Skip to content
View in the app
Armbian Community Forums
Featured Replies
your adapter is not powered.
sudo bluetoothctl power on
you receive (Changing power on succeeded) or error ?
root@transpeed-8k618-t:~# bluetoothctl power on
[CHG] Controller 43:34:B0:00:1F:AC PowerState: off-enabling
Agent registered
[CHG] Controller 43:34:B0:00:1F:AC Pairable: yes
AdvertisementMonitor path registered
[bluetooth]# scan on
Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]#
@rafman
FYII: if i delete BCM4334B0.hcd there is no errors in dmesg. and all the commands works without erros in bluetoothctl. But i dont get any result when "scan" o "devices" so its the same. no works.
like this when no "bcm4334b0.hcd":
^[[Aroot@transpeed-8k618-t:~# dmesg | grep -i bluetooth
[    5.610492] Bluetooth: Core ver 2.22
[    5.610614] NET: Registered PF_BLUETOOTH protocol family
[    5.610619] Bluetooth: HCI device and connection manager initialized
[    5.610636] Bluetooth: HCI socket layer initialized
[    5.610644] Bluetooth: L2CAP socket layer initialized
[    5.610660] Bluetooth: SCO socket layer initialized
[    5.638749] Bluetooth: HCI UART driver ver 2.3
[    5.638781] Bluetooth: HCI UART protocol H4 registered
[    5.638786] Bluetooth: HCI UART protocol BCSP registered
[    5.638893] Bluetooth: HCI UART protocol LL registered
[    5.638898] Bluetooth: HCI UART protocol ATH3K registered
[    5.638929] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.639088] Bluetooth: HCI UART protocol Intel registered
[    5.639183] Bluetooth: HCI UART protocol Broadcom registered
[    5.639213] Bluetooth: HCI UART protocol QCA registered
[    5.639218] Bluetooth: HCI UART protocol AG6XX registered
[    5.639243] Bluetooth: HCI UART protocol Marvell registered
[    5.997577] Bluetooth: hci0: BCM: chip id 68
[    6.000063] Bluetooth: hci0: BCM: features 0x0f
[    6.023468] Bluetooth: hci0: BCM4334B0
[    6.023498] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[    6.023720] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[    6.023727] Bluetooth: hci0: BCM: 'brcm/BCM4334B0.transpeed,8k618-t.hcd'
[    6.023733] Bluetooth: hci0: BCM: 'brcm/BCM4334B0.hcd'
[    6.023738] Bluetooth: hci0: BCM: 'brcm/BCM.transpeed,8k618-t.hcd'
[    6.023743] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[   12.555772] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   12.555804] Bluetooth: BNEP filters: protocol multicast
[   12.555824] Bluetooth: BNEP socket layer initialized
[   12.562835] Bluetooth: MGMT ver 1.22
[   12.824668] Bluetooth: RFCOMM TTY layer initialized
[   12.824718] Bluetooth: RFCOMM socket layer initialized
[   12.824739] Bluetooth: RFCOMM ver 1.11
Agent registered
[CHG] Controller 36:E3:66:EB:FE:ED Pairable: yes
[bluetooth]# power on
[bluetooth]# show
Controller 36:E3:66:EB:FE:ED (public)
	Alias: transpeed-8k618-t
	Class: 0x00400000
	Powered: yes
	PowerState: on
	Discoverable: no
	DiscoverableTimeout: 0x000000b4
	Pairable: yes
	UUID: SIM Access                (0000112d-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
	UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
	UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
	UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
	UUID: Volume Control            (00001844-0000-1000-8000-00805f9b34fb)
	UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
	Modalias: usb:v1D6Bp0246d0542
	Discovering: no
	Roles: central
	Roles: peripheral
Advertising Features:
	ActiveInstances: 0x00 (0)
	SupportedInstances: 0x05 (5)
	SupportedIncludes: tx-power
	SupportedIncludes: appearance
	SupportedIncludes: local-name
	SupportedCapabilities Key: MaxAdvLen
	SupportedCapabilities Value: 0x1f (31)
	SupportedCapabilities Key: MaxScnRspLen
Advertisement Monitor Features:
	SupportedMonitorTypes: or_patterns
[bluetooth]# devices
Discovery started
[CHG] Controller 36:E3:66:EB:FE:ED Discovering: yes
[bluetooth]# discoverable on
Changing discoverable on succeeded
[CHG] Controller 36:E3:66:EB:FE:ED Discoverable: yes
[bluetooth]#
Edited by MMorales
replace the  BCM4334B0.hcd  (don't delete it)  / Reboot
When is powered on --> (Changing power on succeeded)
give :  discoverable on
 USE your mobile phone, activate bluetooth, end discover for devices.
can you see your TV-box  from your mobile ?
if yes then it work as mine.
Edited by rafman
1 minute ago, MMorales said:
I tried all. No works on mine. I think is for the diff on kernel
your device is not descoverable
give :
and retry with your phone.
I do the same and  the adapter seems to work fine now (better than before)
rafman@orion-8k:~$ sudo hciconfig -a
hci0:    Type: Primary  Bus: UART
    BD Address: 00:0E:42:C3:DC:50  ACL MTU: 1021:8  SCO MTU: 64:1
    UP RUNNING PSCAN
    RX bytes:1945 acl:0 sco:0 events:129 errors:0
    TX bytes:4194 acl:0 sco:0 commands:123 errors:0
    Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
    Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
    Link policy: RSWITCH SNIFF
    Link mode: PERIPHERAL ACCEPT
    Class: 0x6c0000
    Service Classes: Rendering, Capturing, Audio, Telephony
    Device Class: Miscellaneous,
    HCI Version: 4.0 (0x6)  Revision: 0x0
    LMP Version: 4.0 (0x6)  Subversion: 0x410d
    Manufacturer: Broadcom Corporation (15)
but  i have no discovery results.
Something is problematic with BCM4334B0.hcd or with the driver / patch.
@Nick A
After a lot of searching i found a thread with a similar problem  (bug) on arch it started to happens (with 6.6.2 kernel)
read here: https://bbs.archlinux.org/viewtopic.php?id=290578
my dmesg errors are same
[   27.873839] Bluetooth: hci0: command 0x0c24 tx timeout
[   27.873844] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   39.306413] Bluetooth: hci0: command 0x0c24 tx timeout
[   39.306412] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   41.322433] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[   41.322455] Bluetooth: hci0: command 0x0c24 tx timeout
I don't know if it remains and affects us.
Edited by rafman
Here are the Allwinner BSP kernel drivers if you want to dive deep into the rabbit hole.
git clone https://github.com/AvaotaSBC/linux.git --depth=1
Have you tried a newer version of bluez?
