April 10, 20251 yr Can I enable wifi (SV6256P) in H616 DDR3 Tv box https://github.com/paolosabatino/ssv6x5x/tree/master or build from old kernel 4.4.x Edited April 10, 20251 yr by Jain Ziad clearance
April 24, 20251 yr 13 minutes ago, Nick F said: @SteeMan Do you mean moving to TV Box Wi-Fi folder? Moved the post to the correct sub-forum.
February 12Feb 12 @Jain Ziad Try this: https://forum.armbian.com/topic/57960-sv6256p-wifi-now-working-on-linux-6x-armbian-tested/
