November 2, 20232 yr Seeing the SOC go upto 80-90C, is there any fan mod or way to reduce temps? for now, added a external fan, removed the case, temps are around 50 Running OMV6 on bullseye
November 2, 20232 yr Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
November 2, 20232 yr You can try to add new thermal paste or a new thermal pad between the heat spreader and the chip. This helped for some of my boards in the past.