https://packages.debian.org/search?arch=arm64&keywords=bluez
https://github.com/bluez/bluez/tree/master
https://github.com/bluez/bluez/blob/bd7d49d54aa3aa490ebdd67b3dd2317d29213d45/monitor/bt.h#L1488
#define BT_HCI_CMD_WRITE_EXT_INQUIRY_RESPONSE	0x0c52
struct bt_hci_cmd_write_ext_inquiry_response {
	uint8_t  fec;
	uint8_t  data[240];
} __attribute__ ((packed));
https://github.com/bluez/bluez/blob/bd7d49d54aa3aa490ebdd67b3dd2317d29213d45/monitor/bt.h#L1271C1-L1274C28
#define BT_HCI_CMD_WRITE_CLASS_OF_DEV		0x0c24
struct bt_hci_cmd_write_class_of_dev {
	uint8_t  dev_class[3];
https://github.com/bluez/bluez/blob/bd7d49d54aa3aa490ebdd67b3dd2317d29213d45/monitor/packet.c#L5920
static void write_ext_inquiry_response_cmd(const void *data, uint8_t size)
	const struct bt_hci_cmd_write_ext_inquiry_response *cmd = data;
	print_fec(cmd->fec);
	print_eir(cmd->data, sizeof(cmd->data), false);
https://kernel.googlesource.com/pub/scm/bluetooth/bluez/+/5.7/monitor/packet.c#4070
	{ 0x0c52, 137, "Write Extended Inquiry Response",
				write_ext_inquiry_response_cmd, 241, true,
				status_rsp, 1, true },
https://github.com/bluez/bluez/blob/bd7d49d54aa3aa490ebdd67b3dd2317d29213d45/monitor/packet.c#L5565
static void write_class_of_dev_cmd(uint16_t index, const void *data,
							uint8_t size)
	const struct bt_hci_cmd_write_class_of_dev *cmd = data;
	print_dev_class(cmd->dev_class);
https://kernel.googlesource.com/pub/scm/bluetooth/bluez/+/5.7/monitor/packet.c#4015
	{ 0x0c24,  73, "Write Class of Device",
				write_class_of_dev_cmd, 3, true,
You can ask the bluez developers for help.
https://github.com/bluez/bluez/issues
Edited by Nick A
one important point on the BT module is that the frequency setting in the xxxxx-sdio.txt needs to match the speed of the oscillator sitting beside the BT module.
There seem to be to common frequency's, 26 and 37.4 MHz.
My transpeed uses "xtalfreq=26000". The corresponding link is:
brcmfmac4330-sdio.transpeed,8k618-t.txt -> brcmfmac-ap6330-sdio.txt
My
brcmfmac4330-sdio.transpeed,8k618-t.txt -> xtalfreq=37400
The kernel people are not really happy with the patch to introduce the RTC auto calibration.
The right way to go is using the existing code from the newer sunxi-ng source instead of adding the H616/H618
into the drivers/rtc/rtc-sun6i.c.
I have to admit that I only partially understood the code in both places.
Unfortunately the current code in drivers/clk/sunxi-ng/ccu-sun6i-rtc.c ends up with a completely unreliable box.
Crashes and hangs during startup and only occasionally a successful boot.
To get around that I have to patch ccu-sun6i-rtc.c the following way:
Quote
--- a/drivers/clk/sunxi-ng/ccu-sun6i-rtc.c
+++ b/drivers/clk/sunxi-ng/ccu-sun6i-rtc.c
@@ -202,7 +202,7 @@ static const struct clk_hw *osc32k_parents[] = {
 static struct clk_init_data osc32k_init_data = {
-       .name           = "osc32k",
+       .name           = "osc32k-out",
        .ops            = &ccu_mux_ops,
        .parent_hws     = osc32k_parents,
        .num_parents    = ARRAY_SIZE(osc32k_parents), /* updated during
probe */
@@ -271,13 +271,13 @@ static struct ccu_mux osc32k_fanout_clk = {
My problem is that I have no idea why this change works :(
Any idea is welcome.
Thanks for the update afiftyp. I'll give it a try.  I thought maybe the issue was with my dts settings. Bluetooth only works when I boot into android and enable bluetooth. Then reboot back to Armbian. I don't use bluetooth much so I haven't looked into it.
This code is from orange pi zero 2.
https://github.com/NickAlilovic/build/blob/74d622f5b071acae4b61904e15f3da2f055c2167/patch/kernel/archive/sunxi-6.1/patches.armbian/arm64-dts-h616-add-wifi-support-for-orange-pi-zero-2.patch#L43
wifi_pwrseq: wifi-pwrseq {
+        compatible = "mmc-pwrseq-simple";
+        clocks = <&rtc 1>;
+        clock-names = "osc32k-out";
+        reset-gpios = <&pio 6 18 GPIO_ACTIVE_LOW>; /* PG18 */
+        post-power-on-delay-ms = <200>;
My code is similar to orange pie. But I have a pinctrl-0 = <&x32clk_fanout_pin>; and no delay.
https://github.com/NickAlilovic/build/blob/74d622f5b071acae4b61904e15f3da2f055c2167/patch/kernel/archive/sunxi-6.7/patches.armbian/arm64-dts-allwinner-h618-add-Transpeed-8K618-T-TV-box.patch#L121C1-L128C12
+	wifi_pwrseq: wifi_pwrseq {
+                clocks = <&rtc CLK_OSC32K_FANOUT>;
+                clock-names = "ext_clock";
+                pinctrl-0 = <&x32clk_fanout_pin>;
+                pinctrl-names = "default";
This part confuses me..
I think it should be
Only the Armbian patches use "osc32k-out" for wifi_pwrseq clock names.
I guess you can name it whatever you like it will always use &rtc 1 or &rtc CLK_OSC32K_FANOUT.
https://github.com/torvalds/linux/blob/8e929cb546ee42c9a61d24fae60605e9e3192354/include/dt-bindings/clock/sun6i-rtc.h
https://github.com/torvalds/linux/blob/8e929cb546ee42c9a61d24fae60605e9e3192354/drivers/mmc/core/pwrseq_simple.c#L120C20-L120C50
	pwrseq->ext_clk = devm_clk_get(dev, "ext_clock");
	if (IS_ERR(pwrseq->ext_clk) && PTR_ERR(pwrseq->ext_clk) != -ENOENT)
		return dev_err_probe(dev, PTR_ERR(pwrseq->ext_clk), "external clock not ready\n");
However, I did find the clock name "osc32k-out" in the RTC portion of  h6.dtsi. The h616.dtsi doesn't have any clock-output-names.
		rtc: rtc@7000000 {
			compatible = "allwinner,sun50i-h6-rtc";
			reg = <0x07000000 0x400>;
			interrupt-parent = <&r_intc>;
			interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
			clock-output-names = "osc32k", "osc32k-out", "iosc";
			#clock-cells = <1>;
Also here.
https://github.com/torvalds/linux/blob/6485cf5ea253d40d507cd71253c9568c5470cd27/drivers/rtc/rtc-sun6i.c#L232
static void __init sun6i_rtc_clk_init(struct device_node *node,
				      const struct sun6i_rtc_clk_data *data)
	struct clk_hw_onecell_data *clk_data;
	struct sun6i_rtc_dev *rtc;
	struct clk_init_data init = {
		.ops		= &sun6i_rtc_osc_ops,
		.name		= "losc",
	const char *iosc_name = "rtc-int-osc";
	const char *clkout_name = "osc32k-out";
	const char *parents[2];
	u32 reg;
	of_property_read_string_index(node, "clock-output-names", 1,
				      &clkout_name);
	rtc->ext_losc = clk_register_gate(NULL, clkout_name, init.name,
					  0, rtc->base + SUN6I_LOSC_OUT_GATING,
					  SUN6I_LOSC_OUT_GATING_EN_OFFSET, 0,
					  &rtc->lock);
Because the there's no "clock-output-names" in the h616.dtsi.. char *clkout_name = "osc32k-out"; does not change.
Maybe you accidentally used the rtc-sun6i.c clock.
Edited by Nick A
Nick, i can do a patch, but I really would like to understand why this change makes it work. In the end it would be less patching.
Our sun50i-h618-transpeed-8k618-t.dtb does not have "osc32k" nor "osc32k-out" so i don't think it is dtb related.
