December 22, 20232 yr I had a working setup with a small driver issue so I flashed coreelc on an sd card and after booting into it once, I can't seem to be able to boot into armbian anymore. booting into coreelec still works but the armbian sd stopped working. I tried editing the extlinux and evreything I soldered serial pins to see what's going on bl31 reboot reason: 0xd bl31 reboot reason: 0x3 system cmd 1. SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0001 - pwm id 0x00 bl2_stage_init 0xc0 bl2_stage_init 0x02 L0:00000000 L1:00000703 L2:00008067 L3:15000020 S1:00000000 B2:20282000 B1:a0f83180 TE: 97016 BL2 Built : 14:02:05, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz Board ID = 1 Set cpu clk to 24M Set clk81 to 24M Use GP1_pll as DSU clk. DSU clk: 1200 Mhz CPU clk: 1200 MHz Set clk81 to 166.6M eMMC boot @ 0 sw8 s board id: 1 Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0 fw parse done PIEI prepare done 00000000 emmc switch 1 ok ddr saved addr:00016000 Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0 00000000 emmc switch 0 ok fastboot data verify result: 255 Cfg max: 12, cur: 1. Board id: 255. Force loop cfg DDR3 probe LPDDR4_PHY_V_0_1_22-Built : 14:02:12, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz ddr clk to 672MHz dmc_version 0001 Check phy result INFO : End of initialization INFO : End of read enable training INFO : End of fine write leveling INFO : End of read dq deskew training INFO : End of MPR read delay center optimization INFO : End of Write leveling coarse delay INFO : End of write delay center optimization INFO : End of read delay center optimization INFO : End of max read latency training INFO : Training has run successfully! dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):00e4 1D training succeed auto size-- 65535DDR cs0 size: 4096MB DDR cs1 size: 0MB DMC_DDR_CTRL: 0000002dDDR size: 3928MB cs0 DataBus test pass cs0 AddrBus test pass non-sec scramble use zero key ddr scramble enabled 100bdlr_step_size ps== 450 result report boot times 1Enable ddr reg access 00000000 emmc switch 3 ok BL2: rpmb counter: 0x000002f9 00000000 emmc switch 0 ok Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000ee000, part: 0 0.0;M3 CHK:0;cm4_sp_mode 0 [Image: g12a_v1.1.3396-c893a7153 2020-11-11 13:54:29 gongwei.chen@droid11-sz] OPS=0x01 ring efuse init 2b 0b 01 00 01 2d 20 00 00 0b 33 38 50 42 30 50 [0.596487 Inits done] secure task start! high task start! low task start! boot bl31 NOTICE: BL31: v1.3(release):ec7984eef NOTICE: BL31: Built : 15:24:59, Nov 30 2020 NOTICE: BL31: G12A normal boot! NOTICE: BL31: BL33 decompress pass ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01 (Jun 27 2023 - 15:25:32) DRAM: 3.8 GiB Relocation Offset is: d6d85000 mmu cfg end: 0xe0000000 mmu cfg end: 0xe0000000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 00000000d7e99628 NAND: get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 MMC: aml_priv->desc_buf = 0x00000000d3d75a70 aml_priv->desc_buf = 0x00000000d3d77db0 SDIO Port B: 0, SDIO Port C: 1 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800 emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 40000000 [set_emmc_calc_fixed_adj][875]find fixed adj_delay=20 init_part() 297: PART_TYPE_AML [mmc_init] mmc init success Amlogic multi-dtb tool Single dtb detected start dts,buffer=00000000d3d7a620,dt_addr=00000000d3d7a620 get_partition_from_dts() 92: ret 0 Amlogic multi-dtb tool Single dtb detected parts: 17 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 set has_boot_slot = 0 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 000000001c000000 1 12: odm 0000000008000000 1 13: system 0000000074000000 1 14: product 0000000008000000 1 15: cache 0000000046000000 2 16: data ffffffffffffffff 4 init_part() 297: PART_TYPE_AML eMMC/TSD partition table have been checked OK! crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!! crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!! crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!! mmc env offset: 0x4d400000 In: serial Out: serial Err: serial reboot_mode=update [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-3476: calc 6bfb8fc3, store 6bfb8fc3 _verify_dtb_checksum()-3476: calc 6bfb8fc3, store 6bfb8fc3 dtb_read()-3691: total valid 2 update_old_dtb()-3672: do nothing Amlogic multi-dtb tool Single dtb detected amlkey_init() enter! [EFUSE_MSG]keynum is 4 vpu: driver version: v20190313 vpu: detect chip type: 11 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level in dts: 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: vpp osd2 matrix rgb2yuv.............. hdr_func 4, hdr_process_select 0x1 cvbs: cpuid:0x2b cvbs: find clk_path: 0x0 cvbs: find performance_pal config Net: dwmac.ff3f0000amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 CONFIG_AVB2: null Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=2 reboot_mode:::: update s_version: U-Boot 2015.01 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L515:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet [KM]Error:f[keymanage_dts_get_key_device]L105:oemkey key name is not exist [KM]Error:f[_get_km_ops_by_name]L240:key oemkey not know device 4 [KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[oemkey] [KM]Error:f[key_manage_query_size]L511:Fail in query key exist hpd_state=0 do_hpd_detect: hdmimode=1080p60hz do_hpd_detect: colorattribute=rgb,8bit Saving Environment to aml-storage... mmc