file:  (but i can't find it)   --> (probably  is filtered from dmesg of  MMorales)
[    6.169613] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
I Formated my emmc on my box but i found a firmware however there are many variations of such boxes
Additionally:
Super partition is dynamic partition not an ext4
i Have convert Super.fex with simg2img to raw image  but i can not mount it...
We need A live box.
@MMorales
Do you have any working Android firmware for your box ?
I finally extract it is on vendor/etc/firmware
The android firmware file is (H618.apollo-p3.T-H618_100M_12.2022.12.05.23.41.img)
You can download the extracted full firmware files here : https://easyupload.io/wab7ki
Edited by rafman
Just now, MMorales said:
@rafman its your bluetooth working ? can you share the file ?
I will check it ... now i am in progress
Download the files Here:  https://easyupload.io/wab7ki
Firmware Contains: ( For transpeed 8k HK6334Q these files are suspected)
bcm4334.hcd
fw_bcm43341b0_ag.bin
fw_bcm43341b0_ag_apsta.bin
fw_bcm43341b0_ag_p2p.bin
regulatory.db
regulatory.db.p7s
You need these three files:
bcm4334.hcd                           (bluetooth)
fw_bcm4334b1_ag.bin           (wifi .bin)
nvram_ap6334.txt                   (wifi .txt)
i copy the selected files in this way.
mv /usr/lib/firmware/brcm/BCM4334B0.hcd /usr/lib/firmware/brcm/BCM4334B0_BAK.hcd
cp ./bcm4334.hcd /usr/lib/firmware/brcm/BCM4334B0.hcd
mv /usr/lib/firmware/rkwifi/fw_bcm4334b1_ag.bin /usr/lib/firmware/rkwifi/fw_bcm4334b1_ag_BAK.bin
cp ./fw_bcm4334b1_ag.bin /usr/lib/firmware/rkwifi/fw_bcm4334b1_ag.bin
cp ./nvram_ap6334.txt /usr/lib/firmware/rkwifi/
with these results:
root@transpeed-8k618-t:~/ble# nano do.sh
root@transpeed-8k618-t:~/ble# dmesg | grep -i bluetooth
[    5.456993] Bluetooth: Core ver 2.22
[    5.457104] NET: Registered PF_BLUETOOTH protocol family
[    5.457109] Bluetooth: HCI device and connection manager initialized
[    5.457128] Bluetooth: HCI socket layer initialized
[    5.457136] Bluetooth: L2CAP socket layer initialized
[    5.457150] Bluetooth: SCO socket layer initialized
[    5.590405] Bluetooth: HCI UART driver ver 2.3
[    5.590433] Bluetooth: HCI UART protocol H4 registered
[    5.590438] Bluetooth: HCI UART protocol BCSP registered
[    5.590540] Bluetooth: HCI UART protocol LL registered
[    5.590545] Bluetooth: HCI UART protocol ATH3K registered
[    5.590575] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.590741] Bluetooth: HCI UART protocol Intel registered
[    5.590870] Bluetooth: HCI UART protocol Broadcom registered
[    5.590904] Bluetooth: HCI UART protocol QCA registered
[    5.590910] Bluetooth: HCI UART protocol AG6XX registered
[    5.590937] Bluetooth: HCI UART protocol Marvell registered
[    5.949227] Bluetooth: hci0: BCM: chip id 68
[    5.951685] Bluetooth: hci0: BCM: features 0x0f
[    5.975070] Bluetooth: hci0: BCM4334B0
[    5.975091] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[    5.976485] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   11.805787] Bluetooth: hci0: BCM: features 0x0f
[   11.829327] Bluetooth: hci0: BCM4334B0 37.4MHz Class1.5 Samsung Note8-1675
[   11.829358] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1718
[   12.100151] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   12.100185] Bluetooth: BNEP filters: protocol multicast
[   12.100204] Bluetooth: BNEP socket layer initialized
[   12.106914] Bluetooth: MGMT ver 1.22
root@transpeed-8k618-t:~/ble#  bluetoothctl
Agent registered
[bluetooth]# discoverable on
Failed to set discoverable on: org.bluez.Error.Failed
I rename: the files and copy it to /lib/firmware/brcm
bcm4334.hcd    -->  BCM4334B0.hcd
fw_bcm4334b1_ag.bin --> brcmfmac4334-sdio.transpeed,8k618-t.bin
nvram_ap6334.txt -->  (as is) to /lib/filrmware/brcm/
it seems to work for me now (i can see my mobile phone on discovery)  but i still have tx errors on dmesg.
