April 21, 20251 yr I am new to armbian, and so far I managed to build a working image with some custom packages added and some removed by customizing `userpatches/lib.config`. Easy stuff and it's working great so far! Now I need to build some packages from sources and get them added to the resulting image. The usual way I would do this, would be installing a cross toolchain, having a staging dir with includes and libs from the dev packages I add to the image, etc. But after building the base armbian image, on my system I see I have two docker images related to armbian (ghcr.io/armbian/docker-armbian-build and armbian.local.only/armbian-build), and I wonder if maybe the "local only" image is somehow like a "staging" image or how does this work. So far I have not been able to find documentation about the procedure, is there any guide explaining how to achieve this?
April 21, 20251 yr Easiest way would be using the customization script: https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-image-customization-script
April 21, 20251 yr Author Thanks for help. If I understand correctly, that script is useful to add files to the image and perform modifications of it. But it seems that runs on a virtualized environment (QEMU I presume). Although that might work, I would prefer having a cross-compilation environment. I have verified the docker images I mentioned before have the cross compile toolchain, but I don't know if armbian generates something like a staging directory to be used for cross compilation. Could it be this is not possible with armbian and I should be using something like Yocto for this task?