To try it, it is two additional changes:
- change kernel config to CONFIG_SUN6I_RTC_CCU=y
- remove the tree patches:
        patches.armbian/drv-rtc-sun6i-support-RTCs-without-external-LOSCs.patch
        patches.armbian/drv-rtc-sun6i-Add-Allwinner-H616-support.patch
        patches.armbian/Code-to-enable-Internal-OSC-Clock-Auto-Calibration.patch
rtc-sun6i.c is still in place but it simply calls the new code in drivers/clk/sunxi-ng/ccu-sun6i-rtc.c as it no longer finds a usable RTC.
Unfortunately I do not have a H616 to test how it behaves here.
Edited by afiftyp
Add info
FYI:
in the meantime of Expecting some answer from bluez guys, I download / compile and install the latest version (5.78) of bluez from
their site.  With the latest version i have no ( TX Errors 0x0c24)  (using either android or debian firmware)
But  now i have -->  Bluetooth: hci0: Opcode 0x0c03 failed: -110 (on both firmware) and no discoverable Device.
rafman@orion-8k:~$ dmesg|grep -i blue
[    6.263046] Bluetooth: Core ver 2.22
[    6.263152] NET: Registered PF_BLUETOOTH protocol family
[    6.263158] Bluetooth: HCI device and connection manager initialized
[    6.263178] Bluetooth: HCI socket layer initialized
[    6.263188] Bluetooth: L2CAP socket layer initialized
[    6.263204] Bluetooth: SCO socket layer initialized
[    6.440666] Bluetooth: HCI UART driver ver 2.3
[    6.440696] Bluetooth: HCI UART protocol H4 registered
[    6.440701] Bluetooth: HCI UART protocol BCSP registered
[    6.440805] Bluetooth: HCI UART protocol LL registered
[    6.440810] Bluetooth: HCI UART protocol ATH3K registered
[    6.440840] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    6.441010] Bluetooth: HCI UART protocol Intel registered
[    6.441112] Bluetooth: HCI UART protocol Broadcom registered
[    6.441146] Bluetooth: HCI UART protocol QCA registered
[    6.441152] Bluetooth: HCI UART protocol AG6XX registered
[    6.441182] Bluetooth: HCI UART protocol Marvell registered
[    6.764123] systemd[1]: Reached target bluetooth.target - Bluetooth Support.
[    6.813233] Bluetooth: hci0: BCM: chip id 68
[    6.819051] Bluetooth: hci0: BCM: features 0x0f
[    6.842499] Bluetooth: hci0: BCM4334B0
[    6.842526] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[    6.854934] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   12.833302] Bluetooth: hci0: BCM: features 0x0f
[   12.857635] Bluetooth: hci0: BCM4334B0 37.4MHz Class1.5 Samsung Note8-1675
[   12.857665] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1718
[   78.123328] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   78.123353] Bluetooth: BNEP filters: protocol multicast
[   78.123371] Bluetooth: BNEP socket layer initialized
[   78.126292] Bluetooth: MGMT ver 1.22
[   80.164838] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[  201.031249] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[  271.432754] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[  277.992897] Bluetooth: hci0: Opcode 0x0c03 failed: -110
rafman@orion-8k:~$ bluetoothctl
hci0 new_settings: bondable ssp br/edr le secure-conn
[bluetooth]# Agent registered
[bluetooth]# [CHG] Controller 43:34:B0:00:1F:AC Pairable: yes
[bluetooth]# version
Version 5.78
[bluetooth]# [CHG] Controller 43:34:B0:00:1F:AC PowerState: off-enabling
[bluetooth]# Failed to set power on: org.bluez.Error.Failed
[bluetooth]# [CHG] Controller 43:34:B0:00:1F:AC PowerState: on
[bluetooth]# Failed to set discoverable on: org.bluez.Error.Failed
[bluetooth]# exit
rafman@orion-8k:~$
So  i am Returning to bluez 5.66 :(
I have Tanix Tx6 and now a Vontar H618. which just arrived. I will check out your build. I cant even detect Bluetooth device. I need to dump my android DTS.
looking at the AP6330 (SP6330) datasheet
wifi/bt chip uses External Low Power Clock input (32.768KHz) and External Xtal Osc 26MHz.
AP6330.pdf
Edited by firepower
@MMorales @Nick A Hi, I already success with Jefflessard version of openVfd with some minor error with my build, can check the forum if you try and have problem:
Just in case you interested, I prefer it because it starting to display something when driver initialized so we early know the box starting and not hang up :) then can display timer or whatever you like after.. and setting just via bash scripting than writing other language code :)
Vontar H618
PCB: FX-H618-D4_V10  23-03-21
Ram: 4GB (8 x K4B4G0446B HCK0)
Rom: 64GB (KLMCG4JENB )
Wifi: HK6334Q Osc: 37.4MHz
LED: FD650B-S
PMIC: AXP313A
Android 12 is much better than Android 9 on my Tanix Tx6, better ui and more responsive.
I will test with default transpeed-8k618-t image.
Edited by firepower
Just FYI @Nick A While working further with Jefflessard I found that all modules in your build not included in images created, Tough it compiles as module and already make the .ko file in the /sources/linux-kernel-worktree/devices. I dont know it is by design or not.. while Im afraid to update linux-kernel-image so I just copy (some modules).ko to /lib/modules/6.7.12-edge-sunxi64 run depmod and its ready to modprobe :)
thanks @L Jumadi i will give a try when i can. btw i attach a benchmark to the transpeed 4g-64 h618 for archive purpose
Quote
sbc-bench v0.9.67 Transpeed 8K618-T (Wed, 16 Oct 2024 11:40:59 +0200)
Distributor ID:	Debian
Description:	Armbian-unofficial 24.11.0-trunk bookworm
Release:	12
Codename:	bookworm
Build system:   https://github.com/NickAlilovic/build.git, 24.11.0-trunk, Transpeed 8k618-t, sun50iw9, sunxi64
/usr/bin/gcc (Debian 12.2.0-14) 12.2.0
Uptime: 11:40:59 up 9 min,  3 users,  load average: 0.99, 0.97, 0.51,  °C,  364239016
Linux 6.10.10-edge-sunxi64 (transpeed-8k618-t) 	10/16/24 	_aarch64_	(4 CPU)
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          15.24    0.06    2.40    3.26    0.00   79.04
Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
mmcblk1          21.95       641.63       422.69         0.00     368293     242624          0
mmcblk2           0.45        12.73         0.00         0.00       7308          0          0
zram0             0.09         2.08         0.01         0.00       1192          4          0
zram1             0.45         0.73         5.91         0.00        420       3392          0
               total        used        free      shared  buff/cache   available