Edited by rafman
cp ./bcm4334.hcd /lib/firmware/brcm/BCM4334B0.hcd
cp ./fw_bcm4334b1_ag.bin /lib/firmware/brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin
cp ./nvram_ap6334.txt /lib/firmware/brcm/
@rafman I did same as you but not working.
my kernel is 6.9.12-edge-sunxi64 maybe is the diference.
Agent registered
[bluetooth]# discoverable yes
Changing discoverable on succeeded
[bluetooth]# exit
Agent registered
Firmware is not stable Bluetooth adapter is not powered correctly.. sometimes works but not stable and lot of tx errors.
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
     Active: active (running) since Sat 2024-10-12 00:05:19 CEST; 1s ago
       Docs: man:bluetoothd(8)
   Main PID: 8382 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 4539)
     Memory: 824.0K
        CPU: 372ms
     CGroup: /system.slice/bluetooth.service
             └─8382 /usr/libexec/bluetooth/bluetoothd
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: Starting SDP server
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: src/plugin.c:plugin_init() Failed to init vcp plugin
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: src/plugin.c:plugin_init() Failed to init mcp plugin
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: src/plugin.c:plugin_init() Failed to init bap plugin
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: Bluetooth management interface 1.22 initialized
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Oct 12 00:05:19 transpeed-8k618-t bluetoothd[8382]: sap-server: Operation not permitted (1)
i saw this and after seach in google i edited /etc/bluetooth/main.conf and add the line :
Experimental = true
after that: the result of status service is:
root@transpeed-8k618-t:~# systemctl status bluetooth.service
     Active: active (running) since Sat 2024-10-12 00:21:25 CEST; 1s ago
   Main PID: 9590 (bluetoothd)
     Status: "Running"
     Memory: 864.0K
        CPU: 284ms
             └─9590 /usr/libexec/bluetooth/bluetoothd
Oct 12 00:21:25 transpeed-8k618-t systemd[1]: Starting bluetooth.service - Bluetooth service...
Oct 12 00:21:25 transpeed-8k618-t bluetoothd[9590]: Bluetooth daemon 5.66
Oct 12 00:21:25 transpeed-8k618-t systemd[1]: Started bluetooth.service - Bluetooth service.
Oct 12 00:21:25 transpeed-8k618-t bluetoothd[9590]: Starting SDP server
Oct 12 00:21:25 transpeed-8k618-t bluetoothd[9590]: Bluetooth management interface 1.22 initialized
Oct 12 00:21:25 transpeed-8k618-t bluetoothd[9590]: Battery Provider Manager created
Oct 12 00:21:25 transpeed-8k618-t bluetoothd[9590]: Adv Monitor Manager created with supported features:0x00000000, enabled features:0x00000000, max number of supported moni>
and the ble stil not working: bah
Agent registered
AdvertisementMonitor path registered
[bluetooth]# power on
[CHG] Controller 43:34:B0:00:1F:AC PowerState: off-enabling
Failed to set power on: org.bluez.Error.Failed
[CHG] Controller 43:34:B0:00:1F:AC PowerState: on
[bluetooth]# show
	Class: 0x00000000
	Powered: no
	PowerState: on
	Discoverable: no
	Pairable: yes
	UUID: SIM Access                (0000112d-0000-1000-8000-00805f9b34fb)
	UUID: Volume Control            (00001844-0000-1000-8000-00805f9b34fb)
	Discovering: no
	Roles: central
	Roles: peripheral
	SupportedCapabilities Key: MaxAdvLen
	SupportedCapabilities Value: 0x1f (31)
	SupportedCapabilities Key: MaxScnRspLen
Advertisement Monitor Features:
	SupportedMonitorTypes: or_patterns
Failed to start discovery: org.bluez.Error.NotReady
[bluetooth]# devices
13 hours ago, Nick A said:
Maybe you'll have better luck with these.
I will try for more tomorrow.
it seems to do be a mater of firmware however this firmware works but not stable.
With previous firmware a was not able to discover any device. however and with android firmware I have tx errors.
FYI : I attach my dmesg files for both situations with original (before)  and (android)
original fw files was also from LibreElec collection. but i will check tomorrow if something is different in your link above.
android-fw-dmesg original-fw-dmesg
Edited by rafman
Quote
I think you used the wifi firmware from LibreElec. But the bluetooth firmware "BCM4334B0.hcd" was already existing in the Armbian firmware folder. The Armbian firmware might be different than LibreElec's version. Worth a try.
I'm not sure if the sdio.txt file has bluetooth configuration settings in it. We can play with some of these settings.
