July 16, 20242 yr Hi, I'm trying to build an image on Windows. But when running compile.sh, I get the following error: [💲|💥] Problem detected [ WSL2 Terminal does not support UTF-8 ] Full log: https://paste.armbian.com/zopitumatu I don't know why this is happening, I've tried both cmd, powershell 5, powershell 7, all with the same result. The log mentions the Windows Terminal in the Microsoft Store should support it, but that already is installed and seems to just open the same Powershell 5, with the same error. Any idea on how to fix this?
March 9, 20251 yr For anyone else that runs into this via a search engine: If you run the wsl2 terminal as a profile in Windows Terminal (usually this is just called "Ubuntu"), it works. Not sure what terminal emulator the `wsl2` Start menu launch uses by default, but I guess it isn't Windows Terminal.