Mem:           3.8Gi       281Mi       3.6Gi       5.6Mi        75Mi       3.6Gi
Swap:          1.9Gi          0B       1.9Gi
Filename				Type		Size		Used		Priority
/dev/zram0                              partition	2012780		0		5
Checking cpufreq OPP (Cortex-A53):
Cpufreq OPP: 1416    Measured: 1413 (1414.040/1413.970/1413.740)
Cpufreq OPP: 1320    Measured: 1318 (1318.178/1318.112/1318.046)
Cpufreq OPP: 1200    Measured: 1197 (1198.000/1197.955/1197.940)
Cpufreq OPP: 1104    Measured: 1101 (1101.979/1101.965/1101.937)
Cpufreq OPP: 1008    Measured: 1005 (1006.017/1005.942/1005.514)
Cpufreq OPP:  936    Measured:  933    (933.983/933.890/933.750)
Cpufreq OPP:  720    Measured:  717    (717.999/717.990/717.819)
Cpufreq OPP:  480    Measured:  477    (478.001/477.995/477.941)
Executing benchmark on cpu0 (Cortex-A53):
tinymembench v0.4.9-nuumio (simple benchmark for memory throughput and latency)
CFLAGS:
bandwidth test min repeats (-b): 2
bandwidth test max repeats (-B): 3
bandwidth test mem realloc (-M): no      (-m for realloc)
      latency test repeats (-l): 3
        latency test count (-c): 1000000
== Memory bandwidth tests                                               ==
== Note 1: 1MB = 1000000 bytes                                          ==
== Note 2: Test result is the best of repeated runs. Number of repeats  ==
==         is shown in brackets                                         ==
== Note 3: Results for 'copy' tests show how many bytes can be          ==
==         copied per second (adding together read and writen           ==
==         bytes would have provided twice higher numbers)              ==
== Note 4: 2-pass copy means that we are using a small temporary buffer ==
==         to first fetch data into it, and only then write it to the   ==
==         destination (source -> L1 cache, L1 cache -> destination)    ==
== Note 5: If sample standard deviation exceeds 0.1%, it is shown in    ==
==         brackets                                                     ==
 C copy backwards                                 :   1225.1 MB/s (3, 8.7%)
 C copy backwards (32 byte blocks)                :   1231.9 MB/s (3, 0.6%)
 C copy backwards (64 byte blocks)                :   1223.8 MB/s (3, 0.1%)
 C copy                                           :   1191.8 MB/s (3, 0.5%)
 C copy prefetched (32 bytes step)                :    952.1 MB/s (3, 1.2%)
 C copy prefetched (64 bytes step)                :   1036.7 MB/s (3)
 C 2-pass copy                                    :   1115.5 MB/s (2)
 C 2-pass copy prefetched (32 bytes step)         :    784.9 MB/s (2)
 C 2-pass copy prefetched (64 bytes step)         :    733.4 MB/s (3, 0.2%)
 C scan 8                                         :    275.9 MB/s (2)
 C scan 16                                        :    539.6 MB/s (3, 0.3%)
 C scan 32                                        :   1007.9 MB/s (3, 0.2%)
 C scan 64                                        :   1501.3 MB/s (3, 0.3%)
 C fill                                           :   3480.1 MB/s (3, 1.1%)
 C fill (shuffle within 16 byte blocks)           :   3490.3 MB/s (3, 0.3%)
 C fill (shuffle within 32 byte blocks)           :   3488.3 MB/s (2)
 C fill (shuffle within 64 byte blocks)           :   3489.9 MB/s (2)
 libc memcpy copy                                 :   1226.4 MB/s (2)
 libc memchr scan                                 :   1445.5 MB/s (3, 0.5%)
 libc memset fill                                 :   3482.6 MB/s (3, 1.1%)
 NEON LDP/STP copy                                :   1236.5 MB/s (3, 0.6%)
 NEON LDP/STP copy pldl2strm (32 bytes step)      :    849.6 MB/s (3, 1.3%)
 NEON LDP/STP copy pldl2strm (64 bytes step)      :   1063.3 MB/s (2)
 NEON LDP/STP copy pldl1keep (32 bytes step)      :   1379.1 MB/s (3)
 NEON LDP/STP copy pldl1keep (64 bytes step)      :   1377.2 MB/s (3, 0.8%)
 NEON LD1/ST1 copy                                :   1224.9 MB/s (3, 0.5%)
 NEON LDP load                                    :   1979.7 MB/s (2)
 NEON LDNP load                                   :   1567.4 MB/s (3, 0.1%)
 NEON STP fill                                    :   3489.9 MB/s (3, 0.5%)
 NEON STNP fill                                   :   2086.8 MB/s (3, 1.0%)
 ARM LDP/STP copy                                 :   1236.5 MB/s (3, 0.3%)
 ARM LDP load                                     :   1981.3 MB/s (2)
 ARM LDNP load                                    :   1567.4 MB/s (3, 0.1%)
 ARM STP fill                                     :   3490.1 MB/s (3, 0.6%)
 ARM STNP fill                                    :   2093.3 MB/s (3, 1.5%)
== Framebuffer read tests.                                              ==
== Many ARM devices use a part of the system memory as the framebuffer, ==
== typically mapped as uncached but with write-combining enabled.       ==
== Writes to such framebuffers are quite fast, but reads are much       ==
== slower and very sensitive to the alignment and the selection of      ==
== CPU instructions which are used for accessing memory.                ==
== Many x86 systems allocate the framebuffer in the GPU memory,         ==
== accessible for the CPU via a relatively slow PCI-E bus. Moreover,    ==
== PCI-E is asymmetric and handles reads a lot worse than writes.       ==
== If uncached framebuffer reads are reasonably fast (at least 100 MB/s ==
== or preferably >300 MB/s), then using the shadow framebuffer layer    ==
== is not necessary in Xorg DDX drivers, resulting in a nice overall    ==
== performance improvement. For example, the xf86-video-fbturbo DDX     ==
== uses this trick.                                                     ==
 NEON LDP/STP copy (from framebuffer)             :    175.5 MB/s (2)
 NEON LDP/STP 2-pass copy (from framebuffer)      :    168.3 MB/s (2)
 NEON LD1/ST1 copy (from framebuffer)             :     45.2 MB/s (2)
 NEON LD1/ST1 2-pass copy (from framebuffer)      :     44.7 MB/s (3, 0.2%)
 ARM LDP/STP copy (from framebuffer)              :     89.6 MB/s (2)
 ARM LDP/STP 2-pass copy (from framebuffer)       :     87.7 MB/s (2)
== Memory latency test                                                  ==
== Average time is measured for random memory accesses in the buffers   ==
== of different sizes. The larger is the buffer, the more significant   ==
