Skip to content
View in the app
Armbian Community Forums
LEMFO RBOX HK1RBOX with rk3528
Featured Replies
Hello!
I have got the LEMFO RBOX HK1RBOX with rk3528 (https://de.aliexpress.com/item/1005006654505780.html?spm=a2g0o.order_list.order_list_main.32.7cbf5c5fIj4Quv&gatewayAdapt=glo2deu)
I have tried the following image recommended in one thread
https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz
I copied the rockchip folder to the boot folder and as well the a armbianEnv.txt adding dtfile=rockchip/rk3528-hlink-ht2.dtb. The original armbianEnv.txt was modified the same way.
that did not work. Did you miss any other steps?
Later on I tried I tried  Armbian_24.5.0_rockchip_h28k_jammy_5.10.160_server_2024.04.25.img.gz from ophub with rk3528-hlink-ht2.dtb, unfortunately the LAN did not work, even I have tried all other rk3528
dtb's.
[LAN error:  ....... eth0: stmmac_hw_setup: DMA engine initialisation failed , eth0: stmmac_open Hw setup failed]
Is there any img and dtb that works with this TV Box?
I would appreciate any hint?
Did you try to play a video through HDMI? was sound present? You can use a USB flash (pendrive) to try it. As, I understand, the RK3528 is not working with HDMI audio (in my case neither GPU acceleration for videoplayback, it plays but it's choppy).
  • Author
Hi Fedes_gl!
HDMI is working, but I could not play any video or audio due to missing applications and any internet connection.
I have the same box, but with 4/64 and I havent sucess to boot the image, maybe I'm missing someting,
I put the SD card on the box and turn on, but after 10 minutes no HDMI screen, I havent yet connected by TTL.
Can someone share an image of SD Card so, I can try? Or maybe write a step by step how to create the SD Card, I follow the guide of the forum, without success. Even multiboot does not boot.
Regards
Panda
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
