Skip to content
View in the app
Armbian Community Forums
La Frite wont boot armbian, kernel panic etc.
Featured Replies
Hello, I have a La Frite 1gb. Im trying to boot armbian but it wont boot, I have checked the common problems list on the libre computer forum , It stated sd card, power supply etc. I have made sure that none of these are the problem, I have tried 5 different sd cards and im now using a 6th brand new Sandisk Extreme bought in the store (The one recommended by libre computer). I have tried many PSUs , All 5V 3.0A which is supposed to be enough, I get no help in the la frite forum so i thought i would check in with you guys and see if anyone knows what the issue could be.
Also, id like to add, it wont boot anything, none of the images of ubuntu destkop, raspbian, etc from libre computers has worked either but i think Armbian is my best chance since the images were updated recently, meanwhilst the official images were not updated since 2023.
This is the instructions for the La Frite boot:
The normal process flow is as follows:
1. Download Compressed Image (eg. file+model.img.xz) DONE
2. Extract Compressed Image (eg. file.img) DONE
3. Flash Extracted Decompressed Image to Bootable Storage Medium (MicroSD card) DONE
4. Insert Bootable Storage Medium into Board DONE
5. Provide Sufficient Power to Board DONE
6. Board Boots u-boot Bootloader from Storage Medium DONE
7. u-boot Bootloader Loads EFI Bootloader (GRUB) done
I never come further than this. The errors are vast, there are many of them and they are different all the time, It is stuff like KERNEL PANIC, KERNEL TIME OUT, END TRACE etc, Stuff which i dont understand.
Is it possbile that i got sent a faulty La Frite? It is brand new unboxed 3 days ago, during which these 3 days i have been all day trying to get it to work. Flashing Tools: I have used all recommended tools, including Win32 Disk Imager, macOS Disk Utility, raspberry pi imager, balena etcher and installing linux on an old computer just so i cold use Gnome Disk Utility on Linux, didnt work either.
I think i have tried booting over a 100 times, to no success.
9. EFI Bootloader Boots Linux
10. Linux Boots systemd
11. systemd starts services and applications
I read on this forum that one guy couldnt get it to work until he tried the V20 images, however i cant seem to find those in the archive, it only goes back to 24.8.1 i believe.
I appreciate any help i could get thanks. I have also updated the firmware of the La Frite itself using the latest spi flash from libre computers, this was actually sucesfull and the firmware of the board was updated.
Ill share some screenshots of some of the errors, All of these has usually been stopped completely or the one time an infinite loop:
Spoiler
IMG_6191.jpgIMG_6192.jpgIMG_6193.jpgIMG_6195.jpgIMG_6194.jpgIMG_6196.jpgIMG_6198.jpgIMG_6200.jpg
Edited by bedahtpro
putting images into a spoiler
🫣  Let me take a look.
[EDIT]
So far I don't see an issue, I booted an image with no errors on my La Frite (1 GB).  My guess is, you have old firmware on the board itself.  The Armbian download page fir la frite includes instructions on how to update the spiflash with Libre Computers most recent binary.
  • Author
Hello TonyMac, I have updated the firmware of the La Frite using the latest spi flash from Libre Computers website, So the board has the latest firmware.
  • Author
Yes i have used different usb sd card adapters, I have also tried USB Stick and an external SSD, The bootfile / bootflow is always recognised. I have the boot switch set to NOR on the board and the board should be able to boot from USB. Can you detail how you flash the image just to make sure im not doing anything wrong?
Edited by bedahtpro
  • Author
No , I dont have an eMMC module, So i need to get it to work without the eMMC. It should be able to boot from the usb without issue, I have read that many users have had no problems with this. The problem always comes after "Starting Systemd-udevd"  I think there might be something wrong with my board honestly, But im not sure, i dont understand any of the error messeges.
