November 14, 20232 yr when I tried to install Armbian (Armbian_23.8.1_Lepotato_bookworm_current_6.1.50.img.xz) on my Le Potato, it asked me to enter the desired value of the TZ environment variable when I chose not to set the timezone automatically. however I am confused with what is a valid Posix timezone string. here are my attempts: Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. UTC 'UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. UTC-0 'UTC-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. GMT 'GMT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. GMT-0 'GMT-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. Etc/UTC 'Etc/UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. AEST-10 'AEST-10' is not a conforming Posix timezone string. Edited November 14, 20232 yr by CocoNut typo
August 24, 20242 yr For anyone who had the same kind of issues, 'UTC-0' worked for me. Edited August 24, 20242 yr by Guest typo
September 8, 20242 yr I had problems with the update: apt update supposedly it was a problem with time. helped: sudo apt-get install ntpdate sudo ntpdate pool.ntp.org and I tried before the entry :upade apt-get -o Acquire::Check-Valid-Until=false -o Acquire::Check-Date=false update but I had another problem with the reboot option which didn't always work? And also restarting the Pi-3 LTS after the poweroff option from the button on the case for 2 seconds. I switched to FW from the Orange PI provider: Orangepi3-lts_3.0.8_debian_bullseye_server_linux5.16.17 and now it's OK? Edited September 8, 20242 yr by kris777
December 8, 20241 yr I am having the exact same issue with Armbian 24.11.1 Bookworm. Just like the original post, the OS isn't even recognizing its own example. I'm stuck. I can't go back and choose something else. I can't skip. I can't report this as a bug since it is happening during setup. 'EST5EDT,M3.2.0/2,M11.1.0/2' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST-5EDT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST5EDT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST-5' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'UTC-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'AEST-10' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. ' ' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings.
June 1, 20251 yr my current timezone is PST (suppose to be PH starndard time) configured via raspi-config, im guessing it is confusing itself with PST (Pacific standard time US). it really messing with my TZ. For my part the only workaround is to set it manually before i can upgrade the system $ TZ=':UTC'; export TZ