env offset: 0x4d400000 Writing to MMC(1)... done no sink, fallback to 720p60hz[4] hdr mode is 0 dv mode is ver:0 len: 0 hdr10+ mode is 0 read hdmichecksum 0x00000000, colorattribute rgb,8bit read hdmimode 1080p60hz, colorspace <NULL>, colordepth <NULL> do_get_parse_edid: autoMode = false, manualMode=16 isYuv4kSink: false, maxTMDSRate=150 do_get_parse_edid: non-yuv4k sink: inColorSpace: HDMI_COLOR_FORMAT_RGB do_get_parse_edid: default inColorDepth: HDMI_COLOR_DEPTH_24B TV is same, initial mode is: 576cvbs attr: rgb,8bit dolby_status 0 dolby_status 0 dolby_vision_process: no tv and dv disabled Saving Environment to aml-storage... mmc env offset: 0x4d400000 Writing to MMC(1)... done [OSD]load fb addr from dts:/meson-fb [OSD]load fb addr from dts:/fb [OSD]set initrd_high: 0x7f800000 [OSD]fb_addr for logo: 0x7f800000 [OSD]load fb addr from dts:/meson-fb [OSD]load fb addr from dts:/fb [OSD]fb_addr for logo: 0x7f800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x7f800000 width=3840, height=2160 [OSD]osd_hw.free_dst_data: 0,719,0,575 [OSD]osd1_update_disp_freescale_enable vpp: vpp_matrix_update: 2 cvbs_performance_enhancement cvbs_config_hdmipll_g12a cvbs_set_vid2_clk vdac_enable: 1, module_sel:0x8 dolby_status 0 dolby_status 0 hdr_packet vpp: hdr_policy = 1 vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0 s_version: U-Boot 2015.01 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L515:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet [KM]Error:f[keymanage_dts_get_key_device]L105:oemkey key name is not exist [KM]Error:f[_get_km_ops_by_name]L240:key oemkey not know device 4 [KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[oemkey] [KM]Error:f[key_manage_query_size]L511:Fail in query key exist gpio: pin GPIOAO_3 (gpio 3) value is 1 Command: bcb uboot-command Start read misc partition datas! get bootloader message from misc partition: [commannd:bootonce-bootloader] [status:] [recovery:] command mark(uboot-command) not match bootonce-bootloader,don't execute. s_version: U-Boot 2015.01 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L515:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet [KM]Error:f[keymanage_dts_get_key_device]L105:oemkey key name is not exist [KM]Error:f[_get_km_ops_by_name]L240:key oemkey not know device 4 [KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[oemkey] [KM]Error:f[key_manage_query_size]L511:Fail in query key exist InUsbBurn wait for phy ready count is 0 noSof sof timeout, reset usb phy tuning card in co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [set_emmc_calc_fixed_adj][875]find fixed adj_delay=20 init_part() 282: PART_TYPE_DOS [mmc_init] mmc init success Device: SDIO Port B Manufacturer ID: 0 OEM: 3432 Name: SD16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: (0x1dc200000 Bytes) 7.4 GiB mmc clock: 40000000 Bus Width: 4-bit Device: SDIO Port B Manufacturer ID: 0 OEM: 3432 Name: SD16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: (0x1dc200000 Bytes) 7.4 GiB mmc clock: 40000000 Bus Width: 4-bit reading aml_autoscript 709 bytes read in 4 ms (172.9 KiB/s) ## Executing script at 03080000 bootfromsd=if mmcinfo; then run cfgloadsd; if fatload mmc 0 ${loadaddr} kernel.img; then run sddtb; setenv bootargs ${bootargs} bootfromsd; bootm; fi; fi reading recovery.img ** Unable to read file recovery.img ** (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 0 ** Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot: normal Unknown command 'wipeisb' - try 'help' avb2: 0 ee_gate_off ... avb2: 0 ## Booting Android Image at 0x03080000 ... Kernel command line: androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=user [store]Is good fdt check header, no need decrypt! active_slot is normal load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected find 1 dtbos dtbos to be applied: 0 Apply dtbo 0 Loading Kernel Image(COMP_NONE) ... OK kernel loaded at 0x01080000, end = 0x019e7928 Loading Ramdisk to 0997f000, end 09fff6f2 ... OK Loading Device Tree to 0000000009968000, end 000000000997edbf ... OK fdt_fixup_memory_banks, reg:0000000000000000 Starting kernel ... uboot time: 4905713 us [ 0.000000@0] Linux version 4.9.113 (user@xeon) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #1 SMP PREEMPT Tue Jun 27 15:39:42 CST 2023 .... I would love any advice Edited December 22, 20232 yr by ajuyg
December 22, 20232 yr This is expected behavior. https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus
December 23, 20232 yr Author that's good to hear! I did the steps in this guide (I think) 1. changed the u-boot 2. edited the extlinux.conf what am I missing?
December 23, 20232 yr The first full paragraph in the instructions says: Note: If you have previously run other distributions on the box such as coreelec the below installation will not work. You will need to restore the original android firmware before attempting the install. coreelec changes the boot environment in ways that are incompatible with these Armbian builds.
December 23, 20232 yr Author wow I feel like an idiot I did already try to "restore to factory settings" from the recovery menu but that didn't help. isn't that enough? does it matter which androind I flash? can I flash it without the usb burning tool?
December 23, 20232 yr You need to find the correct Android firmware for your device and reinstall it according to the instructions for that firmware (usually USB burning tool)