Edited by Nick A
I have ordered the Vontar H618 as it hardware is similar to transpeed most are using. I am new armbian and have much to learn, so using Vontar should be easier then Tanix Tx6.
@rafman what is the monitor software on your desktop?
Edited by firepower
Results.
1> The original BCM4334B0.hcd from my Armbian image does not work, and i think has same behavior as the LibreElec BCM4334B0.hcd.
2> Firmware from LibreElec works only with the wifi but not with Bluetooth.
3> The android firmware works but not stable (I am not 100% sure about the Android firmware file) i used to extract it because i did not Flash this
      firmware to my device, however from my internet search i found that  many  variations of transpeed-8k h618 box exists arround.
      NOTE: There is also a newer version of android firmware (H618.apollo-p3.T-H618_100M_12_FD650.2023.09.13.17.20.img) that i will investigate today to see if some firmware is different.
4> I think the "sdio.txt" is the nvram file (nvram_ap6334.txt) and i already test it (as is)  by copy to /lib/firmware/brcm and as brcmfmac4334-sdio.transpeed,8k618-t.txt
     but this did not make any changes.
I am taking this information about interface (android fw):
rafman@orion-8k:~$ sudo hciconfig -a
[sudo] password for rafman:
hci0:    Type: Primary  Bus: UART
    BD Address: 43:34:B0:00:1F:AC  ACL MTU: 1021:8  SCO MTU: 64:1
    UP RUNNING
    RX bytes:5156 acl:0 sco:0 events:603 errors:0
    TX bytes:56764 acl:0 sco:0 commands:619 errors:0
    Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
    Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
    Link policy: RSWITCH SNIFF
    Link mode: PERIPHERAL ACCEPT
Can't read local name on hci0: Connection timed out (110)
This is my TV, with Mate Desktop (customized)
Edited by rafman
I have this android image wich is the latest H618.apollo-p16.VONTAR_H618_100M_12_FD650.2024.05.20.12.40.img
you can get here https://www.dropbox.com/scl/fi/auh5wmpsigzlrt0ew56vr/VONTAR-H618.zip?rlkey=y00w06w1d3u1ojzl3tuw2nlct&e=1&st=7pwisv8d&dl=0
i installed in a device and extracted the files.
but are the same anyway here you have.
files_from_android_2024.zip
But no bluetooth neither. there are the same files.
Edited by MMorales
59 minutes ago, Nick A said:
Negative / Crash
I have deleted  everything from my /lib/firmware/brcm and i reverse the android (fw)
now i have only theese files and bluetooth working as previous.
rafman@orion-8k:~$ ls -l /lib/firmware/brcm/
total 512
-rw-r--r-- 1 rafman rafman  53957 Jan  1  2009 BCM4334B0.hcd
-rw-r--r-- 1 rafman rafman 457249 Jan  1  2009 brcmfmac4334-sdio.transpeed,8k618-t.bin
-rw-r--r-- 1 rafman rafman   2019 Jan  1  2009 brcmfmac4334-sdio.transpeed,8k618-t.txt
-rw-r--r-- 1 rafman rafman   2019 Jan  1  2009 brcmfmac4334-sdio.txt
I will unpack/decopmpose now the newer android firmware . (H618.apollo-p3.T-H618_100M_12_FD650.2023.09.13.17.20.img)
Hmm Unpacked Firmware files for Bluetooth, seems to be the same and on newer firmware.
But this time i will share the whole vendor/etc folder because i see that it contains some configuration files about bt and wifi and other hardware from the vendor
so probably we may extract very useful information about box configuration by study on it.
You can download it here : https://easyupload.io/sdd0a0
My current Bluetooth state is this:
rafman@orion-8k:~$ bluetoothctl
Agent registered
[bluetooth]# show
    Alias: orion-8k
    Class: 0x00000000
    Powered: yes
    Discoverable: yes
    DiscoverableTimeout: 0x00000000
    Pairable: yes
    UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
    UUID: OBEX Object Push          (00001105-0000-1000-8000-00805f9b34fb)
    UUID: Message Access Server     (00001132-0000-1000-8000-00805f9b34fb)
    UUID: IrMC Sync                 (00001104-0000-1000-8000-00805f9b34fb)
    UUID: Vendor specific           (00005005-0000-1000-8000-0002ee000001)
    UUID: Headset                   (00001108-0000-1000-8000-00805f9b34fb)
    UUID: Phonebook Access Server   (0000112f-0000-1000-8000-00805f9b34fb)
    UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
    UUID: Handsfree Audio Gateway   (0000111f-0000-1000-8000-00805f9b34fb)
    UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
    UUID: OBEX File Transfer        (00001106-0000-1000-8000-00805f9b34fb)
    Discovering: no
    Roles: central
    Roles: peripheral
Edited by rafman
@rafman these files are the same of here https://github.com/armbian/firmware/tree/master so i think they are irrelevant.
