Skip to content
View in the app
Armbian Community Forums
Cannot connect via ssh protocol to orange pi 5b after installing sd card.
Featured Replies
Suddenly after updating via armbian-config I lost ssh access and found the port closed. I rewrote the latest armbian version, stuck the sd card in, connected to ethernet cable via router and started up. The red and green lights were on as they should be and the internet cable was flashing green. Waited 3 minutes and checked the ports with nmap. And the port is closed again.
Not responding to ping at all. I am still new to this topic. Please help and sorry if the translator translates crookedly.
Screenshot_20231130_172722-1.png.9d27f66106109440941a9e99ab31e16c.pngScreenshot_20231130_173048-1.png.92d4db1f89aa9fc2635b1ecf10d5661c.png
Solved by Flops
  • Author
In addition I want to say that when I tried to run armbian with usb ethernet started to light up and orange light. I am still waiting for the adapter to be delivered
Edited by Flops
  • Author
I bought a uart and connected it according to the instructions in the video.
I used screen and set the speed to 1500000 but the terminal shows only garbage. Maybe I should set a different speed?
  • Author
ok. I forgot to look. All right, I'll buy a proper adapter. Can you recommend an adapter or tell me where to look?
Edited by Flops
  • Author
I bought a uart and connected it as indicated in the video. The text is already readable, but sometimes it underwrites and moves away. What should I do next?
Modified: it does not output correctly what I enter. Is there any way to improve it?
Edited by Flops
  • Author
Saw this in the logs:
INFOx4000001 != 0xfead0003
ERROR: INFO: BL31: Initializing Excervices
WARNING: No OPTEE providon. SMC`s destined for OPTEE wil (eMMC)
Maybe it means something?
  • Author
It can work via uart, sshd works and yet it does not respond to a ping or ssh connection. At the same time it can connect to the internet and download packets by itself.
  • Author
I tried rebooting the router. Nothing changed in the end. The router does not respond to ping, but the board works properly via uart. Please help
 1468  ### ip addr:
  1469
p default qlen 1000
  1471      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1472      inet XXX.XXX.0.1/8 scope host lo
  1473         valid_lft forever preferred_lft forever
  1474      inet6 ::1/128 scope host noprefixroute
  1475         valid_lft forever preferred_lft forever
ult qlen 1000
  1477      link/ether 6e:48:1c:02:bd:e7 brd ff:ff:ff:ff:ff:ff
  1478
Either the logs are incomplete or the ethernet ports don't show up at all. Odd...
  • Author
When I connected to cable and uart it was able to update and download packages. I will try to copy the log again today. And I'll also check ifconfig
Edited by Flops
  • Author
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 127.0.0.1/8 scope host lo
2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 2a:77:33:98:ba:5a brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.108/24 brd 192.168.0.255 scope global dynamic noprefixroute end1
       valid_lft 7145sec preferred_lft 7145sec
    inet6 fe80::8a87:d850:159c:a59e/64 scope link noprefixroute
This is what the ip a gave me when I plugged in the cable.
Edited by Flops
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
