August 5, 20242 yr Every time i do umount of an nfs folder from a qnap nas i get an error in syslog similar to that attached, sometimes my board reboot after error I have Armbian 24.5.5 bookworm I need to mount using nfsv 4.0 or 3 because my nas doesnt support nfs 4.1 or newer. I use a command like this mount -t nfs -o nfsvers=4 -o minorversion=0 myqnapnas:/Backups /mnt  I'm using official Armbian 24.5.5 bookworm image from armbian site on a khadas vim1s     khadas_vim1s_error.txt Edited August 5, 20242 yr by Ivano Brunet
August 5, 20242 yr 1 hour ago, Ivano Brunet said: I need to mount using nfsv 4.0 or 3 because my nas doesnt support nfs 4.1 or newer. Vendors kernels are frozen in time and maintained only at HW stack level, while the rest is "as is". Which is why we all want mainline ... which is even a lot more expensive to make and maintain. It could be days, which can extend to weeks, of work with no warranty of success to sort this out - porting this kernel feature from upstream patches: https://www.kernel.org/ Here is best to wait for next kernel update by Amlogic, which is usually based on updated kernel stack.
August 6, 20242 yr The latest available kernel is 5.15.137. It should be available in the beta repository. Can you give that a try? Make sure to update kernel, u-boot and the bsp package to avoid having any boot issues. Alternatively you can flash a different sdcard with the nightly image for testing. Â
August 27, 20242 yr Author I'll wait for next kernel release, meanwhile i'm using cifs (is a backup folder so can work), i can try the nightly image on a sdcard  Thanks for yours good work on maintaining armbiam!
September 10, 20242 yr Author I've tried with kernel 5.15.137, nothing change. I'll wait for amlogic update 🤞