== are relative contributions of TLB, L1/L2 cache misses and SDRAM      ==
== accesses. For extremely large buffer sizes we are expecting to see   ==
== page table walk with several requests to SDRAM for almost every      ==
== memory access (though 64MiB is not nearly large enough to experience ==
== this effect to its fullest).                                         ==
== Note 1: All the numbers are representing extra time, which needs to  ==
==         be added to L1 cache latency. The cycle timings for L1 cache ==
==         latency can be usually found in the processor documentation. ==
== Note 2: Dual random read means that we are simultaneously performing ==
==         two independent memory accesses at a time. In the case if    ==
==         the memory subsystem can't handle multiple outstanding       ==
==         requests, dual random read has the same timings as two       ==
==         single reads performed one after another.                    ==
block size : single random read / dual random read, [MADV_NOHUGEPAGE]
      1024 :    0.0 ns          /     0.0 ns
      2048 :    0.0 ns          /     0.0 ns
      4096 :    0.0 ns          /     0.0 ns
      8192 :    0.0 ns          /     0.0 ns
     16384 :    0.0 ns          /     0.0 ns
     32768 :    0.1 ns          /     0.0 ns
     65536 :    4.7 ns          /     7.9 ns
    131072 :    7.3 ns          /    11.1 ns
    262144 :    8.9 ns          /    12.4 ns
    524288 :   10.4 ns          /    13.0 ns
   1048576 :   29.0 ns          /    45.4 ns
   2097152 :   99.0 ns          /   149.7 ns
   4194304 :  147.4 ns          /   196.7 ns
   8388608 :  172.8 ns          /   213.7 ns
  16777216 :  186.6 ns          /   222.0 ns
  33554432 :  194.0 ns          /   226.8 ns
  67108864 :  198.0 ns          /   229.7 ns
block size : single random read / dual random read, [MADV_HUGEPAGE]
    524288 :   10.4 ns          /    13.1 ns
   1048576 :   13.6 ns          /    14.7 ns
   2097152 :   98.3 ns          /   148.2 ns
   4194304 :  140.7 ns          /   188.3 ns
   8388608 :  162.3 ns          /   200.7 ns
  16777216 :  172.7 ns          /   205.3 ns
  33554432 :  177.9 ns          /   207.3 ns
  67108864 :  180.7 ns          /   208.0 ns
Executing ramlat on cpu0 (Cortex-A53), results in ns:
       size:  1x32  2x32  1x64  2x64 1xPTR 2xPTR 4xPTR 8xPTR
         4k: 2.842 2.865 2.134 2.126 2.122 2.123 2.918 5.924
         8k: 2.830 2.830 2.123 2.122 2.122 2.122 2.918 5.927
        16k: 2.833 2.831 2.130 2.123 2.125 2.123 2.920 5.928
        32k: 11.27 13.89 11.65 13.44 11.64 13.53 17.51 30.19
        64k: 16.75 17.23 16.01 17.04 16.01 17.20 23.18 45.06
       128k: 17.37 18.54 16.97 17.94 16.94 17.91 27.23 54.16
       256k: 20.16 20.90 19.78 20.25 19.76 20.29 27.57 54.24
       512k: 23.20 23.75 22.66 23.36 22.65 23.78 27.87 54.62
      1024k: 47.23 58.25 46.26 58.80 46.46 58.82 87.05 166.8
      2048k: 180.3 186.3 177.5 181.4 177.1 181.0 256.7 508.6
      4096k: 196.0 200.1 195.2 196.5 195.2 195.4 266.4 529.4
      8192k: 195.9 197.2 194.8 195.9 195.2 195.1 269.5 529.1
     16384k: 199.0 200.3 197.7 199.8 197.8 199.3 270.0 545.3
     32768k: 205.6 205.9 202.1 205.8 202.0 205.9 276.5 555.2
     65536k: 199.8 202.5 201.7 201.8 199.0 202.6 273.3 546.7
    131072k: 200.5 202.4 199.4 202.3 206.6 202.2 273.1 545.0
Executing benchmark twice on cluster 0 (Cortex-A53)
OpenSSL 3.0.14, built on 4 Jun 2024 (Library: OpenSSL 3.0.14 4 Jun 2024)
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes  16384 bytes
aes-128-cbc     101502.19k   316819.37k   654948.69k   927581.18k  1054894.76k  1064763.39k
aes-128-cbc     101662.68k   316789.91k   654933.59k   927563.09k  1054635.35k  1056593.24k
aes-192-cbc      98116.06k   287014.10k   543429.97k   720182.27k   795118.25k   800156.33k
aes-192-cbc      97691.46k   286572.69k   542621.61k   719602.35k   794946.22k   800751.62k
aes-256-cbc      95031.92k   265476.91k   474354.01k   604318.38k   656566.95k   657462.61k
aes-256-cbc      95338.91k   266504.66k   474870.61k   604666.20k   656610.65k   660373.50k
Executing benchmark single-threaded on cpu0 (Cortex-A53)
7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE)
LE
CPU Freq: 64000000 - - - - - - - -
RAM size:    3931 MB,  # CPU hardware threads:   4
RAM usage:    435 MB,  # Benchmark threads:      1
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:        866   100    844    843  |      15743   100   1345   1344
23:        828   100    844    844  |      15422   100   1336   1335
24:        797   100    858    857  |      15094   100   1326   1325
25:        755   100    863    862  |      14708   100   1310   1309
Avr:             100    852    851  |              100   1329   1328
Tot:             100   1091   1090
Executing benchmark 3 times multi-threaded on CPUs 0-3
LE
CPU Freq: - - - - - - - - -
RAM usage:    882 MB,  # Benchmark threads:      4
22:       2345   335    680   2282  |      60703   398   1300   5179
23:       2328   351    675   2373  |      59386   399   1288   5138
24:       2288   362    681   2461  |      57999   399   1277   5092
25:       2220   371    684   2536  |      56556   399   1262   5033
Avr:             355    680   2413  |              399   1282   5111
Tot:             377    981   3762
LE
CPU Freq: - 64000000 - - - 256000000 - - -
22:       2411   343    685   2346  |      60967   399   1303   5201
23:       2320   350    675   2364  |      59463   399   1290   5145
24:       2280   361    680   2452  |      58015   399   1277   5093
25:       2226   372    684   2542  |      56666   399   1264   5043
Avr:             356    681   2426  |              399   1283   5121
Tot:             378    982   3773
LE
22:       2404   341    685   2339  |      60716   398   1301   5180
23:       2320   351    674   2364  |      59466   399   1289   5145
24:       2280   361    680   2452  |      58007   399   1277   5092
25:       2227   372    684   2543  |      56451   399   1260   5024
Avr:             356    681   2424  |              399   1282   5110
Tot:             377    981   3767
Compression: 2413,2426,2424
Decompression: 5111,5121,5110
Total: 3762,3773,3767
** cpuminer-multi 1.3.7 by tpruvot@github **
BTC donation address: 1FhDPLPpw18X4srecguG3MxJYe4a1JsZnd (tpruvot)
[2024-10-16 11:53:47] 4 miner threads started, using 'scrypt' algorithm.
