La Frite wont boot armbian, kernel panic etc.
I have only recently been able to get my LaFrite 512, no EMMC to boot armbian. My errors were legion. Might I suggest: 1. write the spi update image with the dd command, I had used etcher to no avail 2. make sure you use the USB port nearer the gpio pins 3. connect the hdmi output on the board to a monitor or use the serial header pins so that you'll have visual confirmations of what is going on 4. if the spi update image is newer than the board's image the update should be applied. My board was out of date and the image was applied. I've no idea what happens if the board has the same or newer image. I wasn't patient or thorough enough to check. 5. Use etcher to write any of the currently posted minimal images to a usb drive of 8, 16, or 32 GB - don't use a larger usb drive. Do not use the Ubuntu server image - the apt sources are bad on that one. 6. put the usb drive with the linux image in the usb port further from the gpio pins -- the opposite of what is needed for the spi update. Again make user you can see what is going on when you boot - hdmi to monitor is fine. Plug a usb keyboard in the other usb port to make things easy. 7. Power on the board. I used an el-cheapo power supply and it worked just fine. If you have a good usb drive the board should boot fairly quickly. There shouldn't be any or many failures on the way up. Again let me reiterate -- a small usb drive. Every 64GB and larger drive I tried failed during the boot process. You may have better luck, but start small to see it things work. I had decided some months ago that my board was defective, it wasn't, my brain was (or is). Hopefully some of my experiences will help. BTW make sure you use the forky rolling release for your Radxa-2F, because unless Armbian has fixed the older releases, your wireless card's drivers will be deleted on an apt upgrade or an Armbian-upgrade. Hope this helps.
Radxa Rock 2F bookworm minimal problems
Have just tested Forky (Debian) release on both the 2A and the 2F, and in both cases the wireless driver survived an upgrade. I also tested the Plucky release on the 2A, and the wireless driver did not survive the stock upgrade. I have not tested the Plucky version on the 2F yet. Also it should be noted that the cron implementation in the Forky version for the 2A is fouled up. Any ordinary user's crontab has to be edited by root. Bad permissions on a number of files. Nice to know that at least the wireless adapter problem has attracted someone's interest.
Finally able to solve the problem. The aic8800 wifi modules and others associated with the wifi driver are deleted when upgrading the kernel. I found Debian packages on radxa's github site downloaded the firmware and usb modules and then reinstalled them from the /tmp directory after kernel upgrade but before rebooting. While this does work, it is a sloppy hack. It seems to me that there ought to be some way to retain the wifi drivers on upgrade, but it will take a more knowledgeable person to do that. The same hack allows the wifi on the Rock-2A to survive a kernel upgrade. Wired Ethernet of the Rock-2A survives a kernel upgrade without issue.
- Radxa Rock 2F bookworm minimal problems
I have been trying to run the bookworm minimal image for the Radxa Rock 2F with poor results. Wifi stops working after an "armbian-upgrade" and after apt upgrade. Doing an nmcli -p r results in WIFI-HW missing response. It seems to me that after the upgrade, something is wrong with the aic8800 driver module. Unfortunately I am too ignorant to be of much help, but any suggestions would be most welcome. Thank you.
- Lates build does not boot
