November 14, 20241 yr Thanks to g4751 for doing the tests for Odroid-HC4. The tests for the Odroid-C2 were performed by myself. Tests were performed on Armbian 24.08 Official releases. Fix is to add a section to the DTB to enable a recently (last year) added kernel driver "meson64-reboot" that is an updated version of the "odroid-reboot" in older kernels. For Odroid-C2: - save your existing DTB - use DTC to convert DTB->DTS - modify the DTS with the code below - use DTC to convert DTS->DTB - reboot (will fail because new DTB not loaded yet) - POR (will now load the new DTB) - log-in - reboot should now work. Quote Add the following under the stock "gpio-regulator-tf_io {....}": meson64-reboot { compatible = "meson64,reboot"; sys_reset = <0x84000009>; sys_poweroff = <0x84000008>; sd-vqsw = <0x39 0x03 0x00>; sd-vmmc = <0x23 0x57 0x00>; }; For Odroid-HC4: - save your existing DTB - use DTC to convert DTB->DTS - modify the DTS with the code below - use DTC to convert DTS->DTB - reboot (will fail because new DTB not loaded yet) - POR (will now load the new DTB) - log-in - reboot should now work. Quote Add the following under the stock "gpio-regulator-tf_io {....}": meson64-reboot { compatible = "meson64,reboot"; sys_reset = <0x84000009>; sys_poweroff = <0x84000008>; sd-vqen = <0x44 0x0e 0x00>; sd-vqsw = <0x44 0x06 0x00>; sd-vmmc = <0x44 0x03 0x00>; }; Notes: - As far as I know, only the Odroid -C4 has an Armbian patch to do the above automatically for each release. - For others, updates may overwrite the DTB and you'll need to perform this fix again. In theory, DTB changes are fairly rare.
January 8, 20251 yr Hi, I found this by chance.. and because I didn't know how to do it, I will post ChatGPT answer, also when doing the conversion, I get a lot of warnings, is that normal? 1. Save the existing DTB file Locate your system's DTB file. It is usually located in /boot or a subfolder like /boot/dtb/. cp /path/to/existing/dtb /backup/path/dtb_backup.dtb Example: cp /boot/dtb/amlogic/meson-sm1-odroid-hc4.dtb ~/dtb_backup.dtb 2. Convert the DTB to DTS (readable text) Use the dtc (Device Tree Compiler) tool to convert the binary DTB file to a DTS file (readable text). dtc -I dtb -O dts -o converted_file.dts original_file.dtb Example: dtc -I dtb -O dts -o meson-sm1-odroid-hc4.dts /boot/dtb/amlogic/meson-sm1-odroid-hc4.dtb 3. Modify the DTS file Open the .dts file in a text editor (such as nano, vim, or another editor) and insert or modify the required code. nano meson-sm1-odroid-hc4.dts Make the necessary changes and save the file. 4. Convert the DTS back to DTB Use dtc to convert the modified DTS file back into a DTB file. dtc -I dts -O dtb -o new_file.dtb modified_file.dts Example: dtc -I dts -O dtb -o /boot/dtb/amlogic/meson-sm1-odroid-hc4.dtb meson-sm1-odroid-hc4_modified.dts Ensure that the new DTB file is placed in the correct location (usually /boot/dtb/...). 5. Reboot (this will initially fail) Execute the reboot command: reboot As the guide notes, this reboot will fail because the system has not yet loaded the new DTB. 6. Perform a Power-On Reset (POR) Turn off the ODROID HC4 completely and then power it back on. This will load the new DTB file. 7. Log in and test the reboot Once the device successfully reboots with the new DTB, log in to your system and test if the reboot command works now: reboot Required Tools dtc: If you don’t have the dtc compiler installed, you can install it with: sudo apt install device-tree-compiler
February 27, 20251 yr tried this for Armbian 25.2.2 noble on Odroid HC4 and no success, unfortunately... any ideas? I really would not want to downgrade, since I have already finished my nextcloud installation :-(
