March 3, 20242 yr Hi All, Current running a RockPi4C+, it has crashed after a dist-update (it seems that uboot update not recognize my nvme), then, I reinstall it, on SD card only , but only found a community rolling version, And, now that my system is booting, I want/need to go back to stable, I read about armbian-config to do that, but not enable on RockPi4C+ What is the "cli" way Thank you
March 3, 20242 yr 10 minutes ago, d83fr said: I read about armbian-config to do that, but not enable on RockPi4C+ I'm not sure what you mean by this as armbian-config is available on all Armbian builds.
March 3, 20242 yr Author OK, perhaps my wrong, got a "Unable to locate package armbian-config", on which repo is it, I got ... ohhh ! by doing an update, armbian repo disappear !! cat you give me your /etc/pat/source.list.d/armbian.list
March 3, 20242 yr What you may be finding is that in armbian-config you are not seeing any stable releases. That would be because your board is not supported by Armbian. It in in unmaintained/community support status. Community supported boards now only get rolling automated builds, no stable releases.
March 3, 20242 yr What version do you have installed? That package should be already installed on all builds (except I believe cli minimal builds)
March 3, 20242 yr Author I'm using bookworm minimal, but, my bad, found armbian-config, your are pointing me right by saying that it have to be enable. armbian-config installed will try to go to stable, and see Thank you