[2024-10-16 11:53:47] CPU #0: 1.32 kH/s
[2024-10-16 11:53:47] CPU #3: 1.26 kH/s
[2024-10-16 11:53:47] CPU #1: 1.16 kH/s
[2024-10-16 11:53:47] CPU #2: 0.98 kH/s
[2024-10-16 11:53:52] Total: 5.24 kH/s
[2024-10-16 11:53:57] CPU #3: 1.38 kH/s
[2024-10-16 11:53:57] Total: 5.44 kH/s
[2024-10-16 11:53:57] CPU #0: 1.38 kH/s
[2024-10-16 11:53:57] CPU #2: 1.38 kH/s
[2024-10-16 11:53:57] CPU #1: 1.38 kH/s
[2024-10-16 11:54:02] Total: 5.50 kH/s
[2024-10-16 11:54:07] CPU #3: 1.38 kH/s
[2024-10-16 11:54:07] Total: 5.50 kH/s
[2024-10-16 11:54:07] CPU #0: 1.38 kH/s
[2024-10-16 11:54:07] CPU #2: 1.38 kH/s
[2024-10-16 11:54:07] CPU #1: 1.38 kH/s
[2024-10-16 11:54:12] Total: 5.50 kH/s
[2024-10-16 11:54:17] CPU #3: 1.38 kH/s
[2024-10-16 11:54:17] Total: 5.50 kH/s
[2024-10-16 11:54:17] CPU #0: 1.38 kH/s
[2024-10-16 11:54:17] CPU #2: 1.38 kH/s
[2024-10-16 11:54:17] CPU #1: 1.38 kH/s
[2024-10-16 11:54:22] Total: 5.50 kH/s
[2024-10-16 11:54:27] CPU #3: 1.38 kH/s
[2024-10-16 11:54:27] Total: 5.50 kH/s
[2024-10-16 11:54:27] CPU #0: 1.38 kH/s
[2024-10-16 11:54:27] CPU #2: 1.38 kH/s
[2024-10-16 11:54:27] CPU #1: 1.38 kH/s
[2024-10-16 11:54:32] Total: 5.50 kH/s
[2024-10-16 11:54:37] CPU #3: 1.37 kH/s
[2024-10-16 11:54:37] Total: 5.49 kH/s
[2024-10-16 11:54:37] CPU #0: 1.38 kH/s
[2024-10-16 11:54:37] CPU #2: 1.37 kH/s
[2024-10-16 11:54:37] CPU #1: 1.38 kH/s
[2024-10-16 11:54:42] Total: 5.50 kH/s
[2024-10-16 11:54:47] CPU #3: 1.38 kH/s
[2024-10-16 11:54:47] Total: 5.50 kH/s
[2024-10-16 11:54:47] CPU #0: 1.38 kH/s
[2024-10-16 11:54:47] CPU #2: 1.38 kH/s
[2024-10-16 11:54:47] CPU #1: 1.38 kH/s
[2024-10-16 11:54:52] Total: 5.50 kH/s
[2024-10-16 11:54:57] CPU #3: 1.38 kH/s
[2024-10-16 11:54:57] Total: 5.50 kH/s
[2024-10-16 11:54:57] CPU #0: 1.38 kH/s
[2024-10-16 11:54:57] CPU #2: 1.38 kH/s
[2024-10-16 11:54:57] CPU #1: 1.38 kH/s
[2024-10-16 11:55:02] Total: 5.50 kH/s
[2024-10-16 11:55:07] CPU #3: 1.38 kH/s
[2024-10-16 11:55:07] Total: 5.50 kH/s
[2024-10-16 11:55:07] CPU #0: 1.38 kH/s
[2024-10-16 11:55:07] CPU #2: 1.38 kH/s
[2024-10-16 11:55:07] CPU #1: 1.38 kH/s
[2024-10-16 11:55:12] Total: 5.50 kH/s
[2024-10-16 11:55:17] CPU #3: 1.37 kH/s
[2024-10-16 11:55:17] Total: 5.50 kH/s
[2024-10-16 11:55:17] CPU #0: 1.37 kH/s
[2024-10-16 11:55:17] CPU #2: 1.37 kH/s
[2024-10-16 11:55:17] CPU #1: 1.37 kH/s
[2024-10-16 11:55:22] Total: 5.49 kH/s
[2024-10-16 11:55:27] CPU #3: 1.38 kH/s
[2024-10-16 11:55:27] Total: 5.50 kH/s
[2024-10-16 11:55:27] CPU #0: 1.38 kH/s
[2024-10-16 11:55:27] CPU #2: 1.38 kH/s
[2024-10-16 11:55:27] CPU #1: 1.37 kH/s
[2024-10-16 11:55:32] Total: 5.50 kH/s
[2024-10-16 11:55:37] CPU #3: 1.38 kH/s
[2024-10-16 11:55:37] Total: 5.50 kH/s
[2024-10-16 11:55:37] CPU #0: 1.37 kH/s
[2024-10-16 11:55:37] CPU #2: 1.38 kH/s
[2024-10-16 11:55:37] CPU #1: 1.38 kH/s
[2024-10-16 11:55:42] Total: 5.50 kH/s
[2024-10-16 11:55:47] CPU #3: 1.38 kH/s
[2024-10-16 11:55:47] Total: 5.50 kH/s
[2024-10-16 11:55:47] CPU #0: 1.37 kH/s
[2024-10-16 11:55:47] CPU #2: 1.38 kH/s
[2024-10-16 11:55:47] CPU #1: 1.38 kH/s
[2024-10-16 11:55:52] Total: 5.50 kH/s
[2024-10-16 11:55:57] CPU #3: 1.37 kH/s
[2024-10-16 11:55:57] Total: 5.50 kH/s
[2024-10-16 11:55:57] CPU #0: 1.37 kH/s
[2024-10-16 11:55:57] CPU #2: 1.37 kH/s
[2024-10-16 11:55:57] CPU #1: 1.37 kH/s
[2024-10-16 11:56:02] Total: 5.49 kH/s
[2024-10-16 11:56:07] CPU #3: 1.38 kH/s
[2024-10-16 11:56:07] Total: 5.50 kH/s
[2024-10-16 11:56:07] CPU #0: 1.38 kH/s
[2024-10-16 11:56:07] CPU #2: 1.38 kH/s
[2024-10-16 11:56:07] CPU #1: 1.38 kH/s
[2024-10-16 11:56:12] Total: 5.50 kH/s
[2024-10-16 11:56:17] CPU #3: 1.38 kH/s
[2024-10-16 11:56:17] Total: 5.50 kH/s
[2024-10-16 11:56:17] CPU #0: 1.38 kH/s
[2024-10-16 11:56:17] CPU #2: 1.38 kH/s
[2024-10-16 11:56:17] CPU #1: 1.38 kH/s
[2024-10-16 11:56:22] Total: 5.50 kH/s
[2024-10-16 11:56:27] CPU #3: 1.38 kH/s
[2024-10-16 11:56:27] Total: 5.50 kH/s
[2024-10-16 11:56:27] CPU #0: 1.38 kH/s
[2024-10-16 11:56:27] CPU #2: 1.38 kH/s
[2024-10-16 11:56:27] CPU #1: 1.38 kH/s
[2024-10-16 11:56:32] Total: 5.50 kH/s
[2024-10-16 11:56:37] CPU #3: 1.38 kH/s
[2024-10-16 11:56:37] Total: 5.50 kH/s
[2024-10-16 11:56:37] CPU #0: 1.38 kH/s
[2024-10-16 11:56:37] CPU #2: 1.38 kH/s
[2024-10-16 11:56:37] CPU #1: 1.37 kH/s
[2024-10-16 11:56:42] Total: 5.50 kH/s
[2024-10-16 11:56:47] CPU #3: 1.38 kH/s
[2024-10-16 11:56:47] Total: 5.49 kH/s
[2024-10-16 11:56:47] CPU #0: 1.38 kH/s
[2024-10-16 11:56:47] CPU #2: 1.38 kH/s
[2024-10-16 11:56:47] CPU #1: 1.38 kH/s
[2024-10-16 11:56:52] Total: 5.50 kH/s
[2024-10-16 11:56:56] CPU #3: 1.38 kH/s
[2024-10-16 11:56:56] Total: 5.50 kH/s
[2024-10-16 11:56:57] CPU #0: 1.38 kH/s
[2024-10-16 11:56:57] CPU #2: 1.38 kH/s
[2024-10-16 11:56:57] CPU #1: 1.38 kH/s
[2024-10-16 11:56:57] Total: 5.50 kH/s
[2024-10-16 11:57:03] CPU #3: 1.38 kH/s
[2024-10-16 11:57:03] Total: 5.50 kH/s
[2024-10-16 11:57:07] Total: 5.50 kH/s
[2024-10-16 11:57:07] CPU #0: 1.38 kH/s
[2024-10-16 11:57:07] CPU #2: 1.38 kH/s
[2024-10-16 11:57:07] CPU #1: 1.38 kH/s
[2024-10-16 11:57:12] CPU #3: 1.38 kH/s
[2024-10-16 11:57:12] Total: 5.50 kH/s
[2024-10-16 11:57:17] Total: 5.50 kH/s
[2024-10-16 11:57:17] CPU #0: 1.38 kH/s
[2024-10-16 11:57:17] CPU #2: 1.38 kH/s
[2024-10-16 11:57:17] CPU #1: 1.38 kH/s
[2024-10-16 11:57:22] CPU #3: 1.37 kH/s
[2024-10-16 11:57:22] Total: 5.50 kH/s
[2024-10-16 11:57:26] Total: 5.49 kH/s
[2024-10-16 11:57:27] CPU #0: 1.38 kH/s
[2024-10-16 11:57:27] CPU #2: 1.38 kH/s
[2024-10-16 11:57:27] CPU #1: 1.38 kH/s
[2024-10-16 11:57:27] Total: 5.50 kH/s
[2024-10-16 11:57:32] CPU #3: 1.38 kH/s
[2024-10-16 11:57:32] Total: 5.50 kH/s
[2024-10-16 11:57:37] CPU #0: 1.38 kH/s
[2024-10-16 11:57:37] CPU #2: 1.38 kH/s
[2024-10-16 11:57:37] CPU #1: 1.37 kH/s
[2024-10-16 11:57:37] Total: 5.50 kH/s
[2024-10-16 11:57:42] CPU #3: 1.38 kH/s
[2024-10-16 11:57:42] Total: 5.50 kH/s
[2024-10-16 11:57:47] CPU #0: 1.38 kH/s
[2024-10-16 11:57:47] CPU #2: 1.38 kH/s
[2024-10-16 11:57:47] CPU #1: 1.38 kH/s
[2024-10-16 11:57:47] Total: 5.50 kH/s
[2024-10-16 11:57:52] CPU #3: 1.38 kH/s
[2024-10-16 11:57:52] Total: 5.50 kH/s
[2024-10-16 11:57:57] CPU #0: 1.38 kH/s
[2024-10-16 11:57:57] CPU #2: 1.38 kH/s
[2024-10-16 11:57:57] CPU #1: 1.38 kH/s
[2024-10-16 11:57:57] Total: 5.50 kH/s
[2024-10-16 11:58:02] CPU #3: 1.37 kH/s
[2024-10-16 11:58:02] Total: 5.50 kH/s
[2024-10-16 11:58:07] CPU #0: 1.37 kH/s