  • Author
I have also used balena etcher, along with the pi imager but it wont boot those images either, Tried both with .img.xz and uncompressed the files to .img aswelll
I have used many ones but some of the ones i remember the specs of / can google, assuming you mean the voltage etc are the following:
20W apple charger:
5V at 3A
65W Nexode Ugreen Charger:
65W Max
USB-C1/C2:5V/3A 9V/3A 12V/3A 15V/3A 20V/3.25A 65W Max
PPS:3.3-11V/4.5A
USB-A: 5V/3A 9V/2A 12V/1.5A 10V/2.25A 22.5W Max
30W Lencent International Travel Charger:
Single USB : 5V 2.4A
Type C Port: 5V 3A (MAX)
Total Output: 5V 3.5A (MAX)
2 hours ago, bedahtpro said:
20W apple charger:
5V at 3A
65W Max
PPS:3.3-11V/4.5A
You don't have any "dumb" power supplies?
Any USB-type -C style charger will limit to 450 or 900 mA without a "smart" device attached to it, irrespective of it's rating. (it requires a matched supply/cable/endpoint configuration to get 5V 1.5 or 3 A)
*Most* QC- compatible (USB A output) will also limit the current unless they detect the correct QC-style resistances on the endpoint.
You wouldn't happen to have a USB power meter on hand to see if these supplies are throttling the USB-A based on the fact the device has no "smart" charging built into it?  I just measured mine and with keyboard, HDMI and network attached I broke 600 mA peak.  If the supply had throttled to 450 mA it would have crashed right after loading the kernel.  Otherwise I think you need to talk to LC and see if they can debug the issue you're having.
  • Author
Thanks for all the help youve given me, i really appreciate it, I thought maybe this could be it, I dont have a USB power meter unfortunetly but i do have a computer PSU ATX Breakout board which allows me to plug in a PC PSU with the atx connector and i then get 6x USB ports, this is a pcb and it is as dumb as it gets, Outputs 5V 2.0A at all ports, only usb a ports.
I really thought it could work but no, same issue now as always, Unfortunetly Libre Computer is not helping at all and not even responding to me so i will have to give up on this board and try to return it or make a warranty claim.
The problem is not with the storage, not with the power and not with the images, so the only option left is that there is something wrong with the board. I usually see the messge "Failed to change CPU frequency -5" right before it stops so perhaps there is something wrong with the cpu.
I have purchased one Radxa Rock 2F 2GB and one Orange Pi Zero 3 1GB. Hoping i will have better luck with these boards.
Edited by bedahtpro
I have only recently been able to get my LaFrite 512, no EMMC to boot armbian.
My errors were legion. Might I suggest:
1. write the spi update image with the dd command, I had used etcher to no avail
2. make sure you use the USB port nearer the gpio pins
3. connect the hdmi output on the board to a monitor or use the serial header pins so that you'll have visual confirmations of what is going on
4. if the spi update image is newer than the board's  image the update should be applied. My board was out of date and the image was applied. I've no idea what happens if the board has the same or newer image. I wasn't patient or thorough enough to check.
5. Use etcher to write any of the currently posted minimal images to a usb drive of 8, 16, or 32 GB - don't use a larger usb drive. Do not use the Ubuntu server image - the apt sources are bad on that one.
6. put the usb drive with the linux image in the usb port further from the gpio pins -- the opposite of what is needed for the spi update.  Again make user you can see what is going on when you boot - hdmi to monitor is fine.  Plug a usb keyboard in the other usb port to make things easy.
7. Power on the board. I used an el-cheapo power supply and it worked just fine.
If you have a good usb drive the board should boot fairly quickly. There shouldn't be any or many failures on the way up. Again let me reiterate -- a small usb drive. Every 64GB and larger drive I tried failed during the boot process. You may have better luck, but start small to see it things work.
I had decided some months ago that my board was defective, it wasn't, my brain was (or is).
Hopefully some of my experiences will help.
BTW make sure you use the forky rolling release for your Radxa-2F, because unless Armbian has fixed the older releases, your wireless card's drivers will be deleted on an apt upgrade or an Armbian-upgrade.
Hope this helps.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
