April 20, 20242 yr @ag123, @c0rnelius, and anyone else that has interest in sound on these devices. I have been able to put together a patch that enables audio for H161/H618 devices. So far only audio on HDMI works. Analog audio is still generating an error on startup. The patches were taken from a git repository by warpme: https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.6/files , and probably came from the Zunlong SDK. A lot of the code was written by Allwinner. @pixdrift generated a version of the patches for Armbian and I continued to work on them. I have a git repository if anyone would like to test, particularly on boards other than orangpizero3, on which I have tested. repository: https://github.com/stephengraf/armbian_build_sg.git There is another repository mentioned in the Armbian Forum: https://github.com/NickAlilovic/build If anyone has interest and skills to debug the analog audio, the dmesg errors are: [ 7.125509] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 7.125539] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 7.125780] sunxi-snd-mach: probe of soc:ahub_dam_mach failed with error -22 Edited June 21, 20242 yr by Stephen Graf removed built images
April 21, 20242 yr thanks, I'd probably try that some time. if audio for HDMI works, I think many users will be happy, I've read some comments some are looking for that. currently, I'm using headless as wifi ap, so I did not know if it works. analog may need to go back into h616 zero 2 to see how it is done there, maybe dts etc.
April 26, 20242 yr OrangePi has this analog audio figured out: http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_Zero_2W#Headphone_interface_audio_playback_test http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_Zero_3#Headphone_jack_playback_audio_test
April 27, 20242 yr Author 7 hours ago, robertoj said: OrangePi has this analog audio figured out: Yes I have tried the Zunlong images for orangepizero3 and they work. Unfortunately those images are for a Linux 6.1 kernel and the zero3 and 2w were only officially implemented into linux with 6.6. The challenge is to get the Zunlong code into Armbian with the newer kernels.
May 7, 20242 yr Hi @Stephen Graf, thank you so much for these images. you are correct. Having audio even on HDMI is extremely useful. Do you perhaps have the kernel headers for this image? https://drive.google.com/file/d/1jIMTIqKc6y_uuG7lRyXXhIWQ_fvo0XgI/view?usp=drive_link Also, Could you create an image for armbian jammy, or provide steps so that i can do it. Armbian_community_24.5.0-trunk.93_Orangepizero3_jammy_current_6.6.18_gnome_desktop.img
May 7, 20242 yr Author 6 hours ago, SUPA said: provide steps so that i can do it @SUPA Thank you for testing the patch. I assume it worked and that you are working with an orangepisero3. If you want to build you own images follow the directions in the Armbian build manual: https://docs.armbian.com/Developer-Guide_Build-Preparation/ and clone my repository. Unfortunately I have limited space on my google drive. git clone https://github.com/stephengraf/armbian_build_sg.git
May 8, 20242 yr @Stephen Graf i see that if i use the original kernel source i want to build patched linux-image and linux-header for armbian jammy 6.6.26. It seems to include support for analog audio. I compile and install these using . **************** i have already tested all my components on jammy 6.6.26 thats why I would prefer using it ========================= Here are my cheat sheets: wget https://cdn.kernel.org/pub/linux/kernel/v6.x/linux-6.6.26.tar.xz tar -xvf linux-6.6.26.tar.xz cd ~/src/kernel-source/linux-6.6.26 copy all patches into ~/src/kernel-source/linux-6.6.26 cp /boot/config-$(uname -r) .config patch -p1 < 0606-dma-sun6i-dma-add-h616-support.patch patch -p1 < 0608-sound-soc-sunxi-add-codec-driver-for-h616.patch patch -p1 < 0609-sound-soc-add-sunxi_v2-for-h616-ahub.patch patch -p1 < 0630-arm64-dts-allwinner-h616.dtsi-add-ths-audio-hdmi.patch patch -p1 < 0631-arm64-dts-allwinner-h616-OrangePI-Zero23-enable-ths-hdmi-audio.patch patch -p1 < 0639-arm64-dts-allwinner-h616.dtsi-add-spdif.patch yes "y" | make oldconfig sudo make prepare sudo make clean cd ~/src/kernel-source/linux-6.6.26 sudo make -j$(nproc) bindeb-pkg LOCALVERSION=-custom cd ~/src/kernel-source/ sudo dpkg -i linux-image-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-headers-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-libc-dev_6.6.26-gbbc005ee4185-6_arm64.deb ls -l /boot/Image ls -l /boot/uInitrd ln -sf /boot/vmlinuz-6.6.26-custom /boot/Image ln -sf /boot/initrd.img-6.6.26-custom /boot/uInitrd cd ~/src/kernel-source/linux-6.6.26 make dtbs sudo mkdir /boot/dtb-6.6.26-custom/allwinner sudo cp /root/src/kernel-source/linux-6.6.26/arch/arm64/boot/dts/allwinner/*.dtb /boot/dtb-6.6.26-custom/allwinner/ sudo ln -sfn /boot/dtb-6.6.26-custom /boot/dtb sudo reboot now however my board doesnt boot. Do you have any suggestions? maybe u-boot? I have created the needed symlink which I though would be enough for u-boot. Maybe my approach is completely wrong
May 8, 20242 yr Author 5 hours ago, SUPA said: i have already tested all my components on jammy 6.6.26 thats why I would prefer using it @SUPAThere is a lot more to building a system than just the kernel. That is what Armbian tries to do for you. I recommend that you use the Armbian build system. You should be able to build the system that you want. The audio patches do include analog audio, but to date there is still a problem and it does not start up. The armbian-config procedure has options to load kernel headers and also source.
