May 5, 20242 yr Hello all, I noticed that since recently (TM) I got loads of spam from panfrost in my dmesg output: I understand that this has something todo with graphics. The only "graphic" thing I'm doing is running standard Klipper-Screen through HDMI and this seems to be working as always... It definately wasn't there like half a year ago. can I get rid of it? Is it something to worry about? my armbian is running on a Banana-Pi CM4 module of of the eMMC. It's a rather standard installation with Klipper installed via KIAUH. sincerely - cad435 Edited May 5, 20242 yr by cad 435
May 5, 20242 yr This has already been fixed upstream and backported to 6.6.y LTS. https://lore.kernel.org/lkml/20240322164525.2617508-1-christianshewitt@gmail.com/ My suggestion is to update the kernel. If you don't wanna update you may just be able to blacklist the driver, which was what I did until it was fixed. It comes down to what is required by Klipper in your case.
May 6, 20242 yr Author Hello! I tried update the kernel vai armbian-config --> System --> Other. There was only one option available, which I chose. System installed something, rebooted. Problem still persists so. What am I missing? https://paste.armbian.com/zojomiciwu Thanks in advance - cad435
May 6, 20242 yr Author Any Ideas how I can get my installation to update? Edit: I just rebooted the system one more time after the autoreboot and now I only get some errors and pxelinux is booting... Guess my installation just is f'ed and neets full repair (aka new flashing with SD-Card and copying to eMMC) Guess this topic can be also closed... Edited May 6, 20242 yr by cad 435
May 6, 20242 yr 22 minutes ago, cad 435 said: Any Ideas how I can get my installation to update? Edit: I just rebooted the system one more time after the autoreboot and now I only get some errors and pxelinux is booting... Guess my installation just is f'ed and neets full repair (aka new flashing with SD-Card and copying to eMMC) Guess this topic can be also closed... I'll see if I can get those release imgs updated to something more recent and inquire about the breakage.
May 6, 20242 yr Author I reinstalled armbian, uname -r gets me: 6.6.16-current-meson64 with reinstalled I mean I downloaded the image from the armbian website Edited May 6, 20242 yr by cad 435
May 6, 20242 yr 10 hours ago, cad 435 said: I reinstalled armbian, uname -r gets me: 6.6.16-current-meson64 with reinstalled I mean I downloaded the image from the armbian website Edited 10 hours ago by cad 435 New imgs are now available. 6.6.30-current-meson64 https://www.armbian.com/bananapicm4io/
May 6, 20242 yr Author Is it possible to upgrade? I upgraded the system and the kernel via armbian-config, but now I'm on 6.7.4-edge-meson64... I have no idea how to get to newest "latest release" from within the running system tbh... Is it even possible? sudo apt-get dist-upgrade also did really nothing.... I feel like I'm missing some kind of big point here which just hangs before my face, but I don't see it...
May 6, 20242 yr @cad 435 No you aren't really missing anything. In the stable channel, kernel .debs generally only get pushed out every three months when a new stable release is put out (24.05 will be out the end of this month for example). If you want to get regular updates of kernels you need to switch to the nightly builds repository in armbian-config. Right now there is no in between.
