February 29, 20242 yr Hello I have Armbian 23.11 installed to x96mini. I use it for HomeAssistant HA argues that cgroup version is incorrect and I have to switch it to version 1. There is a lot of advises about adding "systemd.unified_cgroup_hierarchy=false" to /boot/armbianEnv.txt or /boot/cmdline.txt or /etc/default/grub on the Intrnet But I have not these files in my system. I tried to create them but no results. Does anybody help me tu change cgroup version please ) Edited February 29, 20242 yr by Сергей Галанов
February 29, 20242 yr For the Armbian community build supporting your box (aml-s9xx-box), you need to add the kernel setting to the APPEND line in the extlinux.conf file.