May 8, 20242 yr 21.04.2024 в 02:07, Stephen Graf сказал: If anyone has interest and skills to debug the analog audio, the dmesg errors are: [ 7.125509] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 7.125539] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 7.125780] sunxi-snd-mach: probe of soc:ahub_dam_mach failed with error -22 Hi, I think these messages are not related to analog audio, at least on my custom board with t507 processor, analog audio works with this error. You can simply disable them as it was in the linux kernel 6.1 Цитата --- 6.7__sunxi64__arm64-6.7.9/sound/soc/soc-pcm.c 2024-02-21 00:16:07.645017846 +0300 +++ linux-6.7.9-sk/sound/soc/soc-pcm.c 2024-03-16 13:34:42.000000000 +0300 @@ -2867,14 +2867,14 @@ static int soc_get_playback_capture(stru if (dai_link->capture_only) has_playback = 0; - +#if 0 if (!has_playback && !has_capture) { dev_err(rtd->dev, "substream %s has no playback, no capture\n", dai_link->stream_name); return -EINVAL; } - +#endif The sound works for me if I turn it on in the mixer Цитата /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute It’s strange, but I have another problem - the sound does not work through HDMI and there is also a problem with reading EDID through the DDC interface. I would be grateful if you could tell me whether automatic detection of monitor or TV resolution via HDMI works for you. Edited May 8, 20242 yr by sasa
May 9, 20242 yr Author 5 hours ago, sasa said: whether automatic detection of monitor or TV resolution via HDMI works for you @sasa Many thanks for pointing out that analog sound just has to be enabled! I just tested and it works. I was dreading trying to debug kernel code when I should have been looking at the fundamental "is it turned on?" I will try the patch to remove the other sound error. As to automatic detection, yes on my orangepizero3 with H618 Allwinner SOC, HDMI detects the monitor and sets the proper resolution.
May 9, 20242 yr 6 часов назад, Stephen Graf сказал: yes on my orangepizero3 with H618 Allwinner SOC, HDMI detects the monitor and sets the proper resolution Thanks for confirming. Цитата I will try the patch to remove the other sound error. In fact, my patch does not solve the problem and can only be considered as a temporary solution. I think we need a new driver for the audio multiplexer, for example, as is implemented for NXP processors. https://elixir.bootlin.com/linux/v6.6.30/source/sound/soc/fsl/imx-audmux.c For these processors, the audio multiplexer configuration is described via DT https://elixir.bootlin.com/linux/v6.6.30/source/arch/arm/boot/dts/nxp/imx/imx6qdl-kontron-samx6i.dtsi#L176 Edited May 9, 20242 yr by sasa
May 9, 20242 yr @Stephen Graf I successfully compiled using armbian build. But not sure if i successfully integrated the patches. and also don't know if I used all the correct patches. Could you review and advise please: Here are my steps: sudo apt-get -y -qq install git mkdir ~/src cd ~/src ======================= git hdmi audio patches ======================= git clone https://github.com/warpme/minimyth2.git git clone --depth=1 --branch=main https://github.com/armbian/build mkdir -p ~/src/build/userpatches/kernel/sunxi-current cp ~/src/minimyth2/script/kernel/linux-6.6/files/0600-drivers-h616-wip-add-usb-emac2-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0601-drivers-thermal-allwinner-add-h616-ths-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0602-media-cedrus-add-H616-variant.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0603-soc-sunxi-sram-Add-SRAM-C1-H616-handling.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0606-dma-sun6i-dma-add-h616-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0607-drivers-drm-wip-add-h616-hdmi-jernejsk-24102023.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0608-sound-soc-sunxi-add-codec-driver-for-h616.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0609-sound-soc-add-sunxi_v2-for-h616-ahub.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0615-drivers-iommu-sun50i-iommu-fix-iommu-on-h616.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0630-arm64-dts-allwinner-h616.dtsi-add-ths-audio-hdmi.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0631-arm64-dts-allwinner-h616-OrangePI-Zero23-enable-ths-hdmi-audio.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0639-arm64-dts-allwinner-h616.dtsi-add-spdif.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0640-arm64-dts-allwinner-h618-enable-spdif-opi23-tanix-tx6s.patch ~/src/build/userpatches/kernel/sunxi-current/ ls ~/src/build/userpatches/kernel/sunxi-current ========================= armbian build =========================== cd ~/src/build ./compile.sh
May 9, 20242 yr Okay I noted the file path should be ~/src/build/userpatches/kernel/archive/sunxi-6.6. Then it includes them... Nut now I see the patches are not setup correctly for the correct changes. They work when i build from source. But how do I add them patches from https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.6/files so they work in Armbian build tool? Sorry if my questions are noob.
