Skip to content
View in the app
Armbian Community Forums
USB C port doesn't work on pinebook pro after the latest update on kernel 6.6.2
Featured Replies
Hello,
as already mentioned in topic USB C port doesn't work after upgrading to the latest kernel 6.6.2 .
The previous problem with not working left usb 3 port persist no more. Everything is fine. As I remember , before update the usb c port has worked with the adapter and the devices like mouse, usb flash etc. Now it doesn't work any more, furthermore it gives no signal of life. There is 0 amps current measured, also dmesg -W gives no output at all after plugging in the device.
PS: I was unable to upload the report file, also the service paste.armbian.com doesn't work at the moment.
  • Author
Some issue is, but I don't know. Just checked again. Still not working . With manual paste on paste.armbian.com by saving come pop out message "some went wrong". And output from terminal by issuing sudo armbianmonitor -u
gives me following output:
System diagnosis information will now be uploaded to https://paste.armbian.com/
Please post the URL in the forum where you've been asked for.
As seen above there is no url with id.
About the problem with usb port itself. I could not state anything general, it could be that is some hardware problem only at my side, I don't know therefore I asked.
Use armbianmonitor -U to dump to terminal, then c&p to a paste service of your choice like paste.debian.net or p.na4.eu
Not sure whats wrong with armbian paste or if pbp has trouble.
  • Author
Hello,
It is good news that is new armbian version here. But unfortunatelly my issue listed above was not resolved. Both problems persists. The usb c port still doesn't work and the initramfs issue is also not resolved:
Quote
run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Could you tell me is this error with usb c only on my comp or is it general, also for iniramfs?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
