Skip to content
View in the app
Armbian Community Forums
Orange Pi 3 dwmac-sun8i 5020000.ethernet problem
Featured Replies
Hi. I'm having network problems at last armbian (Armbian_community_24.11.0-trunk.130_Orangepi3_bookworm_current_6.6.44_minimal). Link drops ethernet RTL8211E all the time and sometimes  board won't come out of reboot. Any ideas?
[    2.392800] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[    2.392834] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[    2.393489] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.393545] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[    2.405541] usb 2-1: USB disconnect, device number 2
[    2.501691] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.501720] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.501728] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.501738] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.501747] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.501755] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.677402] dwmac-sun8i 5020000.ethernet end0: renamed from eth0
[    7.374514] dwmac-sun8i 5020000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[    7.380876] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[    7.422454] dwmac-sun8i 5020000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[    7.422504] dwmac-sun8i 5020000.ethernet end0: No Safety Features support found
[    7.422518] dwmac-sun8i 5020000.ethernet end0: No MAC Management Counters available
[    7.422530] dwmac-sun8i 5020000.ethernet end0: PTP not supported by HW
[    7.423042] dwmac-sun8i 5020000.ethernet end0: configuring for phy/rgmii-id link mode
[   11.518341] dwmac-sun8i 5020000.ethernet end0: Link is Up - 1Gbps/Full - flow control off
[   16.296572] dwmac-sun8i 5020000.ethernet end0: Too many address, switching to promiscuous
  • Author
2 hours ago, Werner said:
Do you have an old OPi3 or the LTS variant? They differ in network chip on the pcb. Please verify you are using the correct image for your board.
Hi. Im used  OPi3 and img to OPI3 Minimal/IOT images with Armbian Linux v6.6 https://www.armbian.com/orange-pi-3/
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
