January 19, 20242 yr Zitat thermal thermal_zone0: failed to read out thermal zone (-110) Is this the reason why I don't see my soc temperature and how I can I solve?
January 19, 20242 yr 10 часов назад, bahtiyar57 сказал: Armbianmonitor: https://paste.armbian.com/exuhayuzid Try updating the kernel
January 19, 20242 yr Author Zitat I don't know how. The only option I consider is to switching the kernel over armbian-config. Is this the right approach? In this case which kernel I have to choose?
January 20, 20242 yr You should be up-to-date regarding "current" branch. Since "edge" kernels are not available through this you can try building and installing those packages by yourself. https://docs.armbian.com/Developer-Guide_Build-Preparation/ Anyway also an option is to try an older one, like 5.15.y and see if the issue disappears....
January 20, 20242 yr @bahtiyar57 I am aware of this regression in the latest kernel changes for sunxi. Try installing an older kernel using the armbian-config utility, for example: for current - 5.15.93-sunxi for edge - 6.1.11-sunxi If you want to build the kernel yourself, write here. I will provide you with the necessary changes for the A83T processor.
January 20, 20242 yr ____ ____ _ __ __ _____ | __ )| _ \(_) | \/ |___ / | _ \| |_) | | | |\/| | |_ \ | |_) | __/| | | | | |___) | |____/|_| |_| |_| |_|____/ Welcome to Armbian 23.10 Bookworm with Linux 6.4.14 No end-user support: built from trunk & unsupported (bookworm) userspace! System load: 6% Up time: 3 min Memory usage: 5% of 1.96G IP: 192.168.100.101 CPU temp: 38°C Usage of /: 12% of 7.3G ========================================================================== leo@bananapim3:~$ armbianmonitor -m Two CPU clusters are available for monitoring Stop monitoring using [ctrl]-[c] Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 12:35:38 1344/1152 MHz 0.14 8% 1% 1% 0% 5% 0% 39.1 °C 0/5 12:35:43 1344/1344 MHz 0.13 0% 0% 0% 0% 0% 0% 38.7 °C 0/5 12:35:48 1344/ 768 MHz 0.12 0% 0% 0% 0% 0% 0% 39.5 °C 0/5 12:35:54 1152/1344 MHz 0.11 0% 0% 0% 0% 0% 0% 38.8 °C 0/5 12:35:59 1344/1152 MHz 0.10 0% 0% 0% 0% 0% 0% 39.4 °C 0/5 12:36:04 1344/1152 MHz 0.09 0% 0% 0% 0% 0% 0% 39.7 °C 0/5 12:36:09 768/1344 MHz 0.08 0% 0% 0% 0% 0% 0% 39.7 °C 0/5 12:36:14 1152/1344 MHz 0.08 0% 0% 0% 0% 0% 0% 39.4 °C 0/5^C This is my last kernel build for this platform. It shows the temperature correctly. You can simply download and install this kernel at: https://github.com/The-going/PKG_test/tree/master/linux-edge-sunxi-6.4.14 The *dtb*.deb package is not required.
January 20, 20242 yr Author Can I use this Kernel https://github.com/The-going/PKG_test/tree/master/linux-edge-sunxi-6.4.14? Because I use Armbian 23.11.1
January 20, 20242 yr 6 минут назад, bahtiyar57 сказал: Can I use this Kernel wget https://github.com/The-going/PKG_test/raw/master/linux-edge-sunxi-6.4.14/linux-image-edge-sunxi_6.4.14-Armbian.23.10_armhf.deb
January 20, 20242 yr #!/usr/bin/bash url="https://github.com/The-going/PKG_test/raw/master/linux-edge-sunxi-6.4.14/" pkg="linux-headers-edge-sunxi_6.4.14-Armbian.23.10_armhf.deb \ linux-libc-dev_6.4.14-Armbian.23.10_armhf.deb \ linux-image-edge-sunxi_6.4.14-Armbian.23.10_armhf.deb" for p in $pkg do wget ${url}${p} done create dl.sh in target dir chmod +x dl.sh ./dl.sh sudo dpkg -i linux-image-edge-sunxi_6.4.14-Armbian.23.10_armhf.deb
January 20, 20242 yr 38 минут назад, bahtiyar57 сказал: Do I have to disable automatically kernel updates in armbian-config? The version of the package from Armbian is the release number. Judging by the screenshot you provided, it is 23.8.1. The version of my package is 6.4.14-Armbian.23.10 that is, it will always be less than the Armbian. It probably needs to be frozen from updates. Try to check it out. Type: sudo apt upade sudo apt --list upgradable P.S.I don't use their repository. I assemble all the packages and the image myself. Edited January 20, 20242 yr by going Add P.S.
January 20, 20242 yr Author Zitat # apt list --upgradable Listing... Done linux-image-edge-sunxi/jammy 23.8.1 armhf [upgradable from: 6.4.14-Armbian.23.10] N: There are 25 additional versions. Please use the '-a' switch to see them. Boot fails after upgrading with apt upgrade. Now I will freeze kernel updates. Thank you.
January 20, 20242 yr Author I froze Armbian kernal upgrades But if I enter apt list --upgradable There are still displayed linux-image-edge-sunxi/jammy 23.8.1 armhf [upgradable from: 6.4.14-Armbian.23.10] N: There are 25 additional versions. Please use the '-a' switch to see them. Now I'm afraid to use the apt upgrade command EDIT: Is it better to use a command like this: $ sudo apt-mark hold package_name to exclude it ? Edited January 20, 20242 yr by bahtiyar57
January 21, 20242 yr 10 часов назад, bahtiyar57 сказал: $ sudo apt-mark hold package_name Yes! man apt-mark ..... PREVENT CHANGES FOR A PACKAGE hold hold is used to mark a package as held back, which will prevent the package from being automatically installed, upgraded or removed. unhold unhold is used to cancel a previously set hold on a package to allow all actions again. showhold showhold is used to print a list of packages on hold in the same way as for the other show commands. .... sudo apt-mark hold linux-image-edge-sunxi