May 9, 20242 yr Author 9 hours ago, SUPA said: But not sure if i successfully integrated the patches. @SUPA The warpme patches need work to implement into Armbian. That is what I have been trying to do. When and if we get it right, they should be included into the Armbian system. In the meantime clone my repository, which has the patches implemented, and build your flavour of system from there. cd ~/ git clone https://github.com/stephengraf/armbian_build_sg.git cd armbian_build_sg ./compile.sh The HDMI sound should work immediately. The analog needs to be enabled as @sasa suggested: /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute
May 9, 20242 yr Author 15 hours ago, sasa said: In fact, my patch does not solve the problem and can only be considered as a temporary solution. @sasa I tested with your patch and it gets rid of the error but also creates a new sound device. ahubdam, that has no input or output. I then just took the device creation out of the dtb and then there is no error even without the patch. Analog and HDMI audio still work. This is the piece removed from the dtb. ahub_dam_mach { compatible = "allwinner,sunxi-snd-mach"; soundcard-mach,name = "ahubdam"; status = "okay"; phandle = <0x3f>; soundcard-mach,cpu { sound-dai = <0x0e>; }; soundcard-mach,codec { }; };
May 10, 20242 yr 11 hours ago, Stephen Graf said: @SUPA The warpme patches need work to implement into Armbian. That is what I have been trying to do. When and if we get it right, they should be included into the Armbian system. In the meantime clone my repository, which has the patches implemented, and build your flavour of system from there. cd ~/ git clone https://github.com/stephengraf/armbian_build_sg.git cd armbian_build_sg ./compile.sh The HDMI sound should work immediately. The analog needs to be enabled as @sasa suggested: /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute Thank you soooo much Stephan. I realized my error. I had to add the patches with the expected root path. Which was linux6.6. So I had to add my patches here: ~/src/build/userpatches/kernel/sunxi-6.6/linux-6.6/ @sasa Thank you for showing us how to enable audio through the mixer.
May 10, 20242 yr 8 часов назад, Stephen Graf сказал: ahubdam, that has no input or output This device is used to control the Audio HUB сrossbar switch, for example it makes possible to use external i2s interfaces. https://github.com/elkoni/Opi_Zero_3_I2S3_5.4/blob/main/OpiZero3_I2S_3_mixer.JPG
May 11, 20242 yr Hello, everyone I used your patch @Stephen Graf https://github.com/stephengraf/armbian_build_sg/blob/main/patch/kernel/archive/sunxi-6.6/patches.armbian/sound-soc-h616.patch I found a bug when using it. If I turned on Volume Control in the middle of playing video or audio, the video or audio would suddenly speed up playing, even if I just turned on Volume Control without doing anything,very crazy😂
May 11, 20242 yr Author 29 minutes ago, sakesm said: I found a bug @sakesm Yes i came across that also. Can you confirm that it only happens on analog audio and not on HDMI and when using pulseaudio. I also tested with mpg123 and did not have problems using the mpg123 built in volume controls.
May 11, 20242 yr 2 hours ago, Stephen Graf said: Can you confirm that it only happens on analog audio and not on HDMI and when using pulseaudio. Sorry, I don't have a device that supports hdmi audio 2 hours ago, Stephen Graf said: I also tested with mpg123 and did not have problems using the mpg123 built in volume controls. I tried to use mpg123 to play audio, but as long as the Volume Control is turned on, the bug also appeared I'm still new to audio and video, so I don't know how to solve it
May 11, 20242 yr In pavucontrol, which is the Configuration in Volume Control, set the second Audio to off and exit. After playing the audio and opening the Volume Control at the same time, this problem will not occur and can be adjusted normally My understanding is that two Audio may have output conflict?