[2024-10-16 11:58:07] CPU #2: 1.37 kH/s
[2024-10-16 11:58:07] CPU #1: 1.37 kH/s
[2024-10-16 11:58:08] CPU #3: 1.37 kH/s
[2024-10-16 11:58:08] Total: 5.49 kH/s
[2024-10-16 11:58:11] Total: 5.49 kH/s
[2024-10-16 11:58:12] Total: 5.50 kH/s
[2024-10-16 11:58:17] CPU #0: 1.38 kH/s
[2024-10-16 11:58:17] CPU #2: 1.38 kH/s
[2024-10-16 11:58:17] CPU #1: 1.38 kH/s
[2024-10-16 11:58:17] CPU #3: 1.38 kH/s
[2024-10-16 11:58:17] Total: 5.50 kH/s
[2024-10-16 11:58:22] Total: 5.50 kH/s
[2024-10-16 11:58:27] CPU #0: 1.38 kH/s
[2024-10-16 11:58:27] CPU #2: 1.38 kH/s
[2024-10-16 11:58:27] CPU #1: 1.38 kH/s
[2024-10-16 11:58:27] CPU #3: 1.38 kH/s
[2024-10-16 11:58:27] Total: 5.50 kH/s
[2024-10-16 11:58:32] Total: 5.50 kH/s
[2024-10-16 11:58:37] CPU #0: 1.38 kH/s
[2024-10-16 11:58:37] CPU #2: 1.38 kH/s
[2024-10-16 11:58:37] CPU #1: 1.38 kH/s
[2024-10-16 11:58:37] CPU #3: 1.38 kH/s
[2024-10-16 11:58:37] Total: 5.50 kH/s
[2024-10-16 11:58:42] Total: 5.50 kH/s
Total Scores: 5.50,5.49
Testing maximum cpufreq again, still under full load. System health now:
Time        CPU    load %cpu %sys %usr %nice %io %irq   Temp
11:58:46: 1416MHz  4.01 100%   0%  99%   0%   0%   0%      °C
Cpufreq OPP: 1416    Measured: 1413 (1413.983/1413.877/1413.754)
System health while running tinymembench:
11:41:37: 1416MHz  0.99  21%   2%  15%   0%   3%   0%      °C
11:41:47: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:41:57: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:08: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:18: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:28: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:38: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:48: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:42:58: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:09: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:43:19: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
System health while running ramlat:
11:43:24: 1416MHz  1.00  21%   2%  17%   0%   2%   0%      °C
11:43:27: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:30: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:33: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:36: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:43:39: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:42: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:43:46: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:43:49: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:43:52: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:43:55: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
System health while running OpenSSL benchmark:
11:43:57: 1416MHz  1.00  22%   1%  17%   0%   2%   0%      °C
11:44:13: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:44:29: 1416MHz  1.00  25%   0%  25%   0%   0%   0%      °C
11:44:45: 1416MHz  1.00  25%   0%  24%   0%   0%   0%      °C
11:45:01: 1416MHz  1.16  25%   0%  25%   0%   0%   0%      °C
11:45:17: 1416MHz  1.12  25%   0%  25%   0%   0%   0%      °C
11:45:34: 1416MHz  1.10  25%   0%  24%   0%   0%   0%      °C
System health while running 7-zip single core benchmark:
11:45:45: 1416MHz  1.08  22%   1%  18%   0%   2%   0%      °C
11:45:56: 1416MHz  1.06  25%   0%  24%   0%   0%   0%      °C
11:46:07: 1416MHz  1.05  25%   0%  24%   0%   0%   0%      °C
11:46:19: 1416MHz  1.04  25%   0%  24%   0%   0%   0%      °C
11:46:30: 1416MHz  1.04  25%   0%  24%   0%   0%   0%      °C
11:46:41: 1416MHz  1.03  25%   0%  24%   0%   0%   0%      °C
11:46:52: 1416MHz  1.02  25%   0%  24%   0%   0%   0%      °C
11:47:03: 1416MHz  1.02  25%   0%  24%   0%   0%   0%      °C
11:47:14: 1416MHz  1.02  25%   0%  24%   0%   0%   0%      °C
11:47:25: 1416MHz  1.01  25%   0%  24%   0%   0%   0%      °C
11:47:36: 1416MHz  1.01  25%   0%  24%   0%   0%   0%      °C
11:47:47: 1416MHz  1.01  25%   0%  24%   0%   0%   0%      °C
11:47:58: 1416MHz  1.01  25%   0%  24%   0%   0%   0%      °C
System health while running 7-zip multi core benchmark:
11:48:04: 1416MHz  1.00  22%   1%  19%   0%   1%   0%      °C
11:48:27: 1416MHz  1.90  92%   0%  92%   0%   0%   0%      °C
11:48:50: 1416MHz  2.44  92%   0%  91%   0%   0%   0%      °C
11:49:15: 1416MHz  3.11  95%   1%  94%   0%   0%   0%      °C
11:49:39: 1416MHz  3.26  88%   1%  86%   0%   0%   0%      °C
11:50:02: 1416MHz  3.59  95%   1%  93%   0%   0%   0%      °C
11:50:25: 1416MHz  3.65  92%   0%  92%   0%   0%   0%      °C
11:50:48: 1416MHz  3.79  92%   0%  91%   0%   0%   0%      °C
11:51:11: 1416MHz  3.96  93%   1%  91%   0%   0%   0%      °C
11:51:35: 1416MHz  4.15  92%   2%  90%   0%   0%   0%      °C
11:51:59: 1416MHz  4.15  94%   1%  93%   0%   0%   0%      °C
11:52:22: 1416MHz  4.41  93%   0%  92%   0%   0%   0%      °C
11:52:45: 1416MHz  4.21  92%   0%  91%   0%   0%   0%      °C
11:53:08: 1416MHz  4.07  92%   1%  90%   0%   0%   0%      °C
11:53:31: 1416MHz  4.00  94%   1%  92%   0%   0%   0%      °C
System health while running cpuminer:
11:53:50: 1416MHz  4.19  41%   1%  38%   0%   1%   0%      °C
11:54:32: 1416MHz  4.10 100%   0%  99%   0%   0%   0%      °C
11:55:15: 1416MHz  4.08 100%   0%  99%   0%   0%   0%      °C
11:55:57: 1416MHz  4.04 100%   0%  99%   0%   0%   0%      °C
11:56:39: 1416MHz  4.10 100%   0%  99%   0%   0%   0%      °C
11:57:21: 1416MHz  4.05 100%   0%  99%   0%   0%   0%      °C
11:58:03: 1416MHz  4.02 100%   0%  99%   0%   0%   0%      °C
          49.24    0.03    1.24    1.15    0.00   48.34
mmcblk1           7.92       228.69       147.90         0.00     376513     243508          0
mmcblk2           0.16         4.44         0.00         0.00       7308          0          0
zram0             0.03         0.72         0.00         0.00       1192          4          0
zram1             0.17         0.26         2.11         0.00        436       3480          0
Mem:           3.8Gi       304Mi       3.6Gi       5.7Mi        84Mi       3.5Gi
CPU sysfs topology (clusters, cpufreq members, clockspeeds)
                 cpufreq   min    max
 CPU    cluster  policy   speed  speed   core type
  0        0        0      480    1416   Cortex-A53 / r0p4
  1        0        0      480    1416   Cortex-A53 / r0p4
  2        0        0      480    1416   Cortex-A53 / r0p4
  3        0        0      480    1416   Cortex-A53 / r0p4
