Skip to content
View in the app
Armbian Community Forums
Featured Replies
Hi @John Taylor, @SteeMan,
unfortunatly it takes me time because I was not at home. I found that I can use the minimal or server version and only using Rufus. If I use Balena Etcher it doesn't create the fat32 partition named Boot. now I'm struggling because I would like to use the system on SD card but after that I do any changing for example IP from dynamic to static using armbian-config a lot of messages comes saying that EXT4FS is in read-only mode and I can use the system but not to install programs. I'm a little afraid to install on eemc because I have no android image. It is an old MXQ pro mini from leelbox.
@Maurizio Finesso@John Taylor@SteeMan
I've had success using USB stick instead of SD Card (see my post on 1st page), however now the BOOT Fat32 partition was hidden for some reason, I used DiskGenius to unhide it.
I didn't test this on the tv box yet.
This also goes against what is being said in this thread (that there are no more Fat32 paritions visible in Windows) from this thread:
EDIT2: USB stick works, however I'm having trouble with "USB device not recognized" on Windows, and I can' seem to be able to fix it with gparted for example, as it keeps disconnecting, so YMMW.
Edited by 2mg
Disk genius in my case reveals there is NO FAT32 boot partition, hidden or otherwise, only a root partition.
Furthermore, today I built an Ubuntu desktop PC, and flashed a build onto an SD Card. The resultant installation has only ONE partition. No Windows involvement whatsoever :( Same with a USB flash drive (to eliminate the SD card adapter).
So where do we go from here?
Edited by John Taylor
Thanks to Nick Alilovic for the solution to this issue. You need to add "BOOTFS_TYPE=fat to the board config. If you are on Windows and using an image created by someone else, it's possible you may need to install a utility to show .ext partitions. The you can edit /boot/armbianEnv.txt or extlinux to config to point to a different dtb etc.
  • Author
BOOTFS_TYPE=fat is part of the aml-s9xx-box.tvb config file and has always been.  So I'm not sure what your comment is referring to, but it seems to be off topic for this thread which is about instructions for using the aml-s9xx-box Armbian builds.
Hi guys and Happy Christmas. I found something that could be useful. I had trouble due to fake sd card that report fake capacity. Capacity declared 64 Gb real capacity 3.7 GB. H2testw (windows) will show you the real capacity. Don't trust if it is a known brand because there are companies with machine to fake SD card. After another problem that I found is not to see the boot partition after imaging SD card. I don't know why but you must be sure that your imaging program (balena etcher o pi imager or rufus) are run in admin mode. after that in any case if it doesn't appear you have to assign a letter drive (sometimes it is not assigned) I used aomei partition manager)
Some boxes with unmodified bls might accept reboot update on shell and boot via the sdcard that way, worked for me on both coreelec and now worked with armbian (I formatted via os and installed termux and typed su, then reboot update), way too useful for boxes with no buttons (yes, they exist)
Hi! This is my first message here, congrats to the community for building this :)
I would also like to corroborate that the current Balena Etcher, in Windows at least, is not writing the image correctly to the SD card. The Armbian imager did it well for me.
I just booted an unused A95X (S905X) "Mini Kitty" with Armbian, but I don't think I will spend too much time with it, I already got a lot of mini PCs for servers and it's too slow for a terminal 😅
What do you recommend me to do with this little box? Thanks!
Hello, this is my first message here: I want to thank the community for the work done so far, and for allowing to keep functional old devices which would otherwise become (nasty) garbage.
Now, I tried to install Armbian on a Wetek Play 2 (Amlogic S905), buit now the box is not booting. I would be grateful if I could get some help, or at least clarification about what happened. Here is what I did so far:
  1. Download the image `Armbian_community_26.2.0-trunk.493_Aml-s9xx-box_trixie_current_6.18.13_minimal.img.xz`, and write it on a SD card.
  2. Boot from the SD card, by holding the power button when inserting the power cable. The box booted fine.
  3. Log in via SSH, and configure the installation.
  4. Back-up the full emmc with `dd if=/dev/mmcblk1 of=/mnt/backup/wetek_play2_android_emmc.img bs=4M`. The emmc had the original Android system (with more stuff installed, but I guess the most important part are the first 4 MB...)
  5.  Run the `/root/install-aml` script.
  6. Power-off
When powering on again, the box did not boot. I tried to boot from SD by holding the power button, but it did not work. So at this point my questions are:
  1. What can I do to recover the situation?
  2. What did I made wrong?
As additional context, in the past I had also successfully booted LibreELEC from SD, although the last boot before switching to Armbian was to Android.
Thanks for your help
UPDATE: OK, I think I found the  culprit: I overseen the quite important statement "Note: It is not possible to install into emmc on boxes with the s905 cpu". Great.
Edited by ALG
Found new info
One interesting thing I discovered today is that you can actually boot from a flash drive, if you don't have a SD Card! In my case, I would have to buy a SD Card and had a flash drive laying around so I thought I might just give it a try, worked on an Arm Cortex-A53 CPU. I used u-boot-s905x-912 for .ext and meson-gxl-s905x-p212.dtb.
Edited by Thiago Escaliante
I want to install an image from the sd card to the internal memory in x96q tv box, it boots perfectly from sd card, without having to press anything, and everything works ok, even bluetooth adapter and video reproduction, my question is "do i still need to modify boot files to install in emmc or is not necessary? thanks in advance....
I had previously installed EmuELEC on the TV box, and later trying to install Armbian proved difficult because the device kept booting into Android recovery mode. I learned that installing EmuELEC even once writes data to the firmware that complicates installing Armbian on my TX3 Mini; the solution was to perform a factory reset via Android and then proceed with the installation.
I hope this helps anyone else who is struggling to get the system to boot for the first time.
Hi, sorry, for an upgrade? I already have armbian in an old tv box installed. Not used in 1 year. I want to start now a project and first I want to upgrade it. Which are the steps? Are the same? is there any post about upgrading? I can not find it. Could I better upgrade from "ui"? Thanks a lot.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