But the bluetooth of the android image works nice. So we are not seeing anything in that rom.
Im not an expert but it posible to get the starting system log on that android installation and look how the drivers and firmware is loading?. I have a live vontar in the living room with android.
if vontar has the same chip Every information/log will be usefull. But i don't have any live android (Transpeed-k8-t box).
I attach here my partial working firmware files, if you want to test it with your kernel.
part-working-fw.tar.gz
@rafman After copying your files. the result is:
[    6.247309] Bluetooth: Core ver 2.22
[    6.247463] NET: Registered PF_BLUETOOTH protocol family
[    6.247467] Bluetooth: HCI device and connection manager initialized
[    6.247487] Bluetooth: HCI socket layer initialized
[    6.247494] Bluetooth: L2CAP socket layer initialized
[    6.247510] Bluetooth: SCO socket layer initialized
[    6.271803] Bluetooth: HCI UART driver ver 2.3
[    6.271847] Bluetooth: HCI UART protocol H4 registered
[    6.271851] Bluetooth: HCI UART protocol BCSP registered
[    6.272026] Bluetooth: HCI UART protocol LL registered
[    6.272031] Bluetooth: HCI UART protocol ATH3K registered
[    6.272063] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    6.272291] Bluetooth: HCI UART protocol Intel registered
[    6.272407] Bluetooth: HCI UART protocol Broadcom registered
[    6.272451] Bluetooth: HCI UART protocol QCA registered
[    6.272455] Bluetooth: HCI UART protocol AG6XX registered
[    6.272516] Bluetooth: HCI UART protocol Marvell registered
[    6.633454] Bluetooth: hci0: BCM: chip id 68
[    6.635949] Bluetooth: hci0: BCM: features 0x0f
[    6.659453] Bluetooth: hci0: BCM4334B0
[    6.659501] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[    6.661385] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   12.446784] Bluetooth: hci0: BCM: features 0x0f
[   12.470398] Bluetooth: hci0: BCM4334B0 37.4MHz Class1.5 Samsung Note8-1675
[   12.470428] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1718
[   13.079670] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.079706] Bluetooth: BNEP filters: protocol multicast
[   13.079726] Bluetooth: BNEP socket layer initialized
[   13.090355] Bluetooth: MGMT ver 1.22
[   13.434862] Bluetooth: RFCOMM TTY layer initialized
[   13.434921] Bluetooth: RFCOMM socket layer initialized
[   13.434952] Bluetooth: RFCOMM ver 1.11
[   15.460611] Bluetooth: hci0: Opcode 0x0c56 failed: -110
[   15.460703] Bluetooth: hci0: command 0x0c56 tx timeout
[   17.476600] Bluetooth: hci0: command 0x0c56 tx timeout
[   17.476678] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   19.492752] Bluetooth: hci0: command 0x0c56 tx timeout
[   19.492814] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   21.508663] Bluetooth: hci0: command 0x0c56 tx timeout
[   21.510448] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   23.460485] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   23.460577] Bluetooth: hci0: command 0x0c56 tx timeout
[   25.475854] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   25.475889] Bluetooth: hci0: command 0x0c56 tx timeout
[   27.491587] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   27.491652] Bluetooth: hci0: command 0x0c56 tx timeout
[   27.491688] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   29.511589] Bluetooth: hci0: command 0x0c56 tx timeout
[   29.511586] Bluetooth: hci0: Opcode 0x0c13 failed: -110
[   31.523635] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   31.523658] Bluetooth: hci0: command 0x0c56 tx timeout
[   33.539704] Bluetooth: hci0: command 0x0c56 tx timeout
[   33.539812] Bluetooth: hci0: Opcode 0x0c13 failed: -110
[   35.555751] Bluetooth: hci0: command 0x0c56 tx timeout
[   35.555883] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[   37.571821] Bluetooth: hci0: command 0x0c56 tx timeout
root@transpeed-8k618-t:~# bluetoothctl show
	Class: 0x00000000
	Powered: no
	PowerState: on
	Discoverable: no
	Pairable: no
	Discovering: no
	Roles: central
	Roles: peripheral
root@transpeed-8k618-t:~# bluetoothctl scan on
root@transpeed-8k618-t:~# uname -r
6.9.12-edge-sunxi64
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
