- Installation of Proxmox VE failed
I tried to replace PXVirt on my Raspberry Pi 4 (8GB RAM) with a fresh Proxmox installation. I flashed the Armbian 26.8.1 minimal image and then ran `apt update && apt full-upgrade`. I started the installation with : armbian-config --cmd PVE001 An error occurred during installation: An apt update shows Hit:1 http://deb.debian.org/debian trixie InRelease Get:2 http://security.debian.org trixie-security InRelease [43.4 kB] Get:3 http://download.proxmox.com/debian/pve trixie InRelease [4,357 B] Get:4 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Hit:5 https://github.armbian.com/configng stable InRelease Get:7 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Get:8 http://security.debian.org trixie-security/main arm64 Packages [252 kB] Err:9 https://enterprise.proxmox.com/debian/pve trixie InRelease 401 Unauthorized [IP: 45.144.208.36 443] Get:10 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index [63.3 kB] Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2026-09-04-2006.30-F-2026-09-04-1415.43.pdiff [1,241 B] Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2026-09-04-2006.30-F-2026-09-04-1415.43.pdiff [1,241 B] Get:6 http://distrohub.kyiv.ua/armbian trixie InRelease [39.4 kB] Get:12 http://distrohub.kyiv.ua/armbian trixie/trixie-desktop arm64 Packages [8,515 B] Error: Failed to fetch https://enterprise.proxmox.com/debian/pve/dists/trixie/InRelease 401 Unauthorized [IP: 45.144.208.36 443] Error: The repository 'https://enterprise.proxmox.com/debian/pve trixie InRelease' is not signed. Notice: Updating from such a repository cannot be done securely and is therefore disabled by default. Notice: See the apt-secure(8) man page for repository creation and user configuration details. This showed the error. Any idea what's wrong with the installation? I would use "pve-no-subscription" and not "enterprise.proxmox". How to do? Regards, Markus
Armbian with Virtualbox and Home Assistant
Hello @greg396 What exactly are you trying to achieve? I assume you want to run Home Assistant in a virtual machine on ARM64. That's possible, but you need to install some prerequisites. According to your links, you're using an Orange Pi 5 Plus (RAM unknown). It's powerful enough, but I recommend at least 8GB. 🙂 First, install an ARM64 clone of Proxmox Virtual Environment (PXVirt). https://github.com/jiangcuo/pxvirt Then install HA: https://pimox-scripts.com/scripts?id=pimox-haos-vm `bash -c "$(curl -fsSL https://raw.githubusercontent.com/asylumexp/Proxmox/main/vm/pimox-haos-vm.sh)"` Done. If you run it on a home server it's OK! --- I personally use a Raspberry Pi 4 with 8GB of RAM running Armbian (trixie) since 1,5 year with PXVirt. It's running: Home Assistant (ARM64) Pi-hole OMV VM-Trixie Everything performs very well. 😃 Regards, Markus
Home Assistant with full Armbian desktop experience?
->a bit off topic<- Okay, if you have enough time, you can play around with PXVIRT (formerly the Proxmox port). 🙂 (https://github.com/jiangcuo/pxvirt) It's like Proxmox for ARM64 devices. I've been playing around with an 8 GB Raspberry Pi 4 with a 256 GB USB SSD lying around. In short: I installed a self-made minimal image (RPi4b). Installed PXVIRT (https://docs.pxvirt.lierfang.com/en/installfromdebian.html) Created some LXC containers (e.g., Lyrion Media Server, Heimdall, Pihole, Portainer, etc.) Created a virtual machine (Bookworm with OMV) Created a virtual machine with HAOS / -> bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/vm/pimox-haos-vm.sh)" It's been running perfectly stable for 56 days now. 👍 Okay, it wasn't easy to set up and compile all the software components, but it's running perfectly. I plan to buy an Orange Pi 5 Plus with 32 GB RAM for these tasks next time. Regards, Markus
- OrangePi Plus 2 - Which images will work
- There were no errors before, but now there are errors when compiling???
Armbian with preinstalled OpenMediaVault (OMV)
Hello @AlexVS, you wrote: That is no image with preinstalled OMV but with preinstalled openhab. There is no image for ri4 with OMV preinstalled (as far as i see..). You have to build it by yorself. See DIY on post 1. Markus
Ahh, okay, i didn't know Now it's working.. 👍 Thank's Werner
Hello Igor, try to build OMV for rpi4. ./compile.sh BOARD="rpi4b" BRANCH=current RELEASE=bookworm ENABLE_EXTENSIONS="omv" KERNEL_CONFIGURE="no" BUILD_MINIMAL="yes" Got these error messages: [🌿] Enabling extension [ omv ] [🔨] ERR: Extension problem -- cant find extension 'omv' anywhere - called by /home/master/build/lib/functions/general/extensions.sh [💥] Exiting with error 17 [ at /home/master/build/lib/functions/general/extensions.sh:1 enable_extension() --> lib/functions/general/extensions.sh:1 initialize_extension_manager() --> lib/functions/general/extensions.sh:135 do_main_configuration() --> lib/functions/configuration/main-config.sh:317 do_with_logging() --> lib/functions/logging/section-logging.sh:81 do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] What I'm doing wrong? Markus
How can I get Orange Pi Plus 2 Image(OS)?
Hello @hyungjuk, try to build a image with this command: ./compile.sh BOARD=orangepiplus BRANCH=current RELEASE=bookworm BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,img As you can see the differend about Plus und Plus 2 is only the size of RAM. E. g. Plus = 1GB, Plus 2 = 2GB See in the build framework: Good luck, it should work.. I run Home Assistant for (small) tasks, without Problems.. Markus
- How can I get Orange Pi Plus 2 Image(OS)?
- orange pi not booting from emmc when sd card in connected