Architecture:                         aarch64
CPU op-mode(s):                       32-bit, 64-bit
Byte Order:                           Little Endian
CPU(s):                               4
On-line CPU(s) list:                  0-3
Vendor ID:                            ARM
Model name:                           Cortex-A53
Model:                                4
Thread(s) per core:                   1
Core(s) per cluster:                  4
Socket(s):                            -
Cluster(s):                           1
Stepping:                             r0p4
CPU(s) scaling MHz:                   100%
CPU max MHz:                          1416.0000
CPU min MHz:                          480.0000
BogoMIPS:                             48.00
Flags:                                fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
NUMA node(s):                         1
NUMA node0 CPU(s):                    0-3
Vulnerability Gather data sampling:   Not affected
Vulnerability Itlb multihit:          Not affected
Vulnerability L1tf:                   Not affected
Vulnerability Mds:                    Not affected
Vulnerability Meltdown:               Not affected
Vulnerability Mmio stale data:        Not affected
Vulnerability Reg file data sampling: Not affected
Vulnerability Retbleed:               Not affected
Vulnerability Spec rstack overflow:   Not affected
Vulnerability Spec store bypass:      Not affected
Vulnerability Spectre v1:             Mitigation; __user pointer sanitization
Vulnerability Spectre v2:             Not affected
Vulnerability Srbds:                  Not affected
Vulnerability Tsx async abort:        Not affected
SoC guess: Allwinner H618 (SID: 33802100)
DT compat: transpeed,8k618-t
           allwinner,sun50i-h618
 Compiler: /usr/bin/gcc (Debian 12.2.0-14) 12.2.0 / aarch64-linux-gnu
 Userland: arm64
   Kernel: 6.10.10-edge-sunxi64/aarch64
           CONFIG_HZ=250
           CONFIG_HZ_250=y
           CONFIG_PREEMPT_NONE=y
           CONFIG_PREEMPT_NONE_BUILD=y
   vdd-cpu: 1100 mV (1100 mV max)
   vdd-gpu-sys: 900 mV (990 mV max)
   opp-table-cpu:
       480 MHz    900.0 mV (001f)
       600 MHz    900.0 mV (0012)
       720 MHz    900.0 mV (000d)
       792 MHz       -
       936 MHz    900.0 mV (000d)
      1008 MHz    950.0 mV   940.0 mV   950.0 mV   950.0 mV  1020.0 mV
      1104 MHz   1000.0 mV  1000.0 mV  1000.0 mV
      1200 MHz   1050.0 mV  1020.0 mV  1050.0 mV  1050.0 mV  1100.0 mV
      1320 MHz   1100.0 mV (001d)
      1416 MHz   1100.0 mV (000d)
      1512 MHz       -
Results validation:
  * Measured clockspeed not lower than advertised max CPU clockspeed
  * No swapping
  * Background activity (%system) OK
  * No throttling
| Transpeed 8K618-T | 1416 MHz | 6.10 | Debian 12 (bookworm) tampered by Armbian-unofficial 24.11.0-trunk bookworm arm64 | 3770 | 1090 | 658920 | 1230 | 3480 | 5.49 |
Vontar H618 working with  transpeed,8k618-t image. wifi working with brcmfmac4334-sdio.transpeed,8k618-t.bin
bluetooth does not work but icon appears in task bar
Quote
[    9.796905] Bluetooth: Core ver 2.22
[    9.797049] NET: Registered PF_BLUETOOTH protocol family
[    9.797056] Bluetooth: HCI device and connection manager initialized
[    9.797075] Bluetooth: HCI socket layer initialized
[    9.797083] Bluetooth: L2CAP socket layer initialized
[    9.797099] Bluetooth: SCO socket layer initialized
[   10.163407] Bluetooth: HCI UART driver ver 2.3
[   10.163437] Bluetooth: HCI UART protocol H4 registered
[   10.163442] Bluetooth: HCI UART protocol BCSP registered
[   10.163538] Bluetooth: HCI UART protocol LL registered
[   10.163543] Bluetooth: HCI UART protocol ATH3K registered
[   10.163575] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   10.163735] Bluetooth: HCI UART protocol Intel registered
[   10.163822] Bluetooth: HCI UART protocol Broadcom registered
[   10.163855] Bluetooth: HCI UART protocol QCA registered
[   10.163860] Bluetooth: HCI UART protocol AG6XX registered
[   10.163890] Bluetooth: HCI UART protocol Marvell registered
[   10.525559] Bluetooth: hci0: BCM: chip id 68
[   10.527984] Bluetooth: hci0: BCM: features 0x0f
[   10.551386] Bluetooth: hci0: BCM4334B0
[   10.551413] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[   10.559864] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   15.137586] Bluetooth: hci0: BCM: features 0x0f
[   15.161136] Bluetooth: hci0: BCM4334B1 37.4 MHz ExtLNA Murata VM
[   15.161165] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1852
[   18.854591] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.854622] Bluetooth: BNEP filters: protocol multicast
[   18.854645] Bluetooth: BNEP socket layer initialized
[   18.866766] Bluetooth: MGMT ver 1.22
[   21.576450] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[   39.679565] Bluetooth: RFCOMM TTY layer initialized
[   39.679606] Bluetooth: RFCOMM socket layer initialized
[   39.679633] Bluetooth: RFCOMM ver 1.11
[  144.290000] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4185.182614] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4252.959629] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4342.080999] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4355.681223] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4387.169641] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 4896.781723] Bluetooth: hci0: Opcode 0x0c03 failed: -110
~$ bluetoothctl
Waiting to connect to bluetoothd...[bluetooth]# Agent registered
exit
I had to install no internet apps for desktop as armbian mirror for firefox is broken as there is file size missmatch and it cancels the compile of image
trying to instal firefox by apt or synaptic package manager gave same error. I had to install firefox nightly to get a working browser.
Edited by firepower
8 hours ago, firepower said:
Vontar H618
LED: FD650B-S
PMIC: AXP313A
This Vontar hardware is identical, and the board also with my version of transpeed-8k
Please let me know (or provide link) with your working/tested Android 12 firmware image for your Vontar H618.
Edited by rafman
i like to make a bootable micro SDcard with the Vontar H618 Android 12 firmware and see if it would boot on the Tanix Tx6. Use Disks to make an image and restore to sdcard?
Edited by firepower
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
