Skip to content
View in the app
Armbian Community Forums
How to USB boot Orange Pi Zero with MX25L1606E NOR flash?
Featured Replies
I have a Orange Pi Zero with the MX25L1606E (16Mb) NOR Flash
is it possible flash uboot to the nor flash and boot a OS from the USB port and how?
All without using a SD card
1.Update package
$ sudo apt-get update
$ sudo apt-get upgrade
2.Download flashrom-0.9.9.tar.bz2 from here.
https://www.flashrom.org/Flashrom/0.9.9
3.Install flashrom-0.9.9 to Opi-ZERO
$ sudo apt-get install pciutils
$ sudo apt-get install libftdi-dev
$ sudo apt-get install libusb-dev
$ sudo apt-get install libpci-dev
$ bzip2 -d flashrom-0.9.9.tar.bz2
$ tar xvf flashrom-0.9.9.tar
$ cd flashrom-0.9.9/
$ make
$ sudo make install
4.Write SPI Flash image
$ cd
$ dd if=/dev/zero count=2048 bs=1K | tr '\000' '\377' > spi.img
$ dd if=/usr/lib/linux-u-boot-orangepizero_5.31_armhf/u-boot-sunxi-with-spl.bin of=spi.img bs=1k conv=notrunc
$ sudo flashrom -p linux_spi:dev=/dev/spidev0.0 -c MX25L1605 -w spi.img
Note:
linux-u-boot-orangepizero_5.31 depends on the version of the kernel.
5.Writing an image to USB memory
You will need to use an image writing tool (like Win32DiskImager.exe)
to install the Armbian image on your USB memory.
6.Shutdown
A SD card is removed from Opi-ZERO.
A USB memory is stuck into Opi-ZERO.
7.Power On
  • Author
So basically write a u-boot image to the NOR flash and an armbian image to the usb memory and power on the device
i did try that with the sunxi wiki recommended
$ sudo sunxi-fel -v -p spiflash-write 0 u-boot-sunxi-with-spl.bin
though that didn't work because "Invalid command spiflash-write"
your flashing method doesn't want to work for me either "linux_spi_init: failed to open /dev/spidev0.0: No such file or directory"
It's not in the main sunxi-tools branch yet: https://github.com/linux-sunxi/sunxi-tools/pull/107
Which image (or rather which kernel branch - default or dev) did you use?
  • Author
I'm not on any Armbian kernel
I'm on Ubuntu trying to set up a opi zero without a SD card
no wonder the flashing didn't work ;)
assumed i was on the device with Armbian
17 minutes ago, martinayotte said:
On which one ?
On another device or a PC. As I understand it "without SD card" means without booting any image on the board itself, so the only option left is FEL boot (requires a pretty complex setup) or FEL SPI write (requires compiling sunxi-tools from a special repo/branch that I linked above)
  • Author
I got it to work somewhat
i compiled a u-boot-sunxi-with-spl.bin (orangepi_zero) with CONFIG_SPI_BOOT=y and compiled the sunxi-tools from apritzel's spiflash branch and succesfully flashed the u-boot image to the NOR flash via USB OTG
copied Armbian 5.32.170915 (nightly) to a 8gb USB 3.0 with Etcher, plugged the USB into the opi-zero and turned it on
the green LED comes on fairly quickly, the ethernet leds flash as well but it takes a couple power-on's for me to get the heartbeat from the red LED and i can connect over SSH but the system seems unstable and sluggish
Could it be the power? i tried 2 different 5V power supplies and the USB 3.0 ports of my PC and it doesn't seem any different
How much current can they deliver? (what's specified on the PSU doesn't match every time with the reality!) USB port on a PC is not recommended (they're mostly deliver arround 500mA). We've an own subforum for underpowered boards here.. ;)
https://forum.armbian.com/index.php?/forum/31-sd-card-and-power-supply/
A personal opinion: Before start to think about booting from an USB stick, I would make sure that your system runs smoothly with an SD card. Just to reduce possible variables of failure.
  • Author
One has 900 mili amps output and the other 1.5 amps
don't actually have any tools to accurately measure it though, only read the labels
I ordered a SD card, this whole USB business is really just a result of lacking patience
Problem is often not curret, I would recommend 2 amps (as xunlong do) but this is often not needed. The problem of all these small usb chargers is, that the voltage drops when they are running under high load. This doesn't matter if you charge a battery but your orange pi tends to be bitchy.. :P
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