May 11, 20242 yr Author @sakesm Thank you for the update. I don't have a lot of experience with audio either. Usually it just works. With mpg123 you can adjust volume with the + and - keys, which I think do not cause any problems.
May 15, 20242 yr 09.05.2024 в 01:40, sasa сказал: the sound does not work through HDMI and there is also a problem with reading EDID through the DDC interface Perhaps it will be interesting to someone - audio on hdmi and edid reading work on the t507 too, there was a problem in our DDC connection scheme.
May 30, 20242 yr I registered to say that this works *perfectly* for analog/line out on my OrangePi Zero3. Additionally, I wanted to mention that I ran the build myself via the build framework. My install target is actually an existing DietPi machine. I installed everything but the u-boot deb (which seemed to cause some trouble with booting? I'd not investigated any more than recovering from the error by reinstalling the old packages). It looks like *maybe* all I needed was the kernel itself (headers, libc, base-files, bsp etc all being "extraneous", but I went ahead and installed those). This gets me a lot closer to my whole-home audio setup! Thanks for putting in the work for this. Is there a possibility of getting this upstreamed? I imagine that this would be extremely useful as such (and we wouldn't have to, say, disable kernel updates on these boxes to keep analog audio)
May 30, 20242 yr Author @bryan_bennett Thank you for testing and for your comments. I am starting to work on putting together a pr for Armbian. It might take a while. There is a problem with analog audio on Pulseaudio. It seems that if you open the Pulseaudio volume control, the analog audio starts to play at a higher speed. This does not happen with HDMI audio. It also does not happen if one controls audio with the app audio controls, eg + - on mpg123.
June 6, 20242 yr Author Solution The sound patches have now been implemented in Armbian current and edge. The community images for orangepizero3 are only updated once a week. So either wait for a new image or build one yourself from Armbian build on github.
June 13, 20242 yr On 5/31/2024 at 12:33 AM, Stephen Graf said: There is a problem with analog audio on Pulseaudio. It seems that if you open the Pulseaudio volume control, the analog audio starts to play at a higher speed. @Stephen GrafI tried switching between the two audio devices over the last few days and found that if I chose to use hdmi audio before playing a video, there was no speedup when I switched back and forth between the Default Sink while playing a video. However, if you choose to use analog audio before playing the video, the phenomenon will continue to occur after the video is played. I feel that this will be a breakthrough to solve the problem
June 13, 20242 yr Author @sakesm Thank you for testing and for the update. At least there are workarounds, although I really don't like things that do not work properly.
June 13, 20242 yr @Stephen Graf I almost forgot to simulate the problem of audio disabling. In order to compile it to enable sound by default, I added a modification in armbian-audio-config #!/usr/bin/env bash # Check that we have the tools required available, otherwise exit with no error. # Use command -v, not which, which is deprecated. [[ -z $(command -v amixer) ]] && echo "Missing amixer; doing nothing." && exit 0 [[ -z $(command -v alsactl) ]] && echo "Missing alsactl; doing nothing." && exit 0 [[ -z $(command -v aplay) ]] && echo "Missing aplay; doing nothing." && exit 0 mixer_cmds() { parm=${3:-on} echo "sset '$1' '$2' '$parm'" echo "sset '$1' '$parm'" } mixer_set() { parm=${3:-unmute} echo "set '$1' '$2' '$parm'" } if [ -f "$HOME/.config/sound.conf" ]; then alsactl restore -f "$HOME/.config/sound.conf" else # get card num #card=`echo $1 | sed 's/[^0-9]*//g'` card1=$(aplay -l | grep "device 0" | awk '{print $3}') #echo $card1 for card in $card1; do ( #echo $card # set common mixer params mixer_cmds Master 0db mixer_cmds Front 100% mixer_cmds PCM 0db mixer_cmds Synth 100% # mute CD, since using digital audio instead mixer_cmds CD 0% mute # Only unmute Line and Aux if they are possibly used. # mixer_cmds Line 100% # mixer_cmds Aux 100% # mute mic mixer_cmds Mic 0% mute # ESS 1969 chipset has 2 PCM channels mixer_cmds PCM,1 100% # Trident/YMFPCI/emu10k1 mixer_cmds Wave 100% mixer_cmds Music 100% mixer_cmds AC97 100% mixer_cmds Surround 90% mixer_cmds 'Surround Digital' 90% mixer_cmds 'Wave Surround' 90% mixer_cmds 'Duplicate Front' 90% mixer_cmds 'Sigmatel 4-Speaker Stereo' 90% # CS4237B chipset: mixer_cmds 'Master Digital' 100% # DRC mixer_cmds 'Dynamic Range Compression' 90% # Envy24 chips with analog outs mixer_cmds DAC 100% mixer_cmds DAC,0 100% mixer_cmds DAC,1 100% # some notebooks use headphone instead of master mixer_cmds Headphone 100% mixer_cmds Speaker 100% mixer_cmds 'Internal Speaker' 0% mute mixer_cmds Playback 100% mixer_cmds Headphone 100% mixer_cmds Speaker 100% mixer_cmds Center 100% mixer_cmds LFE 100% mixer_cmds Center/LFE 100% # Intel P4P800-MX (Ubuntu bug #5813) mixer_cmds 'Master Playback Switch' on # set digital output mixer params mixer_cmds 'IEC958' 100% on mixer_cmds 'IEC958 Output' 100% mixer_cmds 'IEC958 Coaxial' 100% mixer_cmds 'IEC958 LiveDrive' 100% mixer_cmds 'IEC958 Optical Raw' 100% mixer_cmds 'SPDIF Out' 100% mixer_cmds 'SPDIF Front' 100% mixer_cmds 'SPDIF Rear' 100% mixer_cmds 'SPDIF Center/LFE' 100% mixer_cmds 'Master Digital' 100% mixer_cmds 'Analog Front' 100% mixer_cmds 'Analog Rear' 100% mixer_cmds 'Analog Center/LFE' 100% # ASRock ION 330 (and perhaps others) has 2 IEC958 channels mixer_cmds IEC958,0 on mixer_cmds IEC958,1 on # some ION2 has much more IEC958 channels ... mixer_cmds IEC958,2 on mixer_cmds IEC958,3 on # ASRock ION 330 has Master Front set to 0 mixer_cmds 'Master Front' 100% # Shuttle XS35GT needs this too mixer_cmds 'Master',0 100% on # and this for various Fusion devices like Zotac ZBOX mixer_cmds 'Front',0 100% on # NVidia CK804 sound devices mixer_cmds 'IEC958 Playback AC97-SPSA' 100% # Allwinner H3 Analog mixer_cmds 'Line Out' 0db on # Allwinner H618 Analog mixer_set 'Left Output Mixer DACL' 100% mixer_set 'Left Output Mixer DACR' 100% mixer_set 'Right Output Mixer DACL' 100% mixer_set 'Right Output Mixer DACR' 100% # Allwinner A20 Analog mixer_cmds 'Power Amplifier' 0db mixer_cmds 'Power Amplifier DAC' on mixer_cmds 'Power Amplifier Mute' on # Allwinner A64 Analog mixer_cmds Headphone 0db on mixer_cmds 'AIF1 Slot 0 Digital DAC' on # Amlogic G12 HDMI to PCM0 mixer_cmds 'FRDDR_A SINK 1 SEL' 'OUT 1' mixer_cmds 'FRDDR_A SRC 1 EN' on mixer_cmds 'TDMOUT_B SRC SEL' 'IN 0' mixer_cmds 'TOHDMITX I2S SRC' 'I2S B' mixer_cmds 'TOHDMITX' on # Amlogic G12 S/PDIF to PCM1 mixer_cmds 'FRDDR_B SINK 1 SEL' 'OUT 3' mixer_cmds 'FRDDR_B SRC 1 EN' on mixer_cmds 'SPDIFOUT SRC SEL' 'IN 1' mixer_cmds 'SPDIFOUT Playback' on # Amlogic GX HDMI and S/PDIF mixer_cmds 'AIU HDMI CTRL SRC' 'I2S' mixer_cmds 'AIU SPDIF SRC SEL' 'SPDIF' # RockPI 4B Analog mixer_cmds 'Right Headphone Mixer Right DAC' on mixer_cmds 'Left Headphone Mixer Left DAC' on # NanoPC T4 Analog mixer_cmds 'HPO L' on mixer_cmds 'HPO R' on mixer_cmds 'HPOVOL L' on mixer_cmds 'HPOVOL R' on mixer_cmds 'HPO MIX HPVOL' on mixer_cmds 'OUT MIXL DAC L1' on mixer_cmds 'OUT MIXR DAC R1' on mixer_cmds 'Stereo DAC MIXL DAC L1' on mixer_cmds 'Stereo DAC MIXR DAC R1' on ) | amixer -c "$card" --stdin > /dev/null 2>&1; done fi
August 8, 20242 yr Ware the images removed from the post? How can I find prebuilt images for this bord?
