OS: Armbian 26.8.3 trixie aarch64 Host: Tanix TX6s (axp313) Kernel: Linux 6.18.44-current-sunxi64 firepower@tanix-tx6s-axp313:~/tm16xx-display$ make module make EXTRA_CFLAGS="-DCONFIG_TM16XX -DCONFIG_TM16XX_KEYPAD -DCONFIG_TM16XX_I2C -DCONFIG_TM16XX_SPI -include /home/firepower/tm16xx-display/drivers/auxdisplay/tm16xx_compat.h -I/home/firepower/tm16xx-display/include/" -C /lib/modules/6.18.44-current-sunxi64/build M=/home/firepower/tm16xx-display/drivers/auxdisplay CONFIG_TM16XX=m CONFIG_TM16XX_KEYPAD=y CONFIG_TM16XX_I2C=m CONFIG_TM16XX_SPI=m CONFIG_LINEDISP=m modules make[1]: Entering directory '/usr/src/linux-headers-6.18.44-current-sunxi64' make[2]: Entering directory '/home/firepower/tm16xx-display/drivers/auxdisplay' warning: the compiler differs from the one used to build the kernel The kernel was built by: aarch64-linux-gnu-gcc (Debian 14.2.0-19) 14.2.0 You are using: gcc (Debian 14.2.0-19) 14.2.0 make[4]: *** No rule to make target 'charlcd.o', needed by './'. Stop. make[3]: *** [/usr/src/linux-headers-6.18.44-current-sunxi64/Makefile:2052: .] Error 2 make[2]: *** [/usr/src/linux-headers-6.18.44-current-sunxi64/Makefile:248: __sub-make] Error 2 make[2]: Leaving directory '/home/firepower/tm16xx-display/drivers/auxdisplay' make[1]: *** [Makefile:248: __sub-make] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-6.18.44-current-sunxi64' make: *** [Makefile:50: module] Error 2
- Help wanted to test a new OpenVFD alternative
Armbian For Tanix TX6S (H616)
I compiled from source edge kernel and noble with cinnamon desktop kept freezing. I then compiled stable kernal and trixie with cinnamon desktop and works reliably. I have also installed openVFD and tanix vfd DTS overlay and also IR remote key map Have bee unable to get bluetooth working SP6330. with correct firmware BCM4330B1.hcd , Bluetooth drivers installs but bluetooth device wont start. (same wifi and bluetooth firmware as android tvbox uses) if i use another similar BCM4330B1.hcd file it install drivers and bluetooth device starts and detect connected bluetooth devices, but still bad as data is choppy for blue tooth audio.
Allwinner H618 FX-H618-D4_V10 – PhoenixSuit stuck / SD boot ignored
I copied armbian to my TV box rom, and want to reinstall original android image to rom. I have exact same issue. cant upgrade original android rom. is there away for armbian to install original image or format rom to original format android expects ? I need to check the original android DTS and wifi firmware as i can not get my BlueTooth to work even though using correct broadcom firmware.
deleted
How to install armbian in h618?
will do, I also trying official armbian build for tanix-tx6s-axp313 which boots but freezes after few minutes, where as your older build is stable. any chance of your builds making it into mainline armbian ? looking forward to a newer build. I see now Radxa Cubie A7A/A7Z is the new favourite. I been having a break from armbian but want to get back into it again.
- Armbian For Tanix TX6S (H616)
I had to modify display format to suit Tanix Tx6 with PCB on Top. Here is DTS file for Tanix TX6 Hope this is Useful to you and you can add to official armbian build.- Armbian For Tanix TX6S (H616)
here is how to get VFD Clock working on Vontar H618 pcb on bottom.- How to install armbian in h618?
trying to build armbian image using v20250306 for vontar-h618 but getting error: Could not find package filename for 'base-files' in distro repo [ looking for base-files, found_package_filename is ] [🚸] Command failed, retrying in 15s [ apt_find_upstream_package_version_and_download_url base-files ] [🚸] Command failed 10 times, giving up [ apt_find_upstream_package_version_and_download_url base-files ] [💥] Cleaning up [ please wait for cleanups to finish ]- How to install armbian in h618?
@svyatoslav Recommended usb wifi. https://github.com/morrownr/USB-WiFi- How to install armbian in h618?
@svyatoslav https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/20/#findComment-217879- How to install armbian in h618?
There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/20/#findComment-217879 - Armbian For Tanix TX6S (H616)
