Skip to content
View in the app
Armbian Community Forums
Rock3A Armbina how to enable 1-wire, SPI3, and I2C3
Featured Replies
not sure if you can run 1-wire, SPI3, and I2C3 together as there may be an overlap in the pins used, but I have just managed to get my I2C1 and I2C3 busses working after having struggled with overlays' installation, that is, after thinking they are not working.
My problem came from "overlay_prefix=" in /boot/armbianEnv.txt.
It was set to "rk35xx". I edited armbianEnv.txt directly, and after changing this to "rk3568" (for Rock 3a), it allowed me, when running armbian-config (system --> kernel --> manage device tree overlays), to select from overlays inside /boot/dtb/rockchip/. In that folder, all files are indeed prefixed with "rk3568".
However, I wanted to try "rockchip-rk3568-hk-i2c0.dtbo" from /boot/dtb/rockchip/overlay/. Prefix here is "rockchip-rk3568"; so I changed "overlay_prefix=", again directly inside /boot/armbianEnv.txt using a text editor, to that, and started again the armbian-config utility. Now, to my delight, I was able to select from the overlays stored inside /boot/dtb/rockchip/overlay/. (Note: In this folder is the SPI overlay that you will want to try.)
Note to not include the "-".
Note also that overlays rockchip-rk3568-hk-i2c0 and rockchip-rk3568-hk-i2c1 (note I2C0 and I2C1) enabled I2C busses 1 and 3 on the Rock 3a, *not* 0 and 1 as the names might imply! (Bus 0, 5 and 6 were already enabled on my setup before adding these two overlays.) (You will have to try and see which of the two enables I2C3 for you 🙂.)
In other words, there may be inconsistencies in numbering schemes.
Hope this helps,
Teddy
Edited by teddytronix
Alright. Yes, there seems to be some issue with the naming of the overlays which required editing armbianEnv by hand. It is hard to keep up with the continously changing world of SoCs and kernels where latter, especially on mainline, often even lacking basic overlays since close to nobody deals with this.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
